Author Topic: Parallel Cable cut away  (Read 1540 times)
GGKoul
  • Cheesecake Apprentice
« on: February 19, 2004, 02:39:16 pm »
Hello
I search the board & internet and I couldn't find the answer to this.
Can someone send me a link that describes what wires are in a parallel cable?  As I planning to create multiple panels and I want to connect the panels via a Male & Female parallel cable.
So each panel will have a Male parallel cable to connect to the Female connection from the IPAC.
Any advise you have will be greatly appreicated!!
-GGKoul
Jake22
  • Last login:February 19, 2004, 02:10:10 pm
Re:Parallel Cable cut away
« Reply #1 on: February 19, 2004, 02:44:37 pm »
There's no standard for the actual cable itself.  However, the port pinouts are in these places:
http://www.doc.ic.ac.uk/~ih/doc/par/doc/regpins.html
http://www.physics.utah.edu/~ko/WebEshop/E-stuff/pinout_parallel.html
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #2 on: February 19, 2004, 02:47:57 pm »
There's just 25 pins/wires.  Do with them as you please.
« Last Edit: February 19, 2004, 02:48:11 pm by SirPoonga »
GGKoul
« Reply #3 on: February 19, 2004, 02:50:50 pm »
So the Pins on both the Male & Female cables don't have to match?
IE:  Pin1 Male to Hole1 on Female?
I mean this..  A wire a on connected to the male end is pin 1 and wired to UP... Hole1 on the female is wired to the IPAC as Button1.
So they dont have to match?
« Last Edit: February 19, 2004, 02:54:13 pm by GGKoul »
GGKoul
« Reply #4 on: February 19, 2004, 02:58:14 pm »
So I'm wondering... Is there a document that says
White Wire is Pin 1
Blue Wire is Pin 2
im_living_large
  • Last login:June 15, 2005, 03:00:58 pm
« Reply #5 on: February 19, 2004, 03:01:08 pm »
Yes, the pins have to match, but pin 1 male may have a purple wire connected to it and female 1 may have a yellow wire.  There's no standard.  The best way to do it is to cut off the end of the female and the male, then strip back the insulation on all wires on the male and female, and use a meter to check continuity and label the wires somehow.  It's a long process, but the best way I know to ensure you have the right connection.  Let's say you hook the purple pin 1 male wire which is connected to pin 1 up to button 1.  Now the purple wire on the female side may be connected to pin 17, and if you hook that up to your IPAC on button 1 it won't work correctly, because it's looking for whatever is coming into pin 17.  It's hard to put this in words, but I hope you understand.
GGKoul
« Reply #6 on: February 19, 2004, 03:02:49 pm »
I got it.
Damn.. its going to be as long process...   :-[
im_living_large
« Reply #7 on: February 19, 2004, 03:03:23 pm »
From what I've seen, there is no industry standard.  It's left up to the cable maufacturer, so unless you have the same brand cable chances are you won't be able to rely on wire color, and even if they are the same manufacturer there's no guarantee they used the same color wire on both cables.
GGKoul
« Reply #8 on: February 19, 2004, 03:05:07 pm »
Unless I purchase one cable that is Male on one end and a Female on the other end.
« Last Edit: February 19, 2004, 03:06:09 pm by GGKoul »
Sephroth57
  • Poo Monkey
  • Last login:June 07, 2020, 11:17:00 am
    • Check it out!!!
« Reply #9 on: February 19, 2004, 03:07:20 pm »
an easier way would be to buy 2 female DB25 connecters with crimp pins from radio shack. wire the pins yourself so you know what they are, then connect the 2 with a double male cable.
"Owens is the ringleader in the ass hat circus"  D K
GGKoul
« Reply #10 on: February 19, 2004, 03:11:05 pm »
My local Radio Shack doesn't have them...  I have to check else where....
crsdawg
  • Last login:September 13, 2019, 06:10:05 am
  • I plan to live forever, or die trying.
« Reply #11 on: February 19, 2004, 03:12:08 pm »
if i'm reading your question correctly......
the wires inside the cable should all be color coded(at least all the cables i've used have been). once cut, and  you have the connectors together the wires of the same color should have continuity.
ie.  if a wire that is yellow/black stripe is connected to player one fire button.......then yellow/blk stripe(coming from the opposing connector)  should be connected to the player one fire input on your encoder.
hope this helps.
SirPeale
  • Green Mountain Man
« Reply #12 on: February 19, 2004, 10:01:19 pm »
Use a 25 pin serial cable.  That should have male and female ends.  Then your color coding issues are over.
GGKoul
« Reply #13 on: February 19, 2004, 10:04:40 pm »
I just purchased 4 of them...
Thanks for everyone's help.
-GGKoul
