Author Topic: Dual Spinners With 2-Player IPAC Ultimate I/O Setup?  (Read 2271 times)
mister-pizza
  • Last login:March 01, 2021, 04:56:05 pm
« on: July 17, 2020, 05:38:05 pm »
Hello all! I'm new to the arcade cabinet building scene. It's all been straight forward until I started reading about the Ultimate I/O's specs, which made me wonder if two spinners would be possible.
I'd like the full panel to be 2 joysticks, 8 buttons (16 total) with a trackball and two spinners. Can that be wired properly on the Ultimate I/O? I wanted to ask someone before I started ordering parts :)
  • Online Online
  • Last login:Today at 03:02:15 pm
Re: Dual Spinners With 2-Player IPAC Ultimate I/O Setup?
« Reply #1 on: July 17, 2020, 07:34:02 pm »
A trackball and two spinner setup needs 4 optical axes.
AFAIK the Ultimate I/O will only handle 3 optical axes, so by itself, it's one axis short.
When you order the SpinTraks, get one with USB and one without.USB.
Pretty sure the USB interface is the same one used for the U-Trak.
Here's the pinout.
Each optical axis needs:
5v operating voltage
Ground
Two data lines
- X1 and X2 for X-axis or Y1 and Y2 for Y-axis.
- If the cursor moves in the opposite direction expected (i.e. turn spinner right ==> cursor goes left), swap the two data lines.
« Last Edit: July 17, 2020, 07:36:17 pm by PL1 »
mister-pizza
« Reply #2 on: July 17, 2020, 07:40:12 pm »
Bingo! Thank you so much, that makes perfect sense to me.  :applaud:
