Author Topic: Help with a (generic?) H-12 Universal Chassis  (Read 2962 times)
kyle__
  • Last login:September 14, 2020, 10:49:48 am
« on: June 24, 2020, 12:13:04 am »
I'm trying to use a somewhat generic universal chassis labeled, "H-12" on the board, and "EPSP648" in some places in the listing I bought it on. I can't find much information about it.  The tube I'm using is labeled WG 1220872.  It came to me in an otherwise empty cabinet.  No boards/chassis etc, but was told it worked.
Anyway, I can't find docs on this exact board, but from reading various sources, I thought I had things hooked up right.  However, whenever I power it on, it pops the circuit.  I am not using an isolating transformer but thought I read newer chassis didn't need that.
When I measure the windings, I get 2.3 and 5.6 ohms.
If there are other pictures or measurements needed, I'd be happy to provide.
kyle__
Re: Help with a (generic?) H-12 Universal Chassis
« Reply #1 on: June 24, 2020, 12:14:26 am »
It didn't like so many pictures in one post.
Neck board.  The other two pictures I took probably aren't that useful (model label on the tube & screen printing of the board name on the chassis).
« Last Edit: June 24, 2020, 12:16:03 am by kyle__ »
grantspain
« Reply #2 on: June 24, 2020, 03:33:26 am »
are you running the chassis from a iso transformer?
  • Last login:Today at 05:29:30 pm
« Reply #3 on: June 24, 2020, 03:55:03 am »
Ken Layton
  • Guru
  • Technician
« Reply #4 on: June 24, 2020, 11:03:14 am »
That chassis REQUIRES operation from an isolation transformer.
kyle__
« Reply #5 on: June 24, 2020, 11:35:11 am »
Oh.  OK.  So, is that something you can tell from looking at it, or the model?   How does one figure that out?
Edit, also ordered this from Jameco: https://www.jameco.com/z/ITR300-Power-Transformer-Isolation-120VAC-120VAC-300VA_181315.html
« Last Edit: June 24, 2020, 01:49:57 pm by kyle__ »
Ken Layton
  • Guru
  • Technician
« Reply #6 on: June 25, 2020, 12:03:40 am »
I can tell by looking at the chassis. There would have been a large yellow transformer in the power supply section. That would have been part of a switching regulator power supply. Since it didn't have that transformer, this is a chassis that needs an isolation transformer.
By the way the transformer you ordered is a bit overkill for the common monitors. Here is what most games requiring isolation use:
http://www.arcadeshop.com/i/1346/monitor-isolation-transformer.htm
kyle__
« Reply #7 on: July 01, 2020, 09:50:57 pm »
So .... if I plug in the chassis to the isolation transformer, and plug it in, it blows the fuse on the transformer.  Did my plugging this in without an iso transofrmer kill it; is it a lemon of a board; or do I just have it hooked up backassward?
grantspain
« Reply #8 on: July 02, 2020, 01:24:32 am »
check the diodes in the bridge circuit and the regulator
kyle__
« Reply #9 on: July 02, 2020, 06:39:21 pm »
I tested all the diodes I could identify.  They seem fine.
I don't know if it's related to what's happening, but what are these circled in white here?
The short wires jumpered to one of two pins.
kyle__
« Reply #10 on: July 09, 2020, 08:30:59 pm »
Well, I decided to try yet another new chassis, and it lives!
So either my naive rough handling killed that first chassis, or it was a lemon.    As a bonus, this one had a degaussing coil and one page (duplexed) of documentation.    It's not perfect, but it works enough for my proposes.
Before I bundle this into the cabinet again, what is this E pin for?
grantspain
« Reply #11 on: July 10, 2020, 02:28:53 am »
crt earth, its the single wire that comes from the dag earth that surrounds the back of the crt( the metal braid)
absolutely critical
