Author Topic: Robotron How to Wire Two Joysticks to Keywiz  (Read 2299 times)
bizarrotot
  • Last login:July 05, 2020, 11:22:06 am
« on: July 03, 2020, 05:37:46 pm »
Hello,
I have installed a new joystick for a MAME Cabinet I inherited because I want to run Robotron. But I can't figure out how to connect two joysticks. Can someone please help me?
After a lot of digging I found this Keywiz Wiring Diagram, but there is only 1 port for for each joystick connection. http://groovygamegear.com/PDF/KEYWIZ_MAX.pdf
Please help.
Thanks.
  • Last login:Yesterday at 05:29:30 pm
Re: Robotron How to Wire Two Joysticks to Keywiz
« Reply #1 on: July 04, 2020, 12:42:24 am »
For your second joystick you can use any 4 inputs except the ones for your first joystick since Robotron needs separate inputs for move (first joystick) and fire. (second joystick)
- If you have 4 unused inputs, use those.
- If you don't have 4 unused inputs, you can "piggy-back" on a button input by wiring the two switches in parallel.
-- Just put both switch-to-input wires into the input terminal and tighten down the set-screw.
                   Button switch
                     ____/____ Daisy-chain ground
    Input ____|
                    |____/____ Daisy-chain ground
                Joystick switch
- The diagram below shows "piggy-backing" 4 inputs for a 4-way and an 8-way joystick. (same wiring as above)
-- You'll use four button switches and the four switches from your second joystick so your move and fire directions are separate in Robotron.
-- When lines cross, a dot = connected and no dot = not connected.
bizarrotot
« Reply #2 on: July 05, 2020, 11:23:02 am »
Thank you very much for your help. I was able to get everything connected and it's working great. Thank you!
« Reply #3 on: July 05, 2020, 12:46:09 pm »
Glad to assist.   :cheers:
Now that you've got the second stick working, here's a list with more dual-stick games.
http://wiki.arcadecontrols.com/index.php/Joysticks#Games_with_Dual_Joysticks
