Author Topic: iPac Ultimate i/o - LED issues  (Read 2281 times)
asadrian
  • Last login:November 30, 2025, 11:13:47 pm
« on: February 20, 2021, 01:44:52 am »
Hi everyone,  new here but building my second table top arcade controller.   First was cheap ebay buttons and joysticks but enjoyed building and using.  Nephews love it.  So going up a level with ultimarc products, Ultimate i/o, led buttons, trackball,etc.
All the buttons work and have everything programmed and working in Launchbox and Bigbox.  Running a Win10 machine.  I am having strange issues with LEDs.  One button is stuck on green.  And NO LED power plugged in!!!  I also was messing with LEDblinky and plugs 1 -16 did nothing and 17 on worked as they should.  Again.....NO power connected to LED plug.
When I plug in LED power, I don't get anything.  The default LED program does not work.
I am very confused.  The LED plugs are all straight forward and not sure how I could have messed those up.  I'm at a loss.  Tried power from USB.  A 5v wall plug.  Tested the led's and they work from being wired directly to power.  So it is something in the board I am guessing?
Thoughts or ideas would be appriciated....
Sent from my SM-G991U using Tapatalk
lrdfoo
  • Last login:February 26, 2021, 02:50:22 pm
Re: iPac Ultimate i/o - LED issues
« Reply #1 on: February 22, 2021, 10:51:25 pm »
I'm by no means a pro at this... I'm using the same board with a pi 4 setup. I'm powering my LED's with a wall wart plug that i bought that is plugged into the I-PAC.  how are you supplying power to the board?  is it supplying enough power to the board?
asadrian
« Reply #2 on: February 23, 2021, 12:12:49 am »
Thanks for the reply.
I've tried every way I can think of except a direct plug.  Have an adaptor to the computer power plug (forgetting the name) to a USB.  Plugged USB into computer and into a wall plug (5V).  Split a USB cable to get the two power wires and tried connecting to the power cable included with the board.  All nothing.
And tested all options with the buttons to confirm I was getting power and all turned on directly wired.
All that said, I get the lights to work in certain pins with out any power supplied to the board on the LED plug.
I am hoping it is something with the board.  Andy with Ultimarc got back to me and is sending a replacement.  Fingers crossed.  I don't know what else it could be.
lrdfoo
« Reply #3 on: February 23, 2021, 09:21:54 am »
I hope that works!
Mine works but I’m using a pi 4 and can’t seem to get a program to work that will tell the board to turn the lights on.
asadrian
« Reply #4 on: February 23, 2021, 11:44:25 am »
Me too....so far both Ultimarc and LEDBlinky customer support has been outstanding.  Recommend them to anyone getting into this.  I tried everything I could think of before reaching out, but both were quick to offer advice, solutions and in ultimarc's case, drop a replacement in the mail when the issues sounded out of the norm.
