Author Topic: 4way 8way switchable sticks? (SNES/NES)  (Read 2131 times)
impetus_maximus
  • Last login:March 16, 2021, 01:54:52 pm
« on: March 15, 2021, 05:25:18 pm »
hello,
i recently played Pack-Man championship edition on the NES (AVS).  :applaud:
i've gone from wanting a custom joystick, to NEEDING one. D-Pad won't cut it.
the plan is to make a custom joystick housing out of 3/8" birch plywood. i'm wanting a stick that can swap between 4 and 8 way switching as i want it for shmups as well.
i'm looking at the Industrias Lorenzo (iL) magnetic joystick. you can pull the stick outward and switch between 4 and 8 way gates.
i've read it's fantastic for 4 way, but 8 way not so much as the corners can be hard to hit accurately.
i know Sanwa sticks are all the rage for fighters, but short throw i think more fits my games/play style.
i'd prefer not to need to open the box to switch, but if i could push a lever etc without tools, that would work.
servos etc are out of the question.
if there is no good 'all around' solution, what are good 8 way, and 4 way only sticks? i don't mind paying $25+ a stick.
thanks for reading.  :cheers:
/max
Scotty
  • Last login:May 01, 2025, 09:16:56 am
Re: 4way 8way switchable sticks? (SNES/NES)
« Reply #1 on: March 15, 2021, 08:03:40 pm »
If you are going to do it, do it right.  Get the Ultimate 360 from Ultimarc.  Analog, 4-way, 8-way, 4-way diagonal, 2 way...  whatever you need.  This thing is incredible.  I had to get a second one.   Pricey, but so worth it.  Never thought I would spend that much on a stick, but I ordered a second one the next week.  NOTE:  ALSO ORDER THE STIFFER SPRING!!!!!!!
impetus_maximus
« Reply #2 on: March 15, 2021, 08:32:41 pm »
thanks Scotty, i'll check em out.
question, how do you have it wired? i'm going to be using resistors and a couple of 4021 ICs for NES/SNES use.
can this function the same as one with mechanical switches? the docs are a little confusing to me.
cheers
circusfreak
  • Last login:January 10, 2024, 03:00:21 pm
« Reply #3 on: March 15, 2021, 09:12:25 pm »
The U360s are connected via USB as a gamepad in windows.
Like Scotty said, get the stiffer spring AND the circular restrictor for it. Those 2 items are pretty much necessities for these sticks IMO.
impetus_maximus
« Reply #4 on: March 15, 2021, 09:15:26 pm »
thanks circusfreak. USB and windows is a no-go for me. i'm hooking up to real(ish) NES/SNES hardware (FPGA AVS, and Super Nt).
  • Last login:Today at 12:45:41 pm
« Reply #5 on: March 15, 2021, 10:01:51 pm »
You might want to consider these two options.
1. https://www.ultimarc.com/arcade-controls/joysticks/servostik/
- Not sure how much current the servo draws while switching -- might be more than the NES/SNES controller connector can supply.   :dunno
- Can be switched in standalone configuration (no PC) using using two buttons or a toggle switch.
2. https://www.ultimarc.com/arcade-controls/joysticks/mag-stik-plus/
P.S. Are you sure you need a 4-/8-way switchable stick for NES/SNES?
Seems like any 4-way game ported to those platforms should be fairly tolerant to using a 8-way stick since the controller D-pad can hit diagonals just like an 8-way stick.
« Last Edit: March 15, 2021, 10:22:19 pm by PL1 »
impetus_maximus
« Reply #6 on: March 15, 2021, 11:40:24 pm »
Scott,
thanks for the suggestions. the Mag-Stik plus looks like a Industrias Lorenzo i was considering with the bonus of not having to open the box to switch.
i can't find documentation on the mA draw limit on SNES/NES 5V line, or the clone hardware i'm running so i'm going to avoid servos to be safe.
as for needing 4 way, i'm not sure. the NES/SNES Capcom fight stick i own has a 4/8 switch.
i've heard pac-man does weird things with diagonal inputs. weather that is present on the version i'm playing, not sure either.  :dunno
i'll have to play around with it and see. unfortunately when i bought the Capcom stick used at Funco Land, it didn't have the NES chord included.
been planning on wiring some SNES extension chords with NES ends so i can use my Super Famicom controllers on my AVS (NES FPGA clone)
i better get on that,  then i'll play around with the 4/8 switch.  :blah:
regardless, i'm still considering the short throw Mag-Stik/iL for my build. perhaps ripping the guts out of my Capcom stick for added features.  >:D
i never liked the long throw of that stick, the buttons, and button layout are horrible IMO.
thanks again  :cheers:
/max
