Author Topic: 3 New 8-1 Partycades - Pac-Man(Black), Ms. Pac-Man, Centipede(w/Akka Arrh proto)  (Read 7176 times)
negative1
  • Last login:Yesterday at 02:33:31 am
3 new ones: I'm getting ms pac man and centipede:
$199 per unit
Game Lists for each Partycade:
Black Pac-Man Partycade:
Pac-Man
Dig Dug
Pac-Land (Not on the QVC version)
Mappy
Super Pac-Man
Super Xevious (not on QVC version)
Galaga
Galaxian
Centipede Partycade:
Centipede
Milipede
Missile Command
Liberator
Crystal Castles
Akkh Arrh
Super Breakout (not a trackball game)
Avalanche (not a trackball game either)
Ms. Pac-Man Partycade:
Ms. Pac-Man
Pac&Pal
Galaga
Galaxian
Pac-Man Plus
Super Pac-Man
Dig Dug
Dig Dug II
later
-1
negative1
promo video:
later
-1
  • Last login:Today at 04:11:36 pm
How many of those ---smurfing--- things do you own?
negative1
1 stand up - pac-man modded
2 countercades - dig dug, and ms pac-man 2-1
2 wallcades - asteroids and centipede
later
-1
« Last Edit: November 21, 2020, 09:29:55 pm by negative1 »
  • Last login:Yesterday at 02:56:43 pm
I own 3!
Mortal Kombat Stock
Pacman - 60-n-1 mod
Pacman to Gorf conversion
Except for the Gorf, the two are in my kids playroom (8 and 10 year old girls). The girls play them periodically (maybe twice a month). I'll probably have to make them taller soon, but they are a pretty cool looking in the room with their barbies and crafts.
negative1
a couple of quick previews of ms pac-man 8-1:
later
-1
negative1
Enjoying a fully licensed akka arrh today on arcade1up.
Never thought i would see this happen, but the atari copyrights are there....
green glow is from Glens trackball, so i can actually play games, stock one is terrible.
the tape on the screen is the killspot for centipede, will be going for 999k to max it out.
later
-1
negative1
got my ms pac man 8-1 and centipede 8-1 today:
First look - Centipede 8-1 HSN Partycade
- original trackball very poor of course, played for 2 minutes, and then swapped out for Glens Retro Trackball
- Crystal Castles and Akka Arrh (Prototype) are fun to play, good additions
- They 'FIXED' the gameplay of Super Breakout, and Avalance, and now you have precision control over left and right. Of course now you're playing with a trackball instead of a spinner though.
- buttons are average, but should be replaced also.
maxed out centipede at 999k
later
-1
negative1
Centipede 8-1 HSN Partycade - Super Breakout WORKS PROPERLY (used Glens Retro Trackball) 561
Sound is a little messed up, but is proper in game.
- Super breakout works properly with the settings, although it is a trackball
- you can precisely move left and right, as normal, instead of discrete spots which was wrong on the Asteroids partycade with spinner
- i modded it to use Glens Trackball properly
- scored 561
- you can only play progressive mode, and not normal or cavity versions
Centipede 8-1 HSN Partycade - Avalanche WORKS PROPERLY (used Glens Retro Trackball) 452
Modded Centipede 8-1 [HSN] Avalanche works, with Glens Retro Trackball
Score - 452 [2 past extend]
Original game used a spinner.
Movement is correct, and you can precisely aim the paddles.
Arcade 1up - Centipede 8-1 - Crystal Castles (2 games) Warp2,3 - 438K
- Used Modded Glens Retro Trackball
- Played 2 games, and used all warps, 1-3-5
- Got to level 7 Pyramid
- Still need to get used to speed of trackball for game, as I was overspinning it at times.
later
-1
negative1
here's play up to 999,990 on the new ms pac-man 8-1 partycade.
the patterns should work on all Arcade 1up new versions with
the easy settings at extra's at 10k,40k, and every 40k.
i played very sloppy, and died on the first level. after that it was ok,
until about 500k, lost several men there. and then made it up to 990k,
and killed off the rest of the men, at 999,990.
will play until the killscreen next time maybe:
later
-1
