Author Topic: JVL retro io battery  (Read 4160 times)
fewpheonix
  • Last login:July 14, 2020, 08:27:09 pm
« on: July 14, 2020, 06:48:16 pm »
So just finally was able to desolder the old io battery out, and replaced it with a new battery in my JVL retro.On startup however, the machine still gives me the corrupted file, needs factory reset message. I am concerned I didn’t solder the new battery wires in completely. I know I have the wires going through the correct holes. Do the wires need to be bent after coming through to touch the sides of the board? Should I use solder just in the backside? Any advice would be appreciated? Thank you all!
Megatouchmike
  • Last login:September 19, 2025, 01:43:48 pm
Re: JVL retro io battery
« Reply #1 on: July 14, 2020, 07:02:35 pm »
It will do that on the first boot. Shouldn't after you factory reset. If it still is, you've botched the solder job
fewpheonix
« Reply #2 on: July 14, 2020, 07:54:06 pm »
That’s what I figured. It still gives me the message on repeated startups. Can I fix the soldering by adding more solder?
orizzle
  • Last login:September 21, 2020, 07:20:41 pm
« Reply #3 on: July 15, 2020, 07:05:13 am »
You should get a multimeter and ensure the battery is making good contact. And that you didn't install it backwards
Sent from my Pixel XL using Tapatalk
