Author Topic: U-HID Nano vs Mini-PAC 'inputs'?  (Read 3764 times)
sdrob04
  • Last login:February 18, 2021, 02:12:50 pm
« on: February 14, 2021, 03:29:37 pm »
Just hoping for some clarity on the U-HID Nano, which is said to have "8 inputs/outputs".  In real-world terms, does this mean one would get a 4/8 way joystick + 4 additional buttons, and that's it?  If so, I'm curious to know how are people using the Nano.  I'm working on a bartop build which will likely have at least 7 or 8 'play' inputs (joystick + 3-4 buttons) and hopefully a few admin buttons, and wanted to ensure that choosing the Mini-Pac made the most sense.
  • Last login:Today at 09:39:01 pm
Re: U-HID Nano vs Mini-PAC 'inputs'?
« Reply #1 on: February 14, 2021, 04:49:28 pm »
That would use all eight of the available inputs.
- Ground for those eight switches is provided by the other pin.
One common use is as an analog (potentiometer) encoder for 270 degree steering wheels and analog pedals.
There are a variety of encoders that would work for that no-spinner, no-trackball setup.
The most sensible choice depends on your ability to strip wires, crimp Quick Disconnects (QDs), solder, and load a firmware on an Arduino.
  "I can't do any of those things." -- MiniPac (regular, not opti) if you want a keyboard/gamepad/mouse button hybrid encoder or a "Zero Delay" encoder if you want a far less expensive gamepad-only encoder.
  "I can strip wires and crimp QDs." -- IPac2, KeyWiz, etc.
  "I can strip wires, crimp QDs, and solder." -- KeyWiz40-Eco or GP-Wiz40 ECO.
  "I can do (or learn) all of those things." -- A very inexpensive Arduino Pro Micro running a keyboard or gamepad encoder firmware.
sdrob04
« Reply #2 on: February 18, 2021, 02:12:50 pm »
Great summary and you provided a few options I was unaware of.  Thanks, PL! :)
