Author Topic: Mini Galaga UPDATE 9/21  (Read 7127 times)
crashwg
« on: February 23, 2004, 11:14:37 am »
I'm currently building a 4' tall galaga, with a few modifications...
The control panel will of course have more to it than the original, including 7 player & ?admin/coin buttons and a 2
« Last Edit: September 21, 2004, 11:02:24 pm by crashwg »
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
crashwg
Re:Mini Galaga
« Reply #1 on: February 23, 2004, 11:17:17 am »
Here are my plans.  Notice my resoursfulness with the 8
Lemme say it again
crashwg
Re:Mini Galaga
« Reply #2 on: February 23, 2004, 11:20:20 am »
I've managed to squeeze most of the material needed out of 1 97x49 sheet of  MDF.  I also needed a 2'x4'x
Lemme say it again
crashwg
Re:Mini Galaga
« Reply #3 on: February 23, 2004, 11:22:36 am »
this one is aproximatly where the mdf will be cut, not much more to explain...
Lemme say it again
crashwg
Re:Mini Galaga
« Reply #4 on: March 11, 2004, 06:33:58 pm »
It's been three weeks since I started this project and I haven't made much progress.  Matter of fact, I didn't do anything over the past few weeks.  But what I did do was cut out the the sides and install some strapping (not quite sure that's what you call it).  I also got the monitor that will be going into this cab, it's a 17" pc monitor, nothing special.
Well, here's the pictures.  I think I'll call it moviepropcab for a while  :P
« Last Edit: March 11, 2004, 06:35:18 pm by crashwg »
Lemme say it again
crashwg
Re:Mini Galaga
« Reply #5 on: March 11, 2004, 06:35:47 pm »
another
Lemme say it again
crashwg
Re:Mini Galaga
« Reply #6 on: March 11, 2004, 06:36:10 pm »
last one
Lemme say it again
dirt
  • Last login:October 30, 2024, 08:36:38 pm
Re:Mini Galaga
« Reply #7 on: March 11, 2004, 07:01:59 pm »
looks like that is going to be a cool cab. i like it.
dirt
WANTED: NINTENDO CABINETS WORKING OR NOT
CitznFish
  • Last login:November 13, 2024, 01:18:45 am
  • www.subvertcity.com - Prof. Strength Slackwear
Re:Mini Galaga
« Reply #8 on: March 11, 2004, 08:04:07 pm »
I dunno, I think it looks a little thin in the last image. Will a monitor fit?  ;D
Stingray
Re:Mini Galaga
« Reply #9 on: March 12, 2004, 09:09:26 am »
LOL @ CitznFish!
The overall shape looks nice. I look forward to seeing it progress.
-S
patrickl
  • Yo momma llama
    • PocketGalaga
Re:Mini Galaga
« Reply #10 on: March 12, 2004, 02:42:30 pm »
Hmmmmmmmm ... Galaga ...    *drewls*
pathdoc2
  • Last login:January 11, 2006, 08:49:53 pm
  • Your friendly pathologist
Re:Mini Galaga
« Reply #11 on: March 15, 2004, 12:11:48 pm »
Your construction tecnnique looks exactly like mine and I always put the 2 sides together to make every thing lines up.  Nice work.
crashwg
Re:Mini Galaga
« Reply #12 on: June 02, 2004, 11:33:23 pm »
Well, it's been about 7 weeks now since I have kept you all updated on my progress.  Mostly because there hasn't been much...  :P  Infact, I pretty much stoped working on it for about 6 weeks.
So here's what I've done:
Assembled the bottom and attached it
Attached the top and kickplate
Sanded, painted and attached the hinge for the CP
Attached the two pieces that will be the CP to eachother
Rounded over the edge of the CP
Attached back door
Attached locking mechanisms to back door
well, I guess that's about it for now
A few things I will probably do in the next week or so are:
Remove back door hinge, sand & paint it
Trim CP about 1/16" so it fits right
Order t-molding & slot cutting bit
Figgure out how I'm going to mount the monitor
Fit trackball and joystick onto CP and coutersink them both
Finalize button design and drill holes
I think I should be ready to paint it if I complete the list above, even though some stuff will not necesarrily (sp) be attached.  We'll see...
Ok, here's some pics now.
Lemme say it again
crashwg
Re:Mini Galaga
« Reply #13 on: June 02, 2004, 11:40:02 pm »
Here's the big picture, with yard stick for size comparison.
Lemme say it again
crashwg
Re:Mini Galaga
« Reply #14 on: June 02, 2004, 11:43:20 pm »
and here's a close up of the CP, which is not attached yet as it is a little too tall.  notice the super awesome curve on there... The way I had to do that was rip the corner off and sand it by hand because the angle is more than 90
Lemme say it again
crashwg
Re:Mini Galaga
« Reply #15 on: June 02, 2004, 11:44:27 pm »
Well, my camera died... so no more pics tonight  :( maybe I'll post some more tomorrow.
Lemme say it again
dmsuchy
  • Last login:August 29, 2025, 01:27:50 pm
  • I kill communist llamas for fun.
Re:Mini Galaga
« Reply #16 on: June 03, 2004, 11:30:39 am »
Looks great! Is your CP on piano hinge?
crashwg
Re:Mini Galaga
« Reply #17 on: June 03, 2004, 04:48:14 pm »
YUP!
Piano hinge for CP and back door.  CP will flip down for easy access to wiring & such.  It will be held down with two screws, one at each of the top corners.
« Last Edit: August 03, 2004, 11:41:39 am by crashwg »
Lemme say it again
AlanS17
    • AlanS17
Re:Mini Galaga
« Reply #18 on: June 03, 2004, 06:03:20 pm »
I would suggest some sort of clamping system over screws (or even velcro for that matter) because mine used screws and over time it finally stripped out the holes... Those things can only be re-inserted so many times before they start to slide right back out.
crashwg
Re:Mini Galaga
« Reply #19 on: June 03, 2004, 07:08:11 pm »
I should rephrase that I guess...
Bolts, not screws, is what I will be using.  I think probably some sort of pan-head bolt with maybe a hex head.  And for the corasponding side ?t-nuts?, I haven't figured that part out yet.  ;)
Lemme say it again
Re:Mini Galaga
« Reply #20 on: June 04, 2004, 06:37:48 am »
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:June 16, 2025, 09:16:27 pm
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
Re:Mini Galaga
« Reply #21 on: June 06, 2004, 09:21:10 pm »
Looking good! I did look at this before, but couldn't picture it when we were talking about it at the get-together. You need to get her playing that thing as soon as possible, mould a future champion for the FunSpot tournament!
patrickl
  • Yo momma llama
    • PocketGalaga
Re:Mini Galaga
« Reply #22 on: June 13, 2004, 07:07:15 pm »
Acids
  • Last login:July 26, 2025, 06:10:07 am
  • Bring It.. Smart arse!
Re:Mini Galaga
« Reply #23 on: June 14, 2004, 04:12:15 am »
crashwg
Re:Mini Galaga
« Reply #24 on: September 21, 2004, 10:45:45 pm »
In case you haven't noticed by now, I'm working on this project rather slowly for some reason or another.  Usually it's just because I don't realy feal like it or I don't wake up early enough in the day to get some good outside work done before the sun goes down.
It's been painted for about 2 months now, I probably should have taken pictures and posted them before, but I never got arround to it.  Oh yea, and it's had t-molding for about the same amount of time.
The control panel has been routed and drilled to accept the mounting plates for both the t-stick and 2
Lemme say it again
crashwg
Re:Mini Galaga
« Reply #25 on: September 21, 2004, 10:47:06 pm »
Another
Lemme say it again
crashwg
Re:Mini Galaga
« Reply #26 on: September 21, 2004, 10:49:21 pm »
and another... check out the piano hinge on the left side of the back door.  Oh yea!
Lemme say it again
crashwg
Re:Mini Galaga
« Reply #27 on: September 21, 2004, 10:52:36 pm »
here's the CP with the mounting plates and the base of the t-stick installed.  Yes there's a piece of paper towel stuck in the joy hole, it's there because I couldn't remove the base of the stick when I primed it.
Lemme say it again
crashwg
Re:Mini Galaga
« Reply #28 on: September 21, 2004, 10:59:56 pm »
Here's the monitor that will be going in the cab.  I drew on the pic to illustrate where the piece on the side will be cut off, the approximate location of the speaker holes and also the supports I added for the monitor's PCB.
In case you're wondering, yes I am a little worried about the PCB's supports but it seems to hold up pretty well as it has been tied to that chair like that for a couple weeks now...
Lemme say it again
crashwg
Re:Mini Galaga UPDATE 9/21
« Reply #29 on: September 21, 2004, 11:08:56 pm »
And to answer your question partricl...  I wanted the front part of the cp to follow the outward angle of the cab but if I did it with a 90
« Last Edit: September 21, 2004, 11:11:51 pm by crashwg »
Lemme say it again
AGGIEZ
  • Last login:January 30, 2017, 05:59:50 pm
« Reply #30 on: September 22, 2004, 10:51:07 am »
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #31 on: September 22, 2004, 11:37:10 am »
Re:Mini Galaga
« Reply #32 on: September 22, 2004, 11:45:04 am »
Heh, I know the feeling.  I've clocked up 50-odd days on my cab, but most of those 'days' were probably an hour or 2.  Full-time jobs, alcohol and working in a shed several miles away don't help.  Not to mention UK winter weather  :(
Your cabs looking good now tho, get on with it and finish it! :)
crashwg
« Reply #33 on: September 22, 2004, 05:36:39 pm »
Or did you just not like the standard 15 degree CP angle (from the kickplate or 13 degrees from the front of the sides) of the regular cab?
I had two sets of plans that were quite different so I kinda winged it.  The plans, seen in post #2, were pretty much free handed with the help of a yardstick and a string (for the radii).
Lemme say it again
