Author Topic: GreenAntz RGB to component transcoder  (Read 157053 times)
Zebidee
  • Trade Count: (+9)
  • Last login:Today at 01:41:36 am
Re: GreenAntz RGB to component transcoder
« Reply #80 on: June 05, 2024, 04:04:57 pm »
That's very impressive work Naponic! Can you share the file when complete?
How do you go with getting the VGA/USB/3xRCA ports into those holes? I imagine it's a tight fit. Does the plastic have a bit of flexibility to make that easier?
FYI, the GreenAntz PCBs are the same size across different versions, and the ports and mounting holes are all in the same places.
The PCB design/layout accommodates at least 1.5mm clearance along the short sides, meaning a box design could be a shaped hollow tube with C-shaped slide guides on left/right sides. The PCB just slides in, like a drawer. I imagine this would be easy to design and print. Then just add flat faceplates (with holes for ports & screws) front and back. The new sync LED intrudes upon that clearance slightly, but still leaves > 1mm free.
Ond & Daniel seem to be working on something too. I don't know how far that's gone? I imagine Ond is pretty busy with his virtual pinball project & other stuff.
I have no 3D printing skills! Sure I'd love it though, as obviously I enjoy creative modelling/design stuff.
  • Last login:July 10, 2025, 08:06:51 am
« Reply #81 on: June 05, 2024, 06:01:58 pm »
I considered drawing up an enclosure but as Naponic is now working on it I'll let it be for now. Personally I have no real need for one myself as I'm just mounting them inside the cabinet on standoffs.
  • Last login:Today at 04:20:24 am
« Reply #82 on: June 05, 2024, 06:16:47 pm »
You don't.
For a top and bottom cover design, the seam between the top and bottom should probably pass through the center of the RCA jacks.
The VGA port hole has flat sides so no problem there.
The USB connector should be shallow enough to slide inside the case or have the seam between the covers dip down at that connector with a little additional reinforcement on the top cover for the part that sticks down.
Another feature to consider adding is wire holes for the alternate power supply terminals mentioned here.
That's one possible approach, but the hard part about it is the hardware for attaching the covers.
Here's a preliminary design I did a while back for the KADE MiniConsole+ that could be easily adapted for GreenAntz.
- The hole in the "diving board" tab lines up with the mounting hole on the other cover.
OpenSCAD code if anyone wants to play around with it.
Code: [Select]
// KADE miniConsole+ case (WIP)
// Variables are estimates -- awaiting accurate measurements.  Port openings have extra wiggle room.
// Define variables
screwdiameter = 4;    // Screw hole diameter
PCBwidth = 60;        // PCB width
PCBlength = 80;       // PCB length
PCBthick = 1.8;       // PCB thickness
componentheight = 22; // Component height
USBoffset = 10;       // Distance from PCB edge to USB
RJ45offset = 8;       // Distance from PCB edge to RJ45
DSUBoffset = 9;       // Distance from PCB edge to left side of D-Sub15
SecHalfMove = 60;     // Y-axis distance to move the second half of the case
// Number of fragments (polygon sides) used to render a full circle.
    $fn = 180; // Default = 180  Typical range = 6 - 360
    // 6 will render a circular hole as a hexagon, 8 will render a circular hole as an octagon.
    // Lower the number for faster rendering, raise the number for smoother rendering.
//  Make the part
// RJ-45 and USB side of case
difference(){ // Case body minus hollow, PCB slot, RJ-45 and USB holes
    // Case body
    hull() {
    translate([PCBwidth+14, 8+PCBthick+componentheight, 1+PCBlength/4])
    cylinder(h=2+PCBlength/2, d=4, center=true);
    // Upper right cylinder
    translate([14, 8+PCBthick+componentheight, 1+PCBlength/4])
    // Upper left cylinder
    translate([PCBwidth+14, 2, 1+PCBlength/4])
    cube([4,4,2+PCBlength/2], center=true);
    // Lower right cube
    translate([14, 2, 1+PCBlength/4])
    // Lower left cube
    } // End case body
// Holes to remove from case
    // Upper hollow
    color("green") translate([14+PCBwidth/2, 6+(PCBthick+componentheight)/2, 5+PCBlength/4])
    cube([PCBwidth-6,PCBthick+componentheight,5+PCBlength/2], center=true);
    // Lower hollow
    color("green") translate([14+PCBwidth/2, 4, 5+PCBlength/4])
    cube([PCBwidth-6,3,5+PCBlength/2], center=true);
    // PCB slot
    color("white") translate([14+PCBwidth/2, 4+PCBthick, 5+PCBlength/4])
    cube([PCBwidth+0.2,PCBthick,5+PCBlength/2], center=true);
    // USB hole
    color("blue") translate([7+PCBwidth-USBoffset, 9.7+(PCBthick*1.5), 5])
    cube([14,12,12], center=true);
    // RJ45 hole
    color("brown") translate([22+RJ45offset, 11.7+(PCBthick*1.5), 5])
    cube([16,16,12], center=true);
     } // End case body minus hollow, PCB slot, RJ-45 and USB holes
difference(){ // Left mount tab minus screw hole
    // Left mount tab
    translate([6, 1.5, 1+PCBlength/4])
    cube([12, 3, 2+PCBlength/2], center=true);
    // Screw hole
    translate([6, 2.5, (2+PCBlength/2)-(PCBlength/2-8)])
    rotate([90, 0, 0])
    cylinder(h=10, d=screwdiameter, center=true);
} // End left mount tab minus screw hole
difference(){ // Right lower mount tab minus screw hole
    translate([22+PCBwidth, 1.5, 1+PCBlength/4])
    // Screw hole
    translate([22+PCBwidth, 2.5, (2+PCBlength/2)-(PCBlength/2-8)])
    rotate([90, 0, 0])
} // End right lower mount tab minus screw hole
difference(){ // Right upper mount tab minus screw holes
    translate([22+PCBwidth, 4.5, 2+PCBlength/2])
    cube([12, 3, 4+PCBlength], center=true);
    // Screw hole 1
    rotate([90, 0, 0])
    // Screw hole 2
    translate([22+PCBwidth, 2.5, (2+PCBlength/2)+(PCBlength/2-8)])
    rotate([90, 0, 0])
} // End right lower mount tab minus screw holes
// DSub15 side of case
difference(){ // Case body minus hollow, PCB slot, and DSub15 hole
    // Case body
    hull() {
    translate([PCBwidth+14, 8+PCBthick+componentheight+SecHalfMove, 1+PCBlength/4])
    translate([14, 8+PCBthick+componentheight+SecHalfMove, 1+PCBlength/4])
    translate([PCBwidth+14, 2+SecHalfMove, 1+PCBlength/4])
    // Lower right cube
    translate([14, 2+SecHalfMove, 1+PCBlength/4])
    // Lower left cube
    } // End case body
    // Upper hollow
    color("green") translate([14+PCBwidth/2, 6+(PCBthick+componentheight)/2+SecHalfMove, 5+PCBlength/4])
    // Lower hollow
    color("green") translate([14+PCBwidth/2, 4+SecHalfMove, 5+PCBlength/4])
    // PCB slot
    color("white") translate([14+PCBwidth/2, 4+PCBthick+SecHalfMove, 5+PCBlength/4])
    // DSub15 hole
    color("blue") translate([-6+PCBwidth-DSUBoffset, 10.7+(PCBthick*1.5)+SecHalfMove, 5])
    cube([40,14,12], center=true);
     } // End case body minus hollow, PCB slot, and DSub15 hole
    // Left mount tab
    translate([6, 1.5+SecHalfMove, 1+PCBlength/4])
    // Screw hole
    translate([6, 2.5+SecHalfMove, (2+PCBlength/2)-(PCBlength/2-8)])
    rotate([90, 0, 0])
    translate([22+PCBwidth, 1.5+SecHalfMove, 1+PCBlength/4])
    // Screw hole
    translate([22+PCBwidth, 2.5+SecHalfMove, (2+PCBlength/2)-(PCBlength/2-8)])
    rotate([90, 0, 0])
    translate([22+PCBwidth, 4.5+SecHalfMove, 2+PCBlength/2])
    // Screw hole 1
    rotate([90, 0, 0])
    // Screw hole 2
    translate([22+PCBwidth, 2.5+SecHalfMove, (2+PCBlength/2)+(PCBlength/2-8)])
    rotate([90, 0, 0])
} // End right upper mount tab minus screw holes
Naponic
  • Last login:June 13, 2024, 11:07:06 am
« Reply #83 on: June 05, 2024, 07:07:00 pm »
Made the case see-through so I can see what I'm doing... doesn't look bad lol.
Made the holes in the middle so there's no wedging of anything. Drop, screw, and go. Still mostly visual guesswork and tape measuring clearances, I need digital calipers. Downloading random circuit parts from GrabCAB and double checking IRL has saved a lot of time.
« Reply #84 on: June 05, 2024, 08:14:58 pm »
Looks great, Naponic.   :cheers:
Two other features you might want to add are a hole for the optional alternate power wires mentioned here and two holes so you can see the LEDs.
Yep.  Digital or dial.  Both are great choices.
Vernier calipers suck.  :puke
EDIT: Forgot to mention that another case variant to consider is for the SCART version with audio jacks mentioned here.
« Last Edit: June 05, 2024, 08:42:53 pm by PL1 »
Zebidee
  • Trade Count: (+9)
« Reply #85 on: June 05, 2024, 11:10:43 pm »
Thanks so much for the suggestions Scott. Yes, SCART... and console users are more likely to want SCART, therefore more likely to want a box (as it will likely be going near a TV in a games room, not inside a cab).
BYOACers almost all want VGA versions, I haven't even built any V1.94 units in SCART form yet. I haven't promoted the latest versions past BYOAC. But once I include the everyone else (y'know, non-members), overall maybe 20-25% of people want SCART, so important to include them.
FYI, the installed SCART jack measures 16mm high x 47mm wide (top); 44.5mm wide (bottom). Those width measurements are taken from the outsides of the curved corners. The white lines marked on PCB show the correct footprint and precisely line up with where the SCART jack goes.
The extra audio passthrough RCA jacks (red & white) are the same height and same diameter as the YPbPr jacks (you can hold a ruler up and it goes through the middle of all five jacks). They are all spaced apart by approximately the same amount too (~14mm). The only difference is the audio jacks don't stick out quite as far, are about 2mm shorter than the YPbPr jacks. Again, the white lines marked on the PCB footprint show the correct placement.
Those measurements are taken with a metal ruler & eyeballs, not calipers of any kind, but I took them many times.
Holes for LEDs might not work, as much of the light would be dispersed before even reaching the holes. Extending the LED legs is not a very practical option. One way to do it would be with optic fibre tubing, which would capture the light and direct it (mostly) toward the hole. Sounds fussy and expensive, but maybe not, I really don't know.
EDIT: a little online searching reveals fibre optic tubes are actually not very expensive. Even so, I'm not sure how well they'd work, some testing would be required. The GreenAntz 3mm "bright" LEDs run much dimmer than their actual ratings, drawing less than 1mA each - they only need to be bright enough to see, not to see by, and not bright enough to make you squint or distract from gaming. Generally speaking, green power LED uses a 50K current limiting resistor, and the blue sync LED uses a 10K resistor (these values are only indicative - actual colours and resistor values may vary).
Transparent case may just be easier.
Thanks again naponic, looking very good.
variaprime
  • Last login:November 13, 2024, 09:49:05 pm
  • See you next mission.
« Reply #86 on: June 06, 2024, 01:43:01 am »
Thank you for all the hard work and updates you've put into this project! Also loving the enclosures I'm seeing above. Sent a PM on purchasing a unit if there are still any spots available. Cheers  :cheers:
« Reply #87 on: June 06, 2024, 02:57:20 am »
If the datasheet for the connector doesn't show the radius of the curved corner, the tool you need to measure the curve is called a fillet gauge.
- There are lots of 3d printable models of them on Thingiverse or you can make custom ones like I did here.
"Transparent" 3d print filament is usually just somewhat translucent so dim LEDs might be hard to see unless the case is so thin that it it will be too weak.
- My 3d printer came with a sample of translucent PLA.  Printed some parts for PBJ with it.  They turned out OK for his setup, but it was far from transparent.
If I was modding a case like Naponic's for LED holes, I'd put in 45 degree funnel-like holes (6mm i.d. hole at the bottom) that stopped just a bit above the 3mm LEDs.
- This gives you fairly good viewing angles, almost all printers should be handle a 45 degree overhang, and you don't have to worry about special filaments or light pipes.
- Bonus points for the holes looking like the entrance to an ant hill.   :lol
Many people won't want to buy a 1000g roll of specialized filament just to print a single 100g(?) case.
Probably better to design a case that works with any type of filament.   ;D
Zebidee
  • Trade Count: (+9)
« Reply #88 on: June 06, 2024, 06:27:52 am »
All good point Scott. I really don't know 3D printing, and I'm sure what you say about transparent stuff is true. Not sure I'd like funnel-holes for the LEDs though. Am worried that they would have to be pretty long funnels, around 1cm or longer, to get down to the LEDs. On the other hand, maybe that would look fine.
I'm thinking some 3mm optic fibre tube, or maybe a bit wider, and a bit of removable white heat-shrink over the LED end, and the other end glued into a custom hole in the case. When installing into the case, you'd need to slip the heat-shrink caps over the LEDs. I've seen similar in PC case designs for power/HDD LEDs, even some pretty old ones.
Anyway, the point of 3D custom printing is that people can modify to their own tastes. A good basic shell is a great place to start. No need to get caught up in the fiddly details too much (yet).
Naturally, I'm also thinking ahead to the next stage where I'm getting making cases made in quantities and sold as an optional extra.
bobbyb13
  • Last login:Yesterday at 07:34:18 pm
« Reply #89 on: June 27, 2024, 03:16:23 am »
I'm still failing to make time for this fun stuff but I'm stoked to see this continue while I only have time to watch occassionally!
« Reply #90 on: July 04, 2024, 10:48:16 pm »
I'm away travelling right now, but thinking about printing off a cover when I return - if no one else does?
Zebidee
  • Trade Count: (+9)
« Reply #91 on: July 04, 2024, 11:23:46 pm »
Yes, do it!
Naponic has done some cool designs, but having printer/filament issues.
If we can come up with one or more "proofable" designs I can host them on my google share.
« Reply #92 on: July 05, 2024, 02:32:25 am »
No worries Zeb, right now I'm  in Asia myself. In a week or so we'll work together on it.
« Last Edit: July 05, 2024, 03:29:08 am by Ond »
« Reply #93 on: July 16, 2024, 11:41:41 pm »
First enclosure prototype is printing.
This version includes a portal for the LED.
There will be a few tweaks and adjustments after the first one, lets see...
Zebidee
  • Trade Count: (+9)
« Reply #94 on: July 17, 2024, 01:12:37 am »
Very exciting!
Your GreenAntz doesn't have the v1.94 sync LED unfortunately.
Would you like to use some proper/original GreenAntz logo art? I can share files with you.
« Reply #95 on: July 17, 2024, 08:43:34 am »
Very exciting!
It was fun designing the case. It's a work in progress now. The first print let me adjust some spacing and fitting issues. I'll play around with the design until I get a print that I'm happy with.  The original artwork would be handy once I have the enclosure model geometry sorted.
« Reply #96 on: July 19, 2024, 01:02:46 am »
I didn't like the boxy first version so I did a more pleasing (to me) curvy version.
Here are the results printed in clear filament:
Some small adjustments for screws to fit, mainly just a slight countersunk size and shape for M3 self tapping screws and maybe a fraction more room around the power cable plug head. Other than that - good to go!  ;D Separate holes for the RCA sockets is not a good idea, there just ain't enough room on that fitting!
Zeb, if you want I can add a logo. Basically just a thinly printed black/green badge would look good.  I recommend a single badge to keep things simple. The Ant head is a good choice. Keep in mind that filament printers don't do fine filigree work or very thin parts too well. Maybe send me a Google drive link for artwork and I'll have a look?
If you want another final sample print in different colors let me know. I get filament way cheaper than most folks so no big deal. Cost for the STL files? Hmm let me see here, my hourly rate is $200US * 5Hrs minus the BYOAC member discount which comes to a total of... $0.00.  Hey, that's cheap!   :laugh2: Ok, I have to get back to some PCB crossover design now.
Zebidee
  • Trade Count: (+9)
« Reply #97 on: July 19, 2024, 02:46:01 am »
Ond, that already looks great!
I too prefer curves in the right places, no need for hard edges/corners. Sure, it is a box, but it doesn't have to look boxy.
So that is how the "clear" comes out - basically a slightly opaque white. But that looks good too, and the power LED is visible through it. Which means the design would also accommodate v1.94 with a sync LED.
I concur with you about the logo too - simple is better. Will assemble a modest zip package of files and PM you the link in next couple of days. You can take what you need from that.
Nice work! Thank you! Love the members price <3
bobbyb13
« Reply #98 on: July 20, 2024, 02:12:12 am »
Great work on that Ond.
Always nice to see the product of someone with a great mind and eye for design.
I'm still trying to catch up on projects among crises here but I'm looking forward to my next raster build!
« Reply #99 on: July 20, 2024, 06:26:45 pm »
Thanks Zeb, yes the artwork would be a nice finishing touch. I've made some final adjustments (see below) after realizing there is in fact room for individual RCA port holes. For some reason I was thinking about the outer plug plastic sheath diameter's not having enough room instead of the metal plug parts.
Thanks bobby, you've become one of my fav builders here. Love your vector AND raster work! I hope you do keep building,  I always find inspiration in your work.
It's just cold here right now so I prefer working on the computer doing design stuff until the weather warms up again and I can get back to cabinet building.
As usual I can't rest up on a project (even a mini one) until I've tweaked it to my satisfaction. I think it is adequate now. I've tested with readily available screws and the GreenAntz board that I have. The printed parts should fit nicely together and screws should go in without needing a torque wrench  :lol The 3D print design should be somewhere near PL1's best practice criteria?
« Last Edit: July 20, 2024, 09:48:38 pm by Ond »
« Reply #100 on: July 20, 2024, 10:16:41 pm »
Great work as always, Ond!   :notworthy:
- That design should print fine on any printer with no supports or raft/brim.
Looks like it would be easy to add four heat-set threaded inserts for the screws that hold the top and bottom together and/or rubber feet (screw through the center, NOT adhesive!  Mouser P/N 534-723 are the best ones I've found, but you might need M4 or M5 hardware) if one were inclined to do so.
The only thing I see that you might consider beefing up is the alignment tabs.  They wil be strong enough once the lid screws are inserted, but are thin enough that they might break if there is some lateral force applied during assembly.  If they were taller, it would definitely be an issue.
To spitball an idea to make the case design a bit more versatile, a sneaky feature that you could add is three holes per LED for people who want to use non-translucent filament for the case.  That would allow the light-pipe idea that Zebidee mentioned earlier through a hole over the LED and mount a separate logo on the other two holes.  Maybe design an alternate logo that mounts over all three holes for people who don't care about the LEDs.   :dunno
« Reply #101 on: July 22, 2024, 07:53:02 am »
Thanks Scott, I've taken your suggestions into consideration. I've added more of the alignment tabs to increase the strength along the seam. I'm open to further refining the design to include some of the other things but I'm also mindful of keeping the parts count to a minimum to make it as accessible to everyone as possible.
Zebidee kindly provided some of his original artwork that went onto the GreenAntz PCB. I've taken the most workable of that in terms of 3D printing and crafted it a bit for a single snap on logo.  Some concept renders to show color combo's:
The logo printed in green with snap on posts:
An example case printed in black with the logo attached.  It's a good tight snap on fit, a bit of glue on each post would make it permanent.
Adding holes for light pipes re: the Sync and power LED is no problem. I'll leave that to Zeb to ponder for a bit. One thing to keep in mind is light pipes are not very effective with low luminescence LEDS. They work just OK with reasonably bright ones.
« Reply #102 on: July 22, 2024, 04:04:31 pm »
The logo looks great.  Exactly how I pictured attaching it to the case.   :cheers:
I figured that the threaded inserts and rubber feet would be optional.
If you add the chamber for the heat set inserts and someone doesn't use them, will the screws still be able to engage well enough or should anyone wanting to use inserts drill the chambers for them?
Agreed.  That and keeping down the parts count is why I suggested the "light funnel" idea earlier.
Perhaps more of a slightly tapered (5-10 degrees?) "light chimney" would be acceptable or maybe add alignment divots on the inside of the case over the LEDs so someone can drill out the holes if they want.
If someone wants to add screw terminals for an alternate power source, do you want to add wire holes or a removable panel?
If you don't want to have the holes on all cases, maybe make recessed alignment divots on the inside of the case so anyone wanting to use this feature can drill them out.  Same for two screwdriver holes in the top so you can tighen/loosen the screw terminals without removing the lid.
Zebidee
  • Trade Count: (+9)
« Reply #103 on: July 22, 2024, 11:14:57 pm »
Ond, the logo inset looks fantastic! You turned that around quickly.
How about ventilation slats or holes? GreenAntz doesn't produce a lot of waste heat, but maybe worth thinking about.
Thanks for your ideas Scott.
My thoughts about the "alternate power" inputs are: Maybe 1/10 people want to use them, they usually aren't much concerned about a case (because it is going into a cabinet of some kind anyway), and a single "alignment divot" on the side would allow them to drill their own anyway (one small hole is all you need for both wires). No holes needed on top for the screw terminals - anybody with a screwdriver can just remove lid of the case to secure the wires, one-time as needed.
Regarding LEDs, I use 3mm "bright" LEDs that throw light "up" more than "sideways". They run with large current limiting resistors (~50K for the power LED, 10K for the sync LED) to throttle the brightness down to something that won't make you blink or squint in a darkened room. They may be bright enough for a light pipe already, but easy for me to use lower values in future for the current limiting resistors too. Retrofitting lower LED resistors (=> brighter) is fairly easy as you can just run an extra resistor under the PCB, though I don't expect many people would do this.
Worth considering a SCART version too - this could be a breakout panel for the larger SCART input, or a modified build. Less demand overall, but people that want SCART often ask about a case as they are more likely to use GreenAntz with consoles in a lounge room style, console + controllers + TV environment.
« Reply #104 on: July 23, 2024, 02:06:35 am »
Vent slats over the LEDs ==> two birds, one stone.   ;D
Sorry, but I'm gonna strongly disagree on this.
Four divots seems like the best choice -- two for the wires and two for jeweler's screwdrivers.
If you only have one hole for the wire, it has to be large enough to cover both screw terminals.
- The only argument I can make for one large hole is if there is a large enough gap between the case and the screw terminals that the wires might veer off course between entering the case and entering the screw terminal.  How big is that gap, Ond?
- Two smaller (3-4mm) wire holes will look cleaner than one large (9-10mm) wire hole and the smaller holes should better serve as a guide when inserting a wire into the terminal.  If so, smaller holes ==> better fit, form, and function.
- Worst case if two small holes don't work, drill them with a 5mm or 6mm bit then use an exacto knife to turn the two holes into an oval.  You'd be cutting parallel to the print layers so it should be easy.
If someone wants to mount the case on a shelf or wall by adding some simple brackets or Z-shaped mounting legs, it would be much more difficult to remove the lid than to have holes for jeweler's screwdrivers.
- If they aren't using heat-set threaded inserts, every time they take the lid off there is a greater chance that the lid screws are going to strip out.
- Having the option to drill screwdriver holes makes the case much more maintenance-friendly.
- Divots are easy and drilling them is optional.  I can make no argument for not including these two divots.
One other thing that would be nice to add on the outside of the case next to where the wire holes would be drilled is small inset "+" and "-" polarity markings.
« Last Edit: July 25, 2024, 02:03:15 am by PL1 »
Zebidee
  • Trade Count: (+9)
« Reply #105 on: July 24, 2024, 01:59:17 am »
Sigh. Oh well  :dunno
Long post here. Better go get your popcorn  :drool
There is quite a gap - 4 or 5mm at least. Though I'm not sure how thick the case plastic is there. Ond made the case large enough to enclose the VGA port next door, which sticks out a bit.
Nobody wants a 9-10mm hole, that would be ugly. Who suggested that? Not me.
The screw terminal centres are 5.08mm apart - so centred 3mm holes would leave approximately 2mm separation. 5mm would leave none.
You win.  :applaud:  Make two divots for top screw holes. Make divots for the wires too. There is no obligation to drill them, guess it can't hurt much, so long as it isn't too ugly.
I believe the use-case is very small. Few people fussy and knowledgeable enough to wall-mount GreenAntz in-case and provide power via alternate input would want to do this, and as designer I would discourage screwing wires into the alt power inputs willy-nilly because of the unnecessary risks (see below).
You really only have to connect the wires once, so ease-of-access to top screws is really not that important.
Here's something deliberately not mentioned before: access to the adjustment pots for luma and Pr. Because mostly you don't *need* to twiddle them, it doesn't really matter that you may have to take the case lid off to do so. That, and I see no reason to make holes (or even divots) that will encourage people to play with them (they will likely only ruin the calibration I painstakingly did on my oscilloscope before sending it out). I consider this an advantage to having a case. I feel the same way, even more so, about the alt power screw terminals.
With that in mind, please consider these things you may have never thought of before:
- IMHO one hole for two wires looks better, is sturdier, safer and more practical than two unsecured twig-thin wires that can be easily pulled out.
- There is no need for the wires to come in right where that screw terminal block is - that hole can be wherever, and wires just run down to the inputs.
- The blue 5.08mm screw terminal connector pictured fits perfectly, but doesn't come as default standard, you have to buy or supply it separately (if you discuss your need and ask when ordering, I'll throw one in for free if I have any spares). Because the spacing is common if unofficial "standard", many PCB connectors would fit. I have two types here, but the blue looks nicer.
- You could also choose to just solder the wires directly into the input holes provided on the PCB, or use some other standard connector. I left this for the tinkerer.
- I'm happy to discourage people from casually connecting wires to the alt power input. Because getting the polarity swapped would likely fry the GreenAntz, or at least the voltage regulator. If you hook up your own non-reversible connector, you both avoid risk and make life easier for yourself.
All of this sours me to the hole idea (pun intended).
I also have to ask (rhetorically),.... Why would anybody go to the effort of wall-mounting GreenAntz in a case, given that by naked default it comes with free PCB offset legs for mounting inside a cabinet? Where you can't see it, and it is already protected from dust? Sure, there must be an edge case, but the numbers would be very small.
Assuming someone wants to do all this anyway, why wouldn't they just put a two-way non-reversible molex connector (or similar) on the wires to make it easy to disconnect? That's exactly what I did myself when wall-mounting a GreenAntz in my own cabinet. Its easier than finding a small screwdriver to unscrew the terminals, having to put your whole head inside the cab and bang it on the CRT neck coming back out (this happened to me twice! Owww!), or accidentally swapping the wires. It even makes cabling less messy. I'm getting older and finding it harder and harder to crawl into tight spaces, so will do anything I can to make life easier.
If I was to do it again, on a GreenAntz with a case, I'd cut a single hole (wherever I please) for both wires and run them through to the inputs, using as much length as needed. I might use a rubber grommet for the hole, maybe a cable tie or something to prevent the wires from being pulled out. Then use an external non-reversible two-way connector. Exact arrangements might vary, but point is that top holes for screw terminals would be unnecessary.
This is safest IMO, as it discourages fiddling with the power inputs and minimises opportunity for someone to get the polarity mixed up. This is a real concern for me, and I've investigated ways to mitigate the risk, but the most obvious solution (putting a schottky diode in series on the 5v input) causes a voltage drop of ~.4v, which is too much for reliable quality operation. There are more complicated solutions, but they will have to wait for future versions.
Here are some well considered thoughts: GreenAntz was designed with arcade tinkerers in mind, so case was never the priority. People that like to tinker are less interested in a case. People that don't tinker are more interested in a case. Strong correlation. I know this because I've sold many units, and while everyone has their own story, it is mostly true. Sure, there are occasional exceptions (like Ond, for example) who want it all, and good on them, but that is what I mostly see. On top of this, only 1/10 people have interest in alt power, more than half of those choose to use USB anyway after I talk it through with them, and NONE of these people have ever expressed special interest in a case. None.
Crunching those numbers leaves me somewhere vanishingly close to zero.
Totally agree - also mark as 5v max input
« Last Edit: July 25, 2024, 05:05:09 am by Zebidee »
« Reply #106 on: July 24, 2024, 05:24:40 am »
I've made one further modification to the enclosure design, that is some ventilation holes at either end as shown;
I will need to leave this as is for a while to turn my attention to other more pressing projects. I'll provide the 3 STL files to Zebidee.
Zebidee
  • Trade Count: (+9)
« Reply #107 on: July 27, 2024, 12:22:53 am »
That looks fantastic! Love the green. Thank you very much Ond for your time and expertise.   :cheers:
As the combined file size is still fairly small, I have simply attached them here as a zip.
No changes have been made. I have not checked the files myself, I assume they are good. If you want to add features yourself, do it.
In terms of legalities: Intellectual property for the enclosure itself belongs to Ond. He's made it for community benefit, so here it is, free for you to use. If you want to do something commercial or otherwise special with it, you'll need to talk to him. However:
The GreenAntz name and head logo, and any elements containing the logo or its parts or their shapes (including the negative space on the lid), may only be used or reproduced for personal purposes that directly relate to an official GreenAntz product originally purchased from myself or my authorised representative. Use of the GreenAntz name and logo etc. for any other purpose, whether commercial, educational, non-profit or whatever, is not permitted. Reproduction in bulk for any purpose is not permitted.
Enough mumbo-jumbo. Enjoy. Please post examples of your 3D printing here 8)
dda1981
  • Last login:September 09, 2024, 06:09:04 am
« Reply #108 on: September 08, 2024, 02:25:44 pm »
Hello from Ohio! How can I purchase this RGB to Component greatness called the GreenAntz! I have this crt SDTV i want to hook my Arcade PCBs to
Zebidee
  • Trade Count: (+9)
« Reply #109 on: September 15, 2024, 12:40:26 am »
Hello Ohio! Sorry, missed your post. Haven't been haunting this forum too closely past couple of weeks.
Normally people PM me - now that you've made a post, you can send PMs.
I have recently finished a small batch so have a small number of VGA GreenAntz units available.
TheArcaveProject
  • Last login:May 16, 2025, 07:46:23 am
  • Here as a collector!
« Reply #110 on: October 30, 2024, 02:56:21 am »
Hello, New to the forum ran into your product looking for this exact solution(needing Jamma CGA to Component!). I will be needing 2 will send you a PM.  :)
Cadams84
  • Last login:April 02, 2025, 11:32:56 am
« Reply #111 on: February 06, 2025, 09:42:50 am »
are you still selling these by chance? I'm looking for something cheaper than the $76 it will cost me to get the Wakabavideo Transcoder. Plus shipping take forever for them to get here. shipping would be to Tennessee if you wouldn't mind giving me an out the door price total!
« Last Edit: February 06, 2025, 09:45:30 am by Cadams84 »
Zebidee
  • Trade Count: (+9)
« Reply #112 on: February 06, 2025, 05:43:29 pm »
Starting 2025, GreenAntz is $50. The GreenAntz and I are in Thailand - Courier to USA is still only $15.
That assumes no additional costs or taxes or delays that may occur due to Trump's current war on imports. Or anything else. So far I think we are unaffected directly (fingers crossed), though it costs us all in one way or another.
I have a couple of VGA GreenAntz units available, so I'll check them over and send you the best one - I'm currently neck-deep in diagnosing CRT TV horizontal deflection issues, so will send on Monday if you don't mind (Friday morning here). From then USPS say 7-10 days, but I'd say ~2 weeks. So, can't promise it'll be any quicker than the one from NZ.
Talk more via PM.
hamadam
  • Last login:April 15, 2025, 07:35:06 pm
« Reply #113 on: April 12, 2025, 06:31:21 pm »
Thanks for doing this and all the information!
Zebidee
  • Trade Count: (+9)
« Reply #114 on: Today at 01:27:15 am »
I found a "bug" with CRT-emudriver's composite sync and the GreenAntz v1.94 composite sync autodetection.
When using CRT_emudriver to generate composite sync (on the H-sync output, VGA pin 13), the driver continues to output normal V sync (VGA pin 14). This makes the sync logic think there is HV sync input, the dual V and composite inputs conflict, and results in an inverted composite sync signal. No stable picture most of the time.
This is not strictly a GreenAntz bug. The issue affects not only GreenAntz v1.94, but also all three of my wakabavideo transcoders and my Bitfunx clonecoder (it is a clone of an early pre-GreenAntz design, ripped from my mate's github). So it seems to be a common problem.
The only transcoder it doesn't affect are my older GreenAntz with the manual slide-switch to select sync input (HV or C).
Anyway, I have a solution for GreenAntz v1.94 owners - I think this "bug" has affected at least one other person. But first, here are some before/after pics to demonstrate what I mean.
On the left side we have GreenAntz v1.94 with buggy sync input, as described above. Note it outputs incorrectly inverted sync. Refer the oscilloscope feed (Y), showing inverted horizontal sync and no vertical sync pulse. On the GreenAntz, note that the sync LED (blue, left) is only weakly lit.
On the right side we have the same GreenAntz v1.94, same buggy sync input, outputting correct composite sync. As can be seen on the 'scope feed the horizontal pulses are in the right direction (down) and vertical pulse is present (marked with a star). Sync LED is brightly lit.
The easy way to solve this, no soldering, is to take a wire with two male pointy ends, like this dupont/arduino wire. I've got a bunch of these wires in different formats (male/female/colours etc). Anyway, you might notice that I've lightly bent the ends with some pliers.
Then use the wire to "blank" out the V-sync input by "pulling it up". That means connecting the GreenAntz Vcc (about 4.7v) to the V-sync input.  Access the Vcc from the corner of the unused LM1881 footprint (pin 8 ), and then just connect the other end to unused resistor R22 (V term) footprint, as shown below. The two holes are unused in v1.94 (VGA). With the ends of the dupont wire slightly bent, and the natural springiness of the wire, it should just sit in place.
I hope the two spots I've described, as pictured, are easy enough to find.
This solution forces the GreenAntz into Csync mode. The wire is only loosely in place, but you can revert back to normal by just removing it. You can solder it in but that would be permanent. If you solder a post onto R22 then you could take a male/female arduino wire, solder the male onto the Vcc at LM1881 and connect the female end to the post. Ideally you could put a 1k resistor in series onto the wire, but this is not necessary.
Hope this helps.
Hardware used is a PC running Windows 7 x64 with HD6450 GPU and CRT_emudriver. Video ouput via VGA/GreenAntz to Sony TV component input.
« Last Edit: Today at 01:41:38 am by Zebidee »
