Author Topic: [RESOLVED] Tp-Link TL-WN823N Wifi adapter [Archer T3U AC1300]  (Read 8138 times)
DreyMIX
  • Last login:May 10, 2024, 01:28:11 pm
« on: September 14, 2020, 04:58:55 am »
« Last Edit: September 15, 2020, 08:10:23 pm by DreyMIX »
Substring
  • Last login:Today at 09:48:07 am
  • Forking GroovyArcade
    • forum.arcadecontrols.com/index.php/topic,160023.0.html
    • GroovyArcade active fork
Re: Tp-Link TL-WN823N Wifi adapter
« Reply #1 on: September 14, 2020, 05:59:12 am »
Can't tell if it work ootb, but I'd say most chances are that it works. May require some manual tweaking though
DreyMIX
« Reply #2 on: September 14, 2020, 08:01:41 am »
What do you mean by "manual tweaking though"?
Otherwise, have you already tested any other wifi adapter that works perfectly with this system?
Thank you
Substring
« Reply #3 on: September 14, 2020, 08:40:15 am »
Manually tweaking could mean installing a compilation environment and use AUR to install a good driver. Any linux newbie would fear such operation
As for me, using the 2 wifi dongles I own :
- one worked without a hitch
- the other one is really troublesome : it's detected by the system, can list APs, but won't connect to any. The same dongle works just perfect on my everyday ubuntu PC ...
I've had reports of :
- someone got it working flawlessly
- someone had to install a specific driver
DreyMIX
« Reply #4 on: September 14, 2020, 08:44:47 am »
Thank you. Could you tell me exactly what model you used?
Substring
« Reply #5 on: September 14, 2020, 10:13:05 am »
It's some kind of "no name" that I got bundled with a raspberry Pi 2. Will try to find the chip inside. But it's an old and crappy one, the bandwidth is really poor.
DreyMIX
« Reply #6 on: September 14, 2020, 10:15:29 am »
Ah, I understand. Maybe I'll buy this adapter first and see if I can get it to work.
Thanks in the meantime. I will let you know ;)
DreyMIX
« Reply #7 on: September 15, 2020, 01:15:27 pm »
Hello,
then I got the wifi adapter from TP-Link - Archer T3U. I tried looking for the drivers for Arch Linux (which is installed on the GroovyArcade), but I can't find anything. On the CD there are drivers only for Windows and Mac.
If I enter the console and type the command "lsusb", the device is detected.
[arcade@GroovyArcade ~]$ lsusb
Bus 002 Device 007: ID 2357:012d TP-Link 802.11ac NIC
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 002: ID d209:0452 Ultimarc J-PAC
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Could you help me install the drivers or at least figure out where to download them? Unfortunately I don't understand much about Arch. I am from Ubuntu.
PS:
From this link I see that they are talking about the same version of adapter that I also have. All right?
https://askubuntu.com/a/1183710
Thx!
« Last Edit: September 15, 2020, 01:25:29 pm by DreyMIX »
Substring
« Reply #8 on: September 15, 2020, 04:47:22 pm »
First check if wlan0 exists. If available, go the easy way : sudo wifi-menu
DreyMIX
« Reply #9 on: September 15, 2020, 04:54:30 pm »
Can I check it with "ifconfig"? If so, just give me the wired network interface.
[arcade@GroovyArcade ~]$ ifconfig
enp6s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.1.240  netmask 255.255.255.0  broadcast 192.168.1.255
        inet6 fe80::e2cb:4eff:feb0:8275  prefixlen 64  scopeid 0x20<link>
        ether e0:cb:4e:b0:82:75  txqueuelen 1000  (Ethernet)
        RX packets 275  bytes 33932 (33.1 KiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 88  bytes 11800 (11.5 KiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 4  bytes 240 (240.0 B)
        TX packets 4  bytes 240 (240.0 B)
« Last Edit: September 15, 2020, 04:59:08 pm by DreyMIX »
Substring
Re: Tp-Link TL-WN823N Wifi adapter [Archer T3U AC1300]
« Reply #10 on: September 15, 2020, 05:08:55 pm »
https://wiki.archlinux.org/index.php/Network_configuration/Wireless#Check_the_driver_status should be a good start as GroovyArcade is basically a custom Arch Linux distro.
DreyMIX
« Reply #11 on: September 15, 2020, 05:31:48 pm »
Sorry if I understand little, but I'm afraid of doing damage. Through that guide you passed me, I ran the following command "lsusb -v" and it gave me the following information. What do you mean, who found the device?
[arcade@GroovyArcade ~]$ lsusb -v
Bus 002 Device 004: ID 2357:012d TP-Link 802.11ac NIC
Couldn't open device, some information will be missing
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.10
  bDeviceClass            0
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x2357 TP-Link
  idProduct          0x012d
  bcdDevice            2.10
  iManufacturer           1
  iProduct                2
  iSerial                 3
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0035
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              500mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           5
      bInterfaceClass       255 Vendor Specific Class
      bInterfaceSubClass    255 Vendor Specific Subclass
      bInterfaceProtocol    255 Vendor Specific Protocol
      iInterface              2
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x84  EP 4 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0200  1x 512 bytes
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x05  EP 5 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x06  EP 6 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x87  EP 7 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0040  1x 64 bytes
        bInterval               3
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x08  EP 8 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
I continued to read and execute the commands the guide told me, but without success. Then towards the end, in the "Troubleshooting drivers and firmware" section. It seems to be talking about my device:
rtl8822bu
rtl8822bu-dkms-gitAUR or rtl88x2bu-dkms-gitAUR provides a kernel module for the Realtek 8822bu chipset found in the Edimax EW7822ULC USB3, Asus AC53 Nano USB 802.11ac and TP-Link Archer T3U adapter.
This requires DKMS, so make sure you have your proper kernel headers installed.
And I found this: https://github.com/jeremyb31/rtl8822bu
Substring
« Reply #12 on: September 15, 2020, 05:38:36 pm »
lspci -k would be better in that case, lsusb is not helping much here
DreyMIX
« Reply #13 on: September 15, 2020, 05:47:58 pm »
Here's what it gives me back. I don't seem to see the device.
00:00.0 Host bridge: Intel Corporation 5520/5500/X58 I/O Hub to ESI Port (rev 13)
   Subsystem: ASUSTeK Computer Inc. Device 836b
00:01.0 PCI bridge: Intel Corporation 5520/5500/X58 I/O Hub PCI Express Root Port 1 (rev 13)
   Kernel driver in use: pcieport
00:03.0 PCI bridge: Intel Corporation 5520/5500/X58 I/O Hub PCI Express Root Port 3 (rev 13)
00:07.0 PCI bridge: Intel Corporation 5520/5500/X58 I/O Hub PCI Express Root Port 7 (rev 13)
00:14.0 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub System Management Registers (rev 13)
   Kernel driver in use: i7core_edac
   Kernel modules: i7core_edac
00:14.1 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub GPIO and Scratch Pad Registers (rev 13)
00:14.2 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub Control Status and RAS Registers (rev 13)
00:14.3 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub Throttle Registers (rev 13)
   Kernel modules: i5500_temp
00:1a.0 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #4
   Subsystem: ASUSTeK Computer Inc. P5Q Deluxe Motherboard
   Kernel driver in use: uhci_hcd
   Kernel modules: uhci_hcd
00:1a.1 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #5
00:1a.2 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #6
00:1a.7 USB controller: Intel Corporation 82801JI (ICH10 Family) USB2 EHCI Controller #2
   Kernel driver in use: ehci-pci
   Kernel modules: ehci_pci
00:1b.0 Audio device: Intel Corporation 82801JI (ICH10 Family) HD Audio Controller
   Subsystem: ASUSTeK Computer Inc. Device 8357
   Kernel driver in use: snd_hda_intel
   Kernel modules: snd_hda_intel
00:1c.0 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 1
00:1c.2 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 3
00:1c.3 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 4
00:1c.4 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 5
00:1d.0 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #1
00:1d.1 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #2
00:1d.2 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #3
00:1d.7 USB controller: Intel Corporation 82801JI (ICH10 Family) USB2 EHCI Controller #1
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev 90)
00:1f.0 ISA bridge: Intel Corporation 82801JIR (ICH10R) LPC Interface Controller
   Kernel driver in use: lpc_ich
   Kernel modules: lpc_ich
00:1f.2 SATA controller: Intel Corporation 82801JI (ICH10 Family) SATA AHCI Controller
   Kernel driver in use: ahci
00:1f.3 SMBus: Intel Corporation 82801JI (ICH10 Family) SMBus Controller
   Kernel modules: i2c_i801
02:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] RV710/M92 [Mobility Radeon HD 4330/4350/4550]
   Subsystem: PC Partner Limited / Sapphire Technology Radeon HD 4350/4550 HyperMemory DDR2
   Kernel driver in use: radeon
   Kernel modules: radeon
02:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] RV710/730 HDMI Audio [Radeon HD 4000 series]
   Subsystem: PC Partner Limited / Sapphire Technology Device aa38
04:00.0 SATA controller: JMicron Technology Corp. JMB363 SATA/IDE Controller (rev 03)
   Subsystem: ASUSTeK Computer Inc. Device 824f
04:00.1 IDE interface: JMicron Technology Corp. JMB363 SATA/IDE Controller (rev 03)
   Kernel driver in use: pata_jmicron
   Kernel modules: pata_jmicron, pata_acpi, ata_generic
05:00.0 FireWire (IEEE 1394): VIA Technologies, Inc. VT6315 Series Firewire Controller
   Subsystem: ASUSTeK Computer Inc. P8P67 Deluxe Motherboard
   Kernel driver in use: firewire_ohci
   Kernel modules: firewire_ohci
06:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 02)
   Subsystem: ASUSTeK Computer Inc. M3A78 Series Motherboard
   Kernel driver in use: r8169
   Kernel modules: r8169
ff:00.0 Host bridge: Intel Corporation Xeon 5500/Core i7 QuickPath Architecture Generic Non-Core Registers (rev 05)
   Subsystem: Intel Corporation Device 8086
ff:00.1 Host bridge: Intel Corporation Xeon 5500/Core i7 QuickPath Architecture System Address Decoder (rev 05)
ff:02.0 Host bridge: Intel Corporation Xeon 5500/Core i7 QPI Link 0 (rev 05)
ff:02.1 Host bridge: Intel Corporation Xeon 5500/Core i7 QPI Physical 0 (rev 05)
ff:03.0 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller (rev 05)
ff:03.1 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Target Address Decoder (rev 05)
ff:03.4 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Test Registers (rev 05)
ff:04.0 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 0 Control Registers (rev 05)
ff:04.1 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 0 Address Registers (rev 05)
ff:04.2 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 0 Rank Registers (rev 05)
ff:04.3 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 0 Thermal Control Registers (rev 05)
ff:05.0 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 1 Control Registers (rev 05)
ff:05.1 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 1 Address Registers (rev 05)
ff:05.2 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 1 Rank Registers (rev 05)
ff:05.3 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 1 Thermal Control Registers (rev 05)
ff:06.0 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 2 Control Registers (rev 05)
ff:06.1 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 2 Address Registers (rev 05)
ff:06.2 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 2 Rank Registers (rev 05)
ff:06.3 Host bridge: Intel Corporation Xeon 5500/Core i7 Integrated Memory Controller Channel 2 Thermal Control Registers (rev 05)
Substring
« Reply #14 on: September 15, 2020, 05:51:19 pm »
Not listed, indeed. I suppose dmesg should show it can't load the driver. Are you sure about your chipset ?
Substring
« Reply #15 on: September 15, 2020, 05:57:05 pm »
Please download the file at https://we.tl/t-f3Q5rGCgjq (I've just built it for you). Copy to your GA PC, run sudo pacman -U rtl88x2bu-dkms-git-5.8.7.1.r96.220508d-1-x86_64.pkg.tar.zst, reboot, try again your wifi dongle. Had someone facing the same problem, worked fine for him this way. So I guess I'll this driver to the repo.
DreyMIX
« Reply #16 on: September 15, 2020, 06:07:47 pm »
What I can tell you is that I'm sure it works. At least on Windows 10, the device works.
Thx! Now I try now and let you know;)
DreyMIX
« Reply #17 on: September 15, 2020, 06:10:16 pm »
I think it gave me an error:
==> Unable to install module rtl88x2bu/5.8.7.1.r96.220508d for kernel *: Missing kernel headers.
Code: [Select]
[arcade@GroovyArcade ~]$ sudo pacman -U rtl88x2bu-dkms-git-5.8.7.1.r96.220508d-1-x86_64.pkg.tar.zst
loading packages...
resolving dependencies...
looking for conflicting packages...
Packages (12) binutils-2.35-2  dkms-2.8.3-1  elfutils-0.180-1  gcc-10.2.0-2  gcc-libs-10.2.0-2  guile-2.2.6-2  libelf-0.180-1  libmicrohttpd-0.9.71-1  libmpc-1.1.0-2
              make-4.3-3  patch-2.7.6-8  rtl88x2bu-dkms-git-5.8.7.1.r96.220508d-1
Total Download Size:    76.68 MiB
Total Installed Size:  405.49 MiB
Net Upgrade Size:      253.87 MiB
:: Proceed with installation? [Y/n]
:: Retrieving packages...
 gcc-libs-10.2.0-2-x86_64                                                     31.5 MiB  38.9 MiB/s 00:01 [##############################################################] 100%
 libmicrohttpd-0.9.71-1-x86_64                                               202.9 KiB  66.0 MiB/s 00:00 [##############################################################] 100%
 libelf-0.180-1-x86_64                                                       450.4 KiB   147 MiB/s 00:00 [##############################################################] 100%
 elfutils-0.180-1-x86_64                                                     619.8 KiB   202 MiB/s 00:00 [##############################################################] 100%
 binutils-2.35-2-x86_64                                                        5.3 MiB  59.1 MiB/s 00:00 [##############################################################] 100%
 libmpc-1.1.0-2-x86_64                                                        65.1 KiB  0.00   B/s 00:00 [##############################################################] 100%
 gcc-10.2.0-2-x86_64                                                          31.5 MiB  45.2 MiB/s 00:01 [##############################################################] 100%
 make-4.3-3-x86_64                                                           481.6 KiB   157 MiB/s 00:00 [##############################################################] 100%
 patch-2.7.6-8-x86_64                                                         92.5 KiB  0.00   B/s 00:00 [##############################################################] 100%
 guile-2.2.6-2-x86_64                                                          6.4 MiB  48.0 MiB/s 00:00 [##############################################################] 100%
 dkms-2.8.3-1-any                                                             53.8 KiB  0.00   B/s 00:00 [##############################################################] 100%
(12/12) checking keys in keyring        [##############################################################] 100%
(11/12) checking package integrity        [##############################################################] 100%
(11/12) loading package files        [##############################################################] 100%
(12/12) checking for file conflicts        [##############################################################] 100%
:: Processing package changes...
( 1/12) upgrading gcc-libs        [##############################################################] 100%
( 2/12) installing libmicrohttpd        [##############################################################] 100%
( 3/12) upgrading libelf        [##############################################################] 100%
( 4/12) installing elfutils        [##############################################################] 100%
( 5/12) installing binutils        [##############################################################] 100%
( 6/12) installing libmpc        [##############################################################] 100%
( 7/12) installing gcc        [##############################################################] 100%
Optional dependencies for gcc
    lib32-gcc-libs: for generating code for 32-bit ABI
( 8/12) installing guile        [##############################################################] 100%
( 9/12) installing make        [##############################################################] 100%
(10/12) installing patch        [##############################################################] 100%
Optional dependencies for patch
    ed: for patch -e functionality
(11/12) installing dkms        [##############################################################] 100%
Optional dependencies for dkms
    linux-headers: build modules against the Arch kernel
    linux-lts-headers: build modules against the LTS kernel
    linux-zen-headers: build modules against the ZEN kernel
    linux-hardened-headers: build modules against the HARDENED kernel
(12/12) installing rtl88x2bu-dkms-git        [##############################################################] 100%
:: Running post-transaction hooks...
(1/3) Arming ConditionNeedsUpdate...
(2/3) Install DKMS modules
(3/3) Updating the info directory file...
I don't know if it will help you.
Code: [Select]
[arcade@GroovyArcade ~]$ uname -a
Linux GroovyArcade 5.7.7-arch1-1-15khz #1 SMP PREEMPT Fri, 03 Jul 2020 00:38:27 +0000 x86_64 GNU/Linux
« Last Edit: September 15, 2020, 06:13:22 pm by DreyMIX »
Substring
« Reply #18 on: September 15, 2020, 06:14:52 pm »
Ah yeah sorry. Just run :
pacman -Sy linux-15khz-headers
DreyMIX
« Reply #19 on: September 15, 2020, 06:17:28 pm »
ok it's downloading ... Thanks I'll let you know
DreyMIX
« Reply #20 on: September 15, 2020, 06:26:44 pm »
Why is it still like this? I tried rebooting and now GA Setup starts and AM doesn't even start anymore.
Code: [Select]
[arcade@GroovyArcade ~]$ sudo pacman -Sy linux-15khz-headers
:: Synchronizing package databases...
 groovyarcade        7.4 KiB  1845 KiB/s 00:00 [##############################################################] 100%
 core        131.6 KiB  1415 KiB/s 00:00 [##############################################################] 100%
 extra        1660.9 KiB  15.2 MiB/s 00:00 [##############################################################] 100%
 community        5.2 MiB  51.5 MiB/s 00:00 [##############################################################] 100%
Packages (1) linux-15khz-headers-5.8.8.arch1-1
Total Download Size:    28.52 MiB
Total Installed Size:  122.62 MiB
 linux-15khz-headers-5.8.8.arch1-1-x86_64                                     28.5 MiB   164 KiB/s 02:58 [##############################################################] 100%
(1/1) checking keys in keyring        [##############################################################] 100%
(1/1) checking package integrity        [##############################################################] 100%
(1/1) loading package files        [##############################################################] 100%
(1/1) checking for file conflicts        [##############################################################] 100%
(1/1) installing linux-15khz-headers        [##############################################################] 100%
(2/3) Updating module dependencies...
(3/3) Install DKMS modules
==> Unable to install module rtl88x2bu/5.8.7.1.r96.220508d for kernel 5.8.8-arch1-1-15khz: Missing kernel modules tree.
Substring
« Reply #21 on: September 15, 2020, 06:40:13 pm »
mmhhh ... looks like you need to update the kernel too
sudo pacman -S linux-15khz linux-15khz-docs
DreyMIX
« Reply #22 on: September 15, 2020, 06:52:13 pm »
Good! It looks like it's gone.
Code: [Select]
[arcade@GroovyArcade ~]$ sudo pacman -S linux-15khz linux-15khz-docs
Packages (2) linux-15khz-5.8.8.arch1-1  linux-15khz-docs-5.8.8.arch1-1
Total Download Size:    99.12 MiB
Total Installed Size:  239.00 MiB
Net Upgrade Size:      163.17 MiB
 linux-15khz-5.8.8.arch1-1-x86_64                                             72.5 MiB  5.44 MiB/s 00:13 [##############################################################] 100%
 linux-15khz-docs-5.8.8.arch1-1-x86_64                                        26.7 MiB  8.17 MiB/s 00:03 [##############################################################] 100%
(2/2) checking keys in keyring        [##############################################################] 100%
(2/2) checking package integrity        [##############################################################] 100%
(2/2) loading package files        [##############################################################] 100%
(2/2) checking for file conflicts        [##############################################################] 100%
:: Running pre-transaction hooks...
(1/2) Removing linux initcpios...
(2/2) Remove DKMS modules
==> Unable to remove module rtl88x2bu/5.8.7.1.r96.220508d for kernel 5.7.7-arch1-1-15khz: Not found in dkms status output.
(1/2) upgrading linux-15khz        [##############################################################] 100%
(2/2) installing linux-15khz-docs        [##############################################################] 100%
(1/4) Arming ConditionNeedsUpdate...
(2/4) Updating module dependencies...
(3/4) Install DKMS modules
==> dkms install --no-depmod -m rtl88x2bu -v 5.8.7.1.r96.220508d -k 5.8.8-arch1-1-15khz
==> depmod 5.8.8-arch1-1-15khz
(4/4) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux-15khz.preset: 'default'
  -> -k /boot/vmlinuz-linux-15khz -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-15khz.img
==> Starting build: 5.8.8-arch1-1-15khz
  -> Running build hook: [base]
  -> Running build hook: [udev]
  -> Running build hook: [autodetect]
  -> Running build hook: [modconf]
  -> Running build hook: [block]
  -> Running build hook: [filesystems]
  -> Running build hook: [keyboard]
  -> Running build hook: [fsck]
  -> Running build hook: [plymouth]
==> Generating module dependencies
==> Creating gzip-compressed initcpio image: /boot/initramfs-linux-15khz.img
==> Image generation successful
I tried to restart the pc:
Code: [Select]
Linux GroovyArcade 5.8.8-arch1-1-15khz #1 SMP PREEMPT Fri, 11 Sep 2020 00:38:27 +0000 x86_64 GNU/Linux
        RX packets 3162  bytes 530676 (518.2 KiB)
        TX packets 3238  bytes 889960 (869.1 KiB)
        RX packets 0  bytes 0 (0.0 B)
        TX packets 0  bytes 0 (0.0 B)
wlan0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether d0:37:45:17:f1:b7  txqueuelen 1000  (Ethernet)
But now AM doesn't start anymore. Going to read the logs (/home/arcade/shared/logs/attract.log), it says this:
Code: [Select]
attract: /usr/lib/libc.so.6: version `GLIBC_2.32' not found (required by /usr/lib/libgomp.so.1)
Substring
« Reply #23 on: September 15, 2020, 06:54:20 pm »
will look at this some other day, bed time here
DreyMIX
« Reply #24 on: September 15, 2020, 06:56:37 pm »
Don't worry! Thanks for everything for now! In the meantime I see if I can at least configure the wifi and let you know.
DreyMIX
« Reply #25 on: September 15, 2020, 08:09:51 pm »
All problems solved!
The wifi network adapter now works for me:
Code: [Select]
[arcade@GroovyArcade ~]$ iw dev wlan0 link
Connected to **:**:**:**:**:** (on wlan0)
        SSID: ******_2.4GHz
        freq: 2472
        signal: -76 dBm
        tx bitrate: 300.0 MBit/s
AM now starts up again. I tried to force update the Glibc library
Code: [Select]
sudo pacman -S glibc
Thanks for all the help, and I hope this post will be useful for other users;)
Substring
Re: [RESOLVED] Tp-Link TL-WN823N Wifi adapter [Archer T3U AC1300]
« Reply #26 on: September 16, 2020, 01:48:28 am »
Wanted to suggest a full system upgrade (I hardly bother with per package updates). The groovyarcade-config package could have been a little tricky, see my last post in the collaborative GA topic giving some news
DreyMIX
« Reply #27 on: September 16, 2020, 03:26:51 am »
ok I'll take a look at it. Doesn't running it risk compromising something?
Substring
« Reply #28 on: September 16, 2020, 05:06:46 am »
If you're using the 2020.06 iso, what I can recall is :
- confirm you agree for some package replacements (harmless)
- Xorg fonts conflicts -> the default answer is no, so you must accept the proposal. Harmless too
- /home/arcade/.xinitrc : used to be "statically" created, not belonging to a package. But since yesterday, it's part of the groovyarcade-config package. So pacman will refuse to install the update. I've explained how to solve that in the collaborative GA topic. I don't recommend you customize this file
- a plymouth update will restore the default boot splash. Once again, check the collaborative GA topic
Better reference : http://forum.arcadecontrols.com/index.php/topic,160023.msg1723442.html#msg1723442
DreyMIX
« Reply #29 on: September 16, 2020, 05:29:11 am »
ok thx!  ;D
