Author Topic: Custom Midway/Namco Cabinet - Geeky Question  (Read 7810 times)
Denicio
  • Last login:April 05, 2021, 03:13:51 pm
« on: March 15, 2021, 05:18:26 pm »
So i am getting closer and closer to pulling the trigger on this guy.
https://www.classicarcadecabinets.com/ms-pacman.html
Found a local wood shop that will cut this for around  120.00 of CNC time.  The geeky question i have is as it relates to the monitor mount and the wood panel that holds the speaker and marquee.
HOW will i know where to put that in 'virgin' wood? The CNC shop will make the cuts but will these plans leave any markings as to where to mount (glue) those braces for the marquee, speaker and monitor?
I assume the poor mans solution is to simply print the PDF in its full size, line it up and trace it on to both sides of the cabinet.  Is this the best way?
What would you do?
  • Last login:June 19, 2025, 11:24:08 am
Re: Custom Midway/Namco Cabinet - Geeky Question
« Reply #1 on: April 02, 2021, 01:16:56 pm »
I think with something like this there will be a fair amount of figuring it out as you assemble.  If you are looking for an IKEA like experience where you just take the cut pieces home, glue them up and you are all set I don't think that is realistic.
