Author Topic: Megatouch XL 6000 MAME Emulation  (Read 10777 times)
megatouchhelp
  • Last login:December 21, 2020, 04:09:50 pm
« on: December 17, 2020, 11:31:30 pm »
Hello, I was wondering if there was anyone out there who has successfully emulated Megatouch XL 6000 using the MAME emulator. I have the ROM and the CHD but for some reason when I try to boot it up it says that I am missing files. Any help would be appreciated, thank you!
  • Last login:Today at 08:53:21 am
Re: Megatouch XL 6000 MAME Emulation
« Reply #1 on: December 18, 2020, 12:49:18 am »
Which files does it tell you that you are missing?   :dunno
Is the ROM (mtchxl6k.zip) in the ROMs folder?
- Does the ROM version match the MAME version you're using?
- For example, use MAME 0.210 ROMs with MAME 0.210.
Is the unzipped "mtchxl6k.chd" file in the "mtchxl6k" sub-folder in the ROMs folder?
- Does the CHD version work with the MAME version you're using?  The format for CHDs has changed several times over the years.
- You can find the SHA1 value for the CHD in the MAME source code file "../src/mame/drivers/mtouchxl.cpp"
-- In the latest version of MAME, line 423 shows that the SHA1 value for the DISK_IMAGE_READONLY (CHD) should be "95599e181d9249db09464420522180d753857f3b".
-- If you're using an older version of MAME, check the source code for that version.
https://github.com/mamedev/mame/blob/b8c338858a101d14308c64c87b0f714db4f05326/src/mame/drivers/mtouchxl.cpp
Code: [Select]
ROM_START( mtchxl6k )
MOTHERBOARD_ROMS
ROM_REGION32_LE(0x100000, "ioboard", 0)
ROM_LOAD( "sa3014-04_u12-r00.u12", 0x000000, 0x100000, CRC(2a6fbca4) SHA1(186eb052cb9b77ffe6ee4cb50c1b580532fd8f47) )
ROM_REGION(192, "multikey", 0)
ROM_LOAD( "multikey", 0, 192, BAD_DUMP CRC(d54ed86c) SHA1(83557dc604b2c7e8ab0787a3c3d73e1fb2556515) ) // hand made
DISK_REGION("board1:ide:ide:0:cdrom")
DISK_IMAGE_READONLY("r07", 0, SHA1(95599e181d9249db09464420522180d753857f3b))
ROM_END
If you've got the correct versions of those two files in the right folders, you should be good to go.   ;D
« Last Edit: December 18, 2020, 12:54:52 am by PL1 »
megatouchhelp
« Reply #2 on: December 18, 2020, 02:05:32 pm »
I know that I have put the zip file in the rom folder. I have also created a folder with an identical name for the CHD image and I have placed that in the roms folder as well. I am not sure how to check what version of MAME is compatible with the rom and CHD file that I have. Here is the error message I receive.
The selected machine is missing one or more required ROM or CHD images. Please select a different machine.
prom.mb (65536 bytes) - NEEDS REDUMP
mb_rtc (128 bytes) - NEEDS REDUMP
multikey (192 bytes) - INCORRECT CHECKSUM:
EXPECTED: CRC(d54ed86c) SHA1(83557dc604b2c7e8ab0787a3c3d73e1fb2556515) BAD_DUMP
FOUND: CRC (a7d118x1)
microtouch_5604010_rev_5.6.u1(65536 bytes) - NOT FOUND (microtouch)
microtouch_5603920_rev_5.5.u1 (32768 bytes) - NOT FOUND (microtouch)
microtouch_5604340_rev_2.2.u1 (65536 bytes) - NOT FOUND (microtouch)
Thank you for your continued support!  :)
« Reply #3 on: December 18, 2020, 09:48:28 pm »
Since you don't know which versions you have there are two basic approaches you can use:
(easier way, best chance of success)
1. Find a CHD and ROM that are clearly identified as working with a specific version of MAME (something like "MAME 0.215 ROMs", not "9427 MAME ROMs") then download the matching version of MAME.
i.e. If you find a MAME 0.215 CHD and a MAME 0.215 ROMset, download MAME 0.215.   ;D
or
(harder way, lower chance of success)
2. Use the dates on the .zip files to figure out the version(s) of MAME released shortly after the later of the two dates.  Download the source code for that version of MAME.  Compare the source code CRC and SHA1 values to your files until you find a version of MAME where they match.
- You'll need to find a version of MAME that the multikey file CRC is "a7d118x1".
- Megatouch XL 6000 was added in MAME 0.185 and promoted to "working" in MAME 0.186 (31 May 2017) so you're looking for 0.186 or newer.
The expected CRC and SHA1 values match the current source code so you are using a newer version of MAME with an older ROM.
These three entries indicate that your version of MAME needs a device file named "microtouch.zip" containing those three files.
megatouchhelp
« Reply #4 on: December 18, 2020, 10:35:37 pm »
What about the stuff that says it needs a redump? How can I be completely sure that my ROM and CHD are eventually going to work once I find the right version of MAME? Will there still be files like "prom.mb" that need a redump? I didn't see any information listed on the ROM site that specified the version of MAME needed.
I have been doing a lot of research lately and I haven't really found anyone else talking about Megatouch XL 6000 emulation on MAME so I figured it was a pretty obscure thing. Have you been able to emulate this software with any success or know anyone that has? If so, could you point me in the right direction of any working ROMs and CHDs (if it's allowed of course) because I am not entirely sure I have one that is working properly.
My apologizes for being so inexperienced. Once again, thank you so much for taking the time to help me.
« Reply #5 on: December 18, 2020, 11:12:40 pm »
The game was promoted to "working" so you know that those files do not cause problems.
If the game was still flagged as "MACHINE_NOT_WORKING" like it was when it was added in MAME 0.185, MAME would show a red warning screen if you tried to run it.
Find another site/source that does specify the version.
Sorry, but Rule 5 prohibits that type of assistance.
Need a ROM to complete your MAME collection? Don't bother to post here. If someone posts such a request, please don't answer it -- no direct answers, no hints, no private messages.
megatouchhelp
« Reply #6 on: December 19, 2020, 07:32:34 pm »
Okay, I am just going to keep my ROM and CHD file and try every version of MAME since 0.185 and report out what happens.
Is the "microtouch.zip" file that I need going to be found in one of these MAME versions, or is it something I am going to have to locate and download?
Also, do you know of anyone who has , or have you yourself successfully emulated Megatouch XL 6000 within MAME? It seems like such an obscure thing, I can't find any documented evidence of anyone ever playing this on MAME, only the 0.185 patchnotes stating it was added.
Thank you.
Robbbert
  • Last login:September 24, 2025, 05:09:06 am
« Reply #7 on: December 20, 2020, 06:55:52 am »
You need to find it out there somewhere.
« Reply #8 on: December 20, 2020, 07:49:16 am »
1. Don't bother with 0.185.  As mentioned above, mtchxl6k was flagged as "not working" when it was added in that version.
- That leaves about 38 possible versions to check.   :banghead:   :banghead:   :banghead:
2. You're going to need to find and download "microtouch.zip" which means that you'll probably have two unknown version files. (ROM and microtouch.zip)
- Unknown ROM and device file versions = a chance that the two of them will never work together with any version of MAME.
- The CHD is probably v5 format (used since 0.145u1) and probably hasn't been redumped.
It's either a device file or maybe a BIOS file.
Official MAME releases don't include ROMs, CHDs, BIOS files, or device files so it won't be in an official MAME release package.
You'll need to locate and download it.
- It's a good justification to find a known corresponding version of the ROM. (I'm not kidding, this really is the easiest way.)
I know the MAMEdevs got it working.   >:D
The 0.186 "What's new" linked above shows it was promoted to "working" ==> no known issues with gameplay.
If you find corresponding known versions of the four files -- ROM, CHD, device file, and MAME executable -- they will work together.   ;D
megatouchhelp
« Reply #9 on: December 21, 2020, 04:09:50 pm »
Thank you to everyone who helped! I was able to get Megatouch XL 6000 on MAME up and running thanks to your support.
I know it was promoted to working and most of it does, but I still got a warning screen at the beginning before the emulator loaded.
Just a few more questions, it seems to be running perfectly fine for the most part. However, there are a few weird quirks I have discovered here and there. For example, every time I try to play Trivia Whiz, the game restarts and it never ends up loading the game.
The emulator runs at an acceptable pace for most of the games since they are mostly puzzle and word games. But it does run a bit slow on action games like Hoop Jones and it feels a bit unnatural at times. Is there any way I could speed things up a bit?
Also is there a way to see what the keys are binded to? I was messing around and accidentally opened up the menu once and I can't figure out how to do it again.
Once again thank you for all the help!  :woot
« Reply #10 on: December 21, 2020, 07:15:23 pm »
So far, the only mtchxl6k issue reported at MAME Testers is a sound bug fixed in v0.199.   :dunno
https://mametesters.org/view.php?id=6983
As of v0.225, Info.dat doesn't have much on it either.
- 0.211: SVGA display parameter correction [AJR]. Changed VSync to 60.054866 Hz.
- 0.186: R. Belmont added clone MegaTouch XL 6000 (Version r04). Added new multikey rom. MegaTouch XL 6000 (Version r07) and clone (Version r02) promoted to working [R. Belmont].
- 0.185: R. Belmont, AeroCityMayor, Smitdogg and The Dumping Union added 'MegaTouch XL 6000 (Version r07)' (Merit Industries 1990) and clone (Version r02).
You may have background processes like anti-virus or Windows updates running that cause slowdowns.
The renderer (BGFX, etc.) or resolution might also cause slowdowns.
F11 toggles the FPS/speed display in the upper right corner of the screen so you can tell how fast and stable the emulation is running.
TAB is the menu key.
Arrow keys and ENTER to navigate.
The "Input (this Game)" menu has the game-specific keys.
To change a key:
- Highlight the line for that input.
- Press ENTER.
- Press the key you want mapped to that input.
If you accidently mapped the wrong key to an input:
- Press ENTER.
- Press ESC (older versions of MAME) or long press DELETE.* (newer versions of MAME) -- Sets input to none.
- Press ENTER.
- Press ESC or long press DELETE.* -- Resets input to default.
* A short press of DELETE maps DELETE to the input.
