Author Topic: CNC Cabinet build from Classic Arcade Cabinet plan. HELP !  (Read 8833 times)
Denicio
  • Last login:April 05, 2021, 03:13:51 pm
« on: November 09, 2020, 11:31:08 am »
I have found a local CNC shop to cut me a cabinet for a reasonable price.
NOW…here is where my OCD brain locks up.
Looking at these plans I see Mrs Pac Man at 85% accuracy with NO ONE having cut a cab from the design.
https://www.classicarcadecabinets.com/ms-pacman.html
This Galaga cab has had a cab cut and is at 92% accurate…BUT the ..crv “Does not create tool paths” which I have NO idea what that means.
https://www.classicarcadecabinets.com/galaga.html
I plan on using THIS control panel which I have been told by Steve requires a Midway/Namco cabinet.
https://www.arcadeshop.com/i/520/multicade-upright-panel-complete-trackball.htm
So my questions are:
1.   Which plan from this site would you feel most comfortable going with?
2.   Isnt the Pac Man, Mrs Pac Man and Galaga cabs all the same?
3.   Do I need ‘Tool Paths” for a CNC woodshop to do their job?
jennifer
Re: CNC Cabinet build from Classic Arcade Cabinet plan. HELP !
« Reply #1 on: November 09, 2020, 01:15:41 pm »
I wouldnt worry about those percent ratings, they start out low as new files, generally they are stitched scans that will lose a couple percentage points because of size, not usually a problem, build what you want...I am not a CNC girl and usually would print that on transfer tape and plot cut it as low adhesion stickers, I do that for allowances on modified cab designs and generally not necessary, but ya, tool paths for CNC.
Denicio
« Reply #2 on: November 09, 2020, 02:58:17 pm »
Jennifer,
Thanks for the reply.
Bonecollektor
  • Last login:February 09, 2021, 07:13:29 am
  • It's time to kickass and chew bubblegum...
« Reply #3 on: November 24, 2020, 07:45:19 am »
The crv file could be a format used by Vcarve Pro, Aspire, or something similar.
For instance, if I design something in Vcarve Pro I have to setup how I want the machine to cut the material (type of bit, speed, where to cut - on the line, outside the line etc..- and some other parameters. When I'm satisfied with everything I then export the file to gcode. There are other formats a cnc can use so you might ask your cnc shop what format they prefer.
They might even be able to just use the crv file and set up the cut the way they want.
Let me know if you have any other questions. 👍🏻
