Author Topic: Area51, Playstation & Gun  (Read 19750 times)
crashwg
« on: February 19, 2004, 04:16:12 pm »
I have Area51 for the playstation, and in the book it says that you can use a light gun, buy my Guncon (which I got with Time Crisis) doesn't work on it.  I tried them both on the PS2 with the Guncon just incase it was my playstation, and got the same result, Time Crisis works Area51 doesn't.
Am I doing something wrong?  Will a different light gun help?  Maybe a Guncon2, they have those right?
Oh, man I want to play Area51 the way it was inteded to be played... :-\
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
Re:Area51, Playstation & Gun
« Reply #1 on: February 19, 2004, 08:44:15 pm »
I've herd of compatibilitiy problems of some PSX lightgun games played through the PS2 (which is really just emulating psx).
I thought it ment you can't use the usb type guncon2 on psx games...but it sounds like you are using the older guncon through a ps2 and it still isn't working?
crashwg
« Reply #2 on: February 20, 2004, 12:12:40 am »
Yea, I can't get the Guncon (original one) to work, with Area51, on the Playstation, PSOne, or PS2.
I'm wondering if they just forgot to ad the light gun support to the game or something, because it works fine with Time Crisis...
Lemme say it again
adonis_minus_20
  • Last login:April 10, 2020, 02:32:20 am
« Reply #3 on: February 20, 2004, 01:19:17 pm »
You just need a regular lightgun,or a Guncon compatible gun that can operate in non-guncon mode.  Here's one that works:
http://www.buyritegames.com/product_information.asp?number=PS-P99G2&back=yes&dept=1057&last=1010
Jim
crashwg
« Reply #4 on: February 20, 2004, 02:33:46 pm »
Is this information you're giving me come from experience?  Have you used this particular gun with Area51?
Lemme say it again
adonis_minus_20
« Reply #5 on: February 20, 2004, 04:02:31 pm »
Yes and yes.  This gun has settings for both guncon and non-guncon mode, you just need to make sure that the gun is set to normal mode for non-guncon games and guncon mode for guncon games (before powering up your PS).  I bought two of these guns off of ebay a ways back, because they work with PS1/PS2 and for Guncon/Guncon2 games (as well as non-guncon games).  It has a kickback feature to it, which is kind of nice (it can be disabled), and comes with a reload pedal.  Another gun that will do the trick, for PS1 only, is the Nyko Super Cobra Lightgun.  This will work for guncon and non-guncon games for PS1 (but not guncon2 for PS2):
http://www.baysoftgames.com/nykosupercobra.html
Hope this helps.
Jim
crashwg
« Reply #6 on: February 21, 2004, 07:27:49 pm »
Thanks man, you have been a huge help.  I can't wait to play some Area51  ;D
Lemme say it again
Harakiri
  • Last login:February 13, 2014, 05:02:37 am
  • Invisible member status
« Reply #7 on: February 26, 2004, 08:38:40 pm »
About that "super compatible" gun! Is it possible to interface it with a pc?! With adaptors and stuff?! It could be a alternative to act labs!  :o
TalkingOctopus
    • My Arcade
« Reply #8 on: March 02, 2004, 09:34:03 pm »
Nope.  Unfortunately there is not a simple way to do it.
