Author Topic: updating a driver from mame 0.142 to the latest mame, anyone that can help?  (Read 3006 times)
abispac
  • Last login:Yesterday at 01:33:55 am
So i have a version of mame 0.142 that enables the use of coin hoppers or ticket dispenser in the proper way to use,i also have the nodified driver that enables it, works like a charm. I dont use it for comercial purposes. I would like to update this modified driver to be able to compile it with the latest mae. Its anyone interested? Thanks for the help.
« Last Edit: May 11, 2021, 12:30:14 pm by abispac »
Robbbert
  • Last login:January 26, 2026, 03:41:15 am
abispac2009: I see your reddit post on this subject was locked because of your commercial purposes.
https://old.reddit.com/r/MAME/comments/n9ejsh/updating_a_driver_from_mame_0142_to_the_latest/
javier1979: your attempt 3 months ago didn't work out either
https://www.mameworld.info/ubbthreads/showflat.php?Cat=&Number=389922
I reckon if you're smart enough to code in hopper support, you're smart enough to change the text in a few lines. It looks quite straightforward.
abispac
