Author Topic: C Sync working for 16.2.1 but not in 18.5.1 - R9 380  (Read 4116 times)
mrchrister
  • Last login:July 20, 2024, 06:14:53 am
« on: September 29, 2020, 09:02:19 pm »
Hey guys, just upgraded my 7750 to a R9 380 for Wii and Naomi gaming.
I have a weird issue. Everything works perfect with 16.2.1 but I cant get C Sync working with 18.5.1 in 640x480.
Tried all sorts of reinstalls over the last 3 hours, also changed polarity in my Generic_15 preset but that made no difference. 18.5.1 works if I switch to any other resolution than 640x480. 2560x240 works with no issues, so does 320x240, but 640x480 is just a garbled mess. No problems with 640x480 resolution in 16.2.1
Looked through the forum but it doesnt seem to be a common issue... I'm on Win7 64bit. Does anyone have an idea why this isnt working for me?
I would love to take advantage of new Vulkan Drivers for some of the Retroarch cores and as I understand it, its better to use 18.5.1
« Last Edit: September 29, 2020, 09:15:23 pm by mrchrister »
Calamity
  • Moderator
  • Last login:July 01, 2025, 01:29:14 pm
  • Quote me with care
Re: C Sync working for 16.2.1 but not in 18.5.1 - R9 380
« Reply #1 on: September 30, 2020, 08:19:46 am »
Hi mrchrister,
It sounds like 640x480 is the mode that was enabled by EDID emulation, and for some reason it doesn't get overridden by the c-sync redefinition of its modeline that's applied by VMMaker when installing modes.
Can you check if you have 2 instances of 640x480 in Arcade OSD? Like @30i and @60i.
Steps to create a log:
mrchrister
« Reply #2 on: September 30, 2020, 01:26:13 pm »
Thanks for you feedback, @Calamity !
I do have a 30i and 60i setting in ArcadeOSD in 16.2.1 and 18.5.1
Calamity
  • Moderator
« Reply #3 on: September 30, 2020, 02:07:14 pm »
Then you probably need to choose the other 640x480 instance.
mrchrister
« Reply #4 on: October 01, 2020, 02:36:48 am »
Tried both and both display the same issue.
I'm not sure it is a csync issue TBH. I noticed with composite sync off and adjusting vertical sync on the PVM I can see that 640x480 works correctly. When Csync is enabled it gives a diagonal distorted picture as if it is out of sync somehow.
Any idea why the two driver versions behave differently here?
kill_one
  • Last login:March 07, 2023, 01:16:21 pm
« Reply #5 on: October 02, 2020, 07:21:41 am »
I have the same card and I have a similar problem but with the 16.2.1 crimson drivers in Windows 7 x64, with the 640x480 resolution it often gives me black screen it does when I mainly launch Type x or Teknoparrot games and often stays like that when I go back to the desktop , to restore it I have to change it by hand, put another resolution and then again choose 640x480 ... when the screen is black via vnc the game shows up so I think the game wants to start with 640x480p and not 480i and having the jammasd card I get the black screen when the resolution goes out of sync, if I go to the settings of the windows card I give 30hertz interlaced or 60hertz, 60hertz interlaced not c0p while in arcade os both 604x480 30i and 640x480 60i are listed, also after a while in interlaced resolutions the screen starts to wobble exaggeratedly to the point of hurting your eyes by turning the monitor off and on again after a few minutes you can see it correctly again.
mrchrister
« Reply #6 on: October 03, 2020, 01:07:09 pm »
I will clean all and drivers with ddu and try from scratch. I also have a win 10 install I could use for testing. Will report back
psakhis
  • Last login:September 24, 2024, 11:54:25 am
« Reply #7 on: October 03, 2020, 01:58:11 pm »
I think it's a "register problem" on windows; some emulators or programs use 640x480 30khz by default, skipping 15khz mode.
See post http://forum.arcadecontrols.com/index.php/topic,163106.0.html
I resolved this issue in my cab but i don't know how..i was playing around ChangeDisplaySettingsA and EnumDisplaySettingsA entrys but i can't remember exactly..
After all, 640x480 it's really problematic with programs..the better workaround it's configure alternative standalone 15khz resolution and avoid conflicts..640x484, etc.
scsa187
  • Last login:April 11, 2021, 10:10:56 am
« Reply #8 on: October 06, 2020, 08:14:02 am »
I have this same issue on Windows 10. Made a thread about it too but no replies. Only super resolutions work and I also have a 30i and 60i mode both have sync issues.
mrchrister
« Reply #9 on: October 06, 2020, 05:32:29 pm »
No dice in Windows 10 either. Exact same issue, 640x480 gives a distorted picture. Attached are two screenshots of vm maker and the output on screen at 640x480
scsa187
« Reply #10 on: October 11, 2020, 01:02:12 am »
@mrchrister Did you find any fix to this?
mrchrister
« Reply #11 on: November 03, 2020, 02:09:58 pm »
Thanks for your help guys. Figured out I needed to adjust H FREQ by opening up the PVM. Now 18.5.1 works like a charme!!
