Author Topic: SOLD: New SNK LS-30 Joysticks Lot (w/Druin's Rotary Interface) [Houston, TX]  (Read 2157 times)
Vectoraster
  • Last login:November 19, 2020, 12:55:33 pm
  • You *are* starting to annoy me.
    • The VectoRaster Network
Time to list some items I saved for projects I'm not working on. This lot contains a set of MINT, genuine SNK LS-30 rotary joysticks with Druin's (legendary) Rotary Interface that can be used for emulator projects. I bought these sticks NOS back around 2003 and installed them on an interchangeable control panel. Seldom used - less than 2 hours total "run time" so consider them "new." Look at the photos - you won't find a cleaner set. Pictured with mounting (blank restrictor) plates I obtained from the amazing Kelsey Schell (OscarControls) that makes it possible to attach them to a wooden control panel. You can remove these mounting plates upon receipt if you have no need for them. LS-30 cables are also included, but they were cut (to accommodate the interchangeable control panel design). Just reconnect the wires if you need these cables (or buy new cables if you prefer). Also includes Druin's Rotary Interface instructions. Does not come with the cap removal tool. The caps are easy to remove by poking a q-tip or bent wire up through the marked head slot(s). The joysticks will be shipped with the caps off. Asking $300 or best offer for the lot, which is everything shown in the photos.
THIS LOT HAS BEEN SOLD.
« Last Edit: November 15, 2020, 10:50:36 pm by Vectoraster »
