Author Topic: RetroPlay (bartop) - updated - New CP  (Read 5264 times)
RecycledPast
  • Last login:October 09, 2011, 09:14:47 pm
    • My 2 scratch built arcade machines
« on: February 25, 2004, 04:36:27 pm »
See the new CP photo further down the page 11/8/04
Here's my first attempt at a MAME machine.  Although the machine is functional it's not done.
It's a P2, running DOS & arcadeos. Only vertical games.
I rushed to get it working for a party I had last weekend so the artwork is very plain since I didn't have enough time to spice it up.
The wire hanging out the side is there because I was trouble shooting the spinner.
I have a ton of respect for everyone that has made a machine.  It was more work then I had anticipated. I almost didn't want to show mine since everyone else's looks so much better.
« Last Edit: November 08, 2004, 08:43:45 pm by Recycled-Past »
Zathras
  • Last login:June 06, 2011, 01:06:02 am
  • Yeah.
Re:RetroPlay (bartop)
« Reply #1 on: February 25, 2004, 05:34:34 pm »
Looks good to me and 99% of any project is that it works - The rest is just polish :)
Are the joysticks 1 4-way and 1 8-way?
How/where do you have the pc mounted?
I'm considering building up a bartop type now that the bug has bit me (I think I'll always have to have a project going now....)
Space Warped by Someone
BobbyG66
  • Last login:November 13, 2016, 11:52:09 am
  • Current project: Dodgeball
« Reply #2 on: February 25, 2004, 05:44:10 pm »
Looks good for a rush job.
Hope the paint was dry...
Half of the people you meet are below average.
walls83
  • beer is good
« Reply #3 on: February 25, 2004, 09:13:41 pm »
Throw some t-molding on it.  It would look much better.
paigeoliver
  • Awesome face!
« Reply #4 on: February 26, 2004, 02:08:42 am »
Wanna trade your spinner for something, once you pull it out?
Also, your problem might just be that you have mouse input=0 in your Mame config, that is stupidly the default for some reason.
RecycledPast
« Reply #5 on: February 26, 2004, 09:18:07 am »
Zathras: Yes, Yellow=4way Green=8way
I don't really have the motherboard "mounted"
It's just sitting on the bottom.  I didn't measure the height of it with the video card before I started so I had to cut a notch in the shelf to fit the sound and video cards, which ends up holding it in place.  I didn't cut the notch deep enough so the MB isn't deep enough so I had to cut a whole in the back so the video cable sticks out about a 1/2 inch.
I just ordered a free sample of t-molding, so I'll test it out on some scrap pieces of wood.  The plywood I used is kind of crappy and I'm afraid that when I try to route the slot it will just chip apart.
Paigeoliver:  I plan on using the spinner on my next project, but if I change my mind, I'll let you know.
I tested a regular PS2 mouse on the machine and it works.  The spinner is USB with a PS2 adapter on the end.  I tried the spinner on a windows laptop and couldn't get it to work on there either but it does work without the PS2 adapter.
paigeoliver
  • Awesome face!
« Reply #6 on: February 27, 2004, 12:29:42 am »
Oh, those PS2 adaptors only work if the "mouse" or "keyboard" has both types of hardware inside.
RecycledPast
« Reply #7 on: November 08, 2004, 08:40:21 pm »
I redid the CP,
 - Removed the 2  joysticks
 - Removed a button.
 - I added a T-Stick Plus long balltop
 - added a custom printed CPO
 - added plexi glass over CP
 - added t-molding around CP
After a few parties I noticed the 4 way 8 way thing confused people.  I think my next machine will be dumbed down as possible.
RecycledPast
Re:RetroPlay (bartop) - updated - New CP
« Reply #8 on: November 08, 2004, 08:51:55 pm »
Closer version of CP with Cookie my play tester.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #9 on: November 08, 2004, 09:48:03 pm »
Pretty good job. Just looks like you need a sander to smooth out those sides, and smooth out the curve of your control panel. Everything else looks good.
~Ray B.
NO MORE!!
menace
« Reply #10 on: November 09, 2004, 01:31:27 pm »
I just love those bartops--looks pretty good to me and yeah I had to dumb down mine alot for her parent's as well as remove  any and all button combos that would make things happen (i.e. shortcuts) then i wrote out detailed instructions on how to use it--they are running well now.
