Author Topic: Electrohome G05801 ground strap  (Read 1778 times)
brickpolisher
  • Last login:February 09, 2022, 02:04:37 am
« on: December 09, 2020, 12:54:21 pm »
I just picked up a 1979 Atari Asteroids arcade. Other than a couple of on-location operator fixes, it looks to be completely original. I'm planning on doing a cap kit to fix it up a bit.
But I noticed that the ground strap is disconnected and someone exposed a point in the gray wire on the neck hardness.  Should I try to find some springs and reconnect that strap to the tube... or is there some sneaky reason they disconnected it?
jennifer
Re: Electrohome G05801 ground strap
« Reply #1 on: December 09, 2020, 02:22:43 pm »
My guess is someone robbed the parts for another monitor, or put a used tube in there and did a quick fix for ground. The way it is is not right, the chassis is grounded but the tube itself not so much...You can probibally just grab what you need from a comparable television.
