Author Topic: vertical cabinet front end  (Read 2353 times)
mattnday
  • Last login:December 29, 2005, 10:13:30 pm
« on: February 24, 2004, 08:49:30 pm »
struggling a little bit with mamewah............is this the best bet for a vertical cabinet. I would like to get away from using the pivot rotation software as it is causing some grief to my system.
I loaded gamelauncher and it was ok but I was kind of looking for something a little more impressive tat it doesnt take a rocket scientist to set up
PacManFan
  • Last login:December 06, 2005, 12:18:56 pm
    • Kymaera Home Page
Re:vertical cabinet front end
« Reply #1 on: February 24, 2004, 09:05:34 pm »
Check out Kymaera.
www.pacmanfan.com
All Hail Smezznar! The Giant purple centipede of Omnicron 5. Regail him with your odiferous offerings of onion powder!
SirPeale
  • Green Mountain Man
« Reply #2 on: February 24, 2004, 09:10:48 pm »
ArcadeOS does vertical.
OSCAR
    • Oscar Controls
« Reply #3 on: February 24, 2004, 09:21:14 pm »
Cocktail FE
This FE was designed specificially for vertical monitors and has a similiar appearance to MAMEWAH.
slicer_d
  • Last login:November 06, 2013, 12:51:11 am
  • Yay n' stuff
« Reply #4 on: February 24, 2004, 10:33:59 pm »
Gamelauncher works for me a has some decent support.
http://www.dribin.org/dave/game_launcher/
paigeoliver
  • Awesome face!
« Reply #5 on: February 25, 2004, 12:25:25 am »
Last Mame cabinet I sold was a vert one, and it used the DOS version of gamelauncher.
I also own 3 vertical Mame cabinets, using windows gamelauncher, arcadeOS, and advancemenu (windows) respectively.
DarkKobold
  • Last login:June 18, 2013, 11:31:23 pm
« Reply #6 on: February 25, 2004, 08:27:29 am »
ArcadeOS has the distinct advantage of being able to support arcade  monitors. It also can use the parrallel port to turn on a monitor after the correct resolution is being sent, to protect the monitor.
My games: Tapper, Asteroids, Cocktail-MAME, Tron, ROTJ, Tempest, Star Wars (not working)
My wants: Warlords Cocktail
« Reply #7 on: February 25, 2004, 03:15:29 pm »
If your video card supports hardware rotation you could also give that a shot...
But since many of the other FE's mentioned can rotate natively they are probably a better bet...
SaiNRuB
  • Last login:November 26, 2024, 07:30:53 pm
  • Pluck your magic twanger, Froggy!
« Reply #8 on: February 26, 2004, 12:55:02 am »
I am planning to build a vertical cabinet with a 19" CGA monitor.
Id like to hear what kind of software and hardware config you would suggest for me and my plans.
I presently have these components:
ASUS A7PRO /KT133 Chipset
Duron 700
256MB PC100 SDRAM
10GB ATA66 HDD
ATi RAGE 128 Ultra 32MB
Creative Labs Ensoniq  PCI Sound Card /1371 Chipset
I bought these in regards to using ArcadeOS and I am getting a lil nervous on my build since i am almost prepared to find a cga monitor to begin testing.
I plan on having swappable control panels so hotswapping is going to require usb so I dont know about a DOS environment. Id like to use windows with my cga monitor so ive been reading up on that and have come to the conclusion that it is very steep. The best alternative would be to buy a ArcadeVGA card but that would be out of my budget.
What are the fundamentals with running windows with a CGA Monitor without an ArcadeVGA Card?
I am all ears and appreciate and advice you may offer me. TIA
mattnday hopefully if i get some feedback will both realize that its not going to be as hard as we think on getting our vertical cabs up and runnin with arcade monitors and a vertically orineted front-end :)
« Last Edit: February 26, 2004, 01:02:03 am by SaiNRuB »
paigeoliver
  • Awesome face!
« Reply #9 on: February 26, 2004, 01:25:54 am »
To my knowledge it has never been done.
And also, please take no offense to any of these comments I will now post.
You CAN afford the extra controls needed to have USB powered hot swappable panels, and you CAN afford a 19" CGA display, but you CAN'T afford an arcadeVGA card?
That seems to be an improper budgeting issue. As in, you don't seem to be wisely spreading you cash around for the project. This isn't quite as bad as some others I have seen though ("I CAN afford a brand new 6 GHZ computer, hand built cabinet, and $300 worth of custom artwork, but I CAN'T afford an actual coin door, or an encoder").
My suggestion, drop $90 worth of hot swappable panels so that you can afford the arcadeVGA. I am not sure what panels you are making, but I am sure you could cut some cash in that department, as you can always build them later.
SaiNRuB
« Reply #10 on: February 26, 2004, 09:31:23 am »
paigeoliver you are absolutely right, I need to go over my plans and make some serious changes to the hardware that will be involved.
I am now at a conclusion that Id either go with an AVGA card our rule out all usb and go with a dos environment and no hotswapping.
Either way i hope i make the rite decision in regards to my cabinet.
I appreciate your advice.
« Reply #11 on: February 26, 2004, 12:02:58 pm »
I would agree that an ArcadeVGA is the way to go...
But I wouldn't neccessarily rule out Windows + USB - what are the main costs that you are concerned about with this route?
SaiNRuB
« Reply #12 on: February 26, 2004, 01:15:09 pm »
Hiya minwah, I was confused on being able to use a ATi Rage128 Ultra with AdvanceMame/AdvanceMenu in Windows. I know that a Trident Blade T64 is able to and thought the same was possible with my particular card. I now know it isnt but i would be able to use it in a Dos environment with AdvMame/AdvMenu.
So basically im running in circles with high hopes :)
« Last Edit: February 26, 2004, 01:17:49 pm by SaiNRuB »
« Reply #13 on: February 26, 2004, 01:27:56 pm »
I see, I don't know much about AdvMAME but I would think that it would run pretty well with DOS on your spec PC.  I don't think you would get any better performance in Windows really so you may as well try it out - you can always upgrade your PC later if you want :)
USB is not neccessarily needed for hot-swapping either, depending on what controls you have (although it does help).
JoeB
  • Last login:December 04, 2025, 08:49:00 am
  • NES Fanatic
« Reply #14 on: February 26, 2004, 03:58:20 pm »
I'm confused about the problem with vertical monitors.. is it because all vertical monitors are really horizontal monitors put on their side, with the game boards configured to flip the video 90 degrees internally??
As far as arcadeVGA goes.. I think it's as important as getting MAME.EXE to run, if not more for arcade monitor owners!
