Author Topic: FightCade2 FBNeo tearing issue  (Read 15984 times)
iori01
  • Last login:May 18, 2024, 05:41:12 pm
« on: July 21, 2020, 04:53:48 pm »
Hello all,
I have another issue with new Fightcade 2 setup
This is now using FinalBurn Neo emu for NeoGeo and CPS but this special version for FC2 disabled triple buffer.
The result is now tearing and whatever tweak i did can't get rid of this tearing.
I've tried modeline 304x224 to match emulator choice, I also setup super resolution and use 2560x224  and both have tearing. I've tried different bitter, same issue.
did someone successfully setup 15Khz setup Native Res with new FC2 ?
btw, I've tried RedGGPO which use also FBNeo, it's even worse while emu is not able to go fullscreen progressif resolution from interlace :(
Thanks for your help.
My setup is Win7-64, HD4550 emudriver 2.0 beta15
psakhis
  • Last login:September 24, 2024, 11:54:25 am
Re: FightCade2 FBNeo tearing issue
« Reply #1 on: July 22, 2020, 04:58:47 am »
Hi, i have only configured FightCade v1 without problems.
¿Are there more people on FightCade v2 now?
iori01
« Reply #2 on: July 22, 2020, 06:51:12 am »
yes, same for me with FC1, only FC2 is problematic.
Looks like people moving from FC1 to FC2 has now FC2 include NullDCNaomi, then allow more netplay games like CvsS2, MvsC2, Hokutono Ken, etc..
still beta but looks good start
iori01
« Reply #3 on: July 24, 2020, 01:58:40 pm »
I continue troubleshooting session without any succes.
To provide more details, tearing is really easy to see with games like aero fighters 2
I've tried with Win7 HD5xxx , and now Win10 HD5xxx but still the same.
Also, I tried all Blitter, all possibility, native res and super res , but all the same issue.
Nobody using new Fightcade 2 on CRT ?
Thanks.
Calamity
  • Moderator
  • Last login:Today at 04:51:39 am
  • Quote me with care
« Reply #4 on: July 24, 2020, 02:34:00 pm »
So that Fightcade2 thing doesn't have a vsync feature?
Steps to create a log:
psakhis
« Reply #5 on: July 24, 2020, 02:48:46 pm »
dgVoodoo2 it's your friend  ;D ;D
Only you need it's activate it and copy dll files to fba emulator directory. I tested on my personal computer and vsync works.
iori01
« Reply #6 on: July 24, 2020, 05:49:11 pm »
Hi Calamity,
It seems Fightcade Teams build FinalBurn Neo (Mame code) and remove all possible feature that will add extra frame and will not help with netplay
Maybe that's why they remove Vsync, triple buffern etc
Just my thinking
iori01
« Reply #7 on: July 24, 2020, 05:52:07 pm »
Hi Psakhis,
Thank you sooooo much !!! :)
This is just amazing, works perfectly  :applaud:
On downside, looks not working at all with my setup Win7 HD4xxx , FinalBurn Neo will not even launch and crash with error
Maybe it's time to move my ITX PC to Win10
Is it still Win7 recommanded for CRT emudriver ? or Win10 is now working ok ?
Thanks again
psakhis
« Reply #8 on: July 25, 2020, 04:22:16 am »
Hi, i tested on W7x64, for me better than W10 for a cabinet arcade (no updates concern)
iori01
« Reply #9 on: July 25, 2020, 07:13:04 am »
interesting, might be something wrong with my setup, or because I have an HD4xxx with my Win7-64 setup
I will give a try and change for a HD5xxx
By the way, I discover that ddraw.dll from dgVoodoo2 works better than the one Calamity propose for Emulator.
I can now change from interlace to progressive with Direct draw 7 blitter while with the one of Calamity, not working.
Could be an improvement to implement
Recapnation
  • Last login:May 16, 2025, 07:59:16 am
    • Eiusdemmodi
« Reply #10 on: July 25, 2020, 08:11:13 am »
Sonic Wings 2/Aero Fighters 2 (as well as some other NG games) may very well be the worst game to troubleshoot this -- the original hardware's limitations caused some sort of tearing in many situations:
https://youtu.be/shlLNk4cDKk?t=47
iori01
« Reply #11 on: July 26, 2020, 12:17:34 pm »
Hi Recapnation,
Thanks for this info but I think this is a good test because I have the real hardware and then this is the perfect way to compare ;)
So, after another day of test, I can say that HD4xxx was the issue.
Win7-64 + HD4xxx = Fightcade2 tearing (because dgVoodoo2 no working)
Win7-64 + HD5xxx = Fightcade2 no tearing (with the help of dgVoodoo2)
Win10-64 + HD5xxx = Fightcade2 no tearing (with the help of dgVoodoo2)
Many thanks again for the help !
Problem solved (until new FC2 update ... ) and I can enjoy CPS/NeoGeo native res on PVM online  :cheers:
Recapnation
    • Eiusdemmodi
« Reply #12 on: July 27, 2020, 04:54:12 am »
Glad I said "may", then.
iori01
« Reply #13 on: July 29, 2020, 04:17:18 pm »
I'm sorry Recapnation, I'm french and my English is to be improved  :-[
your video really show hardware limitation. I would have say that every vertical shoot would shown easily the tearing, just that aero fighters 2 was the first in the list  ;D
Thanks anyway for your help in this topic  :cheers:
Recapnation
    • Eiusdemmodi
« Reply #14 on: July 30, 2020, 06:27:14 am »
Yeah, the video is legit. I meant that using games which have inherent "tearing" for testing this particular matter is nuts, but if you know well how the game originally behaves, don't mind me.
scsa187
  • Last login:April 11, 2021, 10:10:56 am
« Reply #15 on: October 06, 2020, 07:48:03 pm »
Fightcade 2 has a vsync option on the emulator whats wrong with using that?
cornerstone
  • Last login:December 15, 2022, 06:47:28 pm
  • El Niño (the storm)
« Reply #16 on: October 09, 2020, 09:59:22 am »
In general, is a fightcade on arcade cab setup as simple as using crtemudriver and a jpac? I’m planning to build a setup like that but I’m unsure if I’m missing something
psakhis
« Reply #17 on: October 09, 2020, 01:16:40 pm »
Fightcade allows play online..but it's a "simple" fba emulator at all.
scsa187
« Reply #18 on: October 09, 2020, 08:04:52 pm »
Using the vsync option on Fightcade 2 with CRT I do notice more input lag than vsync off on my LCD. But vsync on other things like Retroarch seem fine to me.
What other vsync options can we use? I could not get the dgvoodoo thing to work properly still had tearing and a watermark when using the dll.
cornerstone
« Reply #19 on: October 10, 2020, 10:12:14 am »
Yeah, I’m guessing I just set up the resolution to the native CPS2 resolution and go from there?
Edit: actually maybe setting it to a super resolution like 2560x224 would be best?
« Last Edit: October 10, 2020, 10:23:38 am by cornerstone »
psakhis
« Reply #20 on: October 10, 2020, 02:00:18 pm »
See options.
cornerstone
« Reply #21 on: October 12, 2020, 08:55:39 am »
Hello all,
Sorry for clogging this thread up, but were you able to run FC2 while switching resolutions when each game plays?
Because at 304x224, the interface is too big to read chat or messages. And at Super Resolutions, Windows horizontal resolution is too small.
Is there a way to remain at 640 x 480 and then switch to the native resolution of a game when you start it up?
psakhis
« Reply #22 on: October 12, 2020, 09:05:15 am »
Hello all,
Hi, with FC1 i scripted a workaround for my cabinet if you are interested. I don't installed FC2 yet.
FightCade_Launcher.exe %basename% -f (this argument is optional for autofullscreen at startup a game)
https://drive.google.com/drive/folders/12aT5kQSmcX-S9wfSU_5m0oJsjvSUUMu0?usp=sharing
NOTE: the script only starts a selected game from frontend. My run.bat is this and auto switch resolutions.
Code: [Select]
@echo off
set fullpath=%~dp0
c:\users\arcade\scripts\cmd_focus.exe
call "c:\users\arcade\12noon Display Changer\640.bat"
c:\users\arcade\scripts\show_cursor.exe
%fullpath%fightcade_launcher.exe %1 -f
c:\users\arcade\scripts\hide_cursor.exe
call "c:\users\arcade\12noon Display Changer\450.bat"
« Last Edit: October 12, 2020, 09:17:18 am by psakhis »
cornerstone
« Reply #23 on: October 13, 2020, 12:03:17 pm »
Thanks. I’ve got to have FC2 though. If anyone else knows what to do, here is where I am:
I’ve got the CPS2 and NeoGeo modelines installed, along with 640 x 480
If I run with the base 640x480 in windows resolution, my full screen FBNeo at the correct CPS2 resolution looks like the attached photo.
HOWEVA,
When I right click and switch the background windows resolution to the CPS2 resolution and then full screen FBNeo, it looks perfect. But the fightcade 2 program is unreadable.
Hopefully that adds a nugget of info to anyone trying to figure this out. Hopefully FBNeo has something in the program that allows for resolution switching, but I can’t find it. Thanks for the help anyway.
psakhis
« Reply #24 on: April 27, 2021, 02:15:09 pm »
Hi, i tested latest version and now vsync works fine.
If anyone are interested, i wrote a launcher for those who have a cabinet frontend like my case. Features:
 - Automatic search games by system and rom file
 - Automatic join into the channel
 - Automatic fullscreen on snes and fightcade v1 (not needed in fightcade v2)
 - Change snes resolution on the fly to 256x224 (view script on process fcadesnes9x.exe)
 - Alt+F4 integrated to the buttons (view script buttons, i use 10 and 12 hotkeys)
Use:
fightcade2_launcher.exe system rom [resolution]
system: fc1,fc2,nes,megadrive,snes,msx,sms,...
rom: basename of the rom
resolution: (optional) by default it's configured for 640x480 crt. With 1920 argument works on 1920x1080.
For example: fightcade2_launcher.exe fc2 sf2ce
Autohotkey src and metadata files. https://drive.google.com/file/d/1gQxK7RUxoaohBdV4xSLYF9eFWlNKUjY5/view?usp=sharing
Cauptain
  • Last login:August 12, 2021, 07:42:06 am
« Reply #25 on: August 12, 2021, 07:42:06 am »
Use:
Hello psakhis
I tried to download from your page and it says that there is a virus in the executable, blocked for me.
How do I exactly configure your launcher? Where do I need to place the .exe file and the .ahk file?
I already have Fightcade working here at home.
Is there a way to check this executable problem and give me more detailed instructions?
Claudio
psakhis
« Reply #26 on: August 12, 2021, 03:47:57 pm »
Hi Claudio,
The .7z is compressed file. You will find .ahk script for compile to .exe with autohotkey program.
https://www.autohotkey.com/
Copy fightcade_launcher.exe to the fightcade directory and the all *.dat and *.xml files.
