Author Topic: Question about Tovis / Vision Pro MTG-2901CN  (Read 1715 times)
robotdance
  • Last login:February 05, 2021, 11:32:06 am
« on: December 01, 2020, 01:52:56 am »
Background: A friend built a Mame cabinet for me many years ago, but recently the motherboard seems to have gone bad.  I'm thinking I want to replace all the PC internals with a new motherboard, video card, CPU, SSD, etc., and go with GroovyMAME/GroovyArcade.  The monitor and all the controls are still connected and I think should still work just fine if I can get them hooked up to a new PC build.
The monitor is a Tovis / Vision Pro MTG-2901CN.  I'm a newbie at building a Mame machine myself, and I still can't quite understand how to connect the monitor to a new video card.
I'm thinking of a Radeon HD 5450 or HD 6450 with a VGA connector for the new video card.
The monitor is currently connected to the old video card with 6 wires that are soldered directly onto pins of a DVI connector.  The wires connect to the monitor chassis with a 6 pin Molex connector, and the V/S and H/S pins seem to be jumped together at the Molex connector.
So my questions:
  • Is this monitor a good candidate for GroovyMAME?
  • How do I go about connecting to a new video card?  Should I make my own cable by stripping one end of a VGA cable and then adding the 6 pin Molex connection? Would I add the jumper across V/S and H/S as is done for the current connection?
  • Should I use an arcade monitor video amplifier? How would this change the connections?
I've never worked with arcade monitors before, so I've still got a ton to learn!  Any other suggestions would be greatly welcomed!
