Author Topic: Build an Arcade Cabinet for 200euro ($250)  (Read 2824 times)
duyvh0309
  • Last login:September 16, 2020, 04:58:36 am
« on: July 30, 2020, 04:04:21 am »
Build an arcade cabinet for around €200 ($250)
It all started with some SNES gamepads and a SNES emulator, but it all got slightly out of hand.
After we had done some SNES gaming with some cheap knockoff SNES gamepads we converted to usb, we wanted more. We came up with the idea to make a MAME arcade machine, and settled pretty quickly on the fact that a full size arcade cabinet was the only way that would fulfill our dreams. But, there's two of us (me and my friend) surely we can't share one machine, right? Of course not! We're building two of them!
That wasn't all. Why build a huge machine with only a single function? So we tried to come up with more. The major other feature of our arcade machine is a fridge! There's loads of space below the controls and the screen that we weren't going to fill with electronics like in the old days. So we've put a fridge in there. This of course did mean that there would need to be a door in the botom, and that also added a problem of sturdiness because the door can't help support the other three sides. But afterwards the machine ended up really sturdy, especially because the fridge holds it together a little bit as well by it's weight.
Before building the machine, we did a lot of planning and designing, stuff that, if you are genuinely interested in building a MAME, you might be doing at the moment. We know how hard it can be to find all of the perfect information in one place, so we will try to do our best to give you all possible information we've found in our building process.
DEMONSTRATION VIDEO
If you're not familiar with these terms I'll explain them here:
Bezel - the bezel is the plastic in front of the screen and the black around the screen
Marquee - the marquee is the image above the screen, this has a 'marquee light' behind it so it is backlit
Cabinet - the cabinet is another name for the whole machine, but especially the case
tomton
  • Last login:April 18, 2023, 07:38:30 am
Re: Build an Arcade Cabinet for 200euro ($250)
« Reply #1 on: August 03, 2020, 05:14:28 am »
Video is not playing/showing so difficult to say anything about your design/plans.
One thing I can say is that $250 is extremely tight budget!
