Author Topic: LED Buttons  (Read 1544 times)
superpie
  • Last login:March 07, 2021, 05:05:16 am
LED Buttons
« on: March 07, 2021, 05:05:16 am »
Hello all! I had a question I was hoping someone could assist with. I am building a control panel prop for a small movie I am working on. My plan is to use about 25 of  these https://www.amazon.com/uxcell-Button-Rectangle-Illuminated-Switch/dp/B07WQTMRHF - I only wish to show interactivity—I need these to light up when pushed and nothing more. My question is - what is the best way to go about this method? I don’t really know what I need to accomplish this; based on some of the info I’ve taken from here, it seems like I might have to build a fully functioning arcade control in order to accomplish this? Any info you can provide would be GREATLY appreciated :)
  • Last login:Today at 05:29:30 pm
Re: LED Buttons
« Reply #1 on: March 07, 2021, 06:48:00 am »
Good news:  You aren't the first one to ask a question like this.   ;D
Check out WannabeJoy's build thread.
http://forum.arcadecontrols.com/index.php/topic,151577.0/all.html
It's full of detailed advice on how to do what you're trying to do including schematics, product links, how to print custom inserts for the LED buttons, add an inexpensive (<$25) no-programming sound board that interacts with the buttons, and use a USB battery pack in case you don't have power on location for your shoot.
The buttons you linked to should work just fine.
The LEDs are rated for 12v, but will light well with 5v.
- If you power 25 LEDs with 12v, they will draw about 20mA each. (25 LEDs * 20 mA = 500mA = 0.5 Amps)
-- You can use a wall-wart power adapter rated for at least 750mA or an arcade-style switching power supply if you want 12v for LEDs and 5v for the sound board.
- If you power the LEDs with 5v, they will draw considerably less current. (less than 200mA IIRC)
-- A USB battery pack like WannabeJoy's will be fine for this. (The battery pack link in her thread is broken, but you can use this one instead.)
For four of the six schematic configurations that you can choose for each button, you will need to buy standard microswitches with 3 tabs. (COM - common, NO - Normally Open, and NC - Normally Closed)
- They are cheap and plentiful.
If you have any questions, please feel free to ask.   :cheers:
JRobATL
  • Last login:September 27, 2022, 10:20:34 am
  • Completed - Tron Legacy
    • forum.arcadecontrols.com/index.php/topic,162637.0.html
Re: LED Buttons
« Reply #2 on: March 08, 2021, 09:18:09 pm »
This is why Scott gets paid the big bucks.
