Author Topic: Picked up a machine for free, don't have too much information on it...  (Read 2879 times)
kingted
  • Last login:June 11, 2020, 08:31:04 am
Anyone have any info on it? Got it for free, doesn't work, haven't tried to power it on yet, I'd like to get it open but don't have a key...
Here's some more photos
https://imgur.com/a/PEj7Qmr
Can I just put a new plug on this and plug it in? The 100v is confusing me. As for the the key, I'd rather not drill it out. Is this a common type of lock? Are there master keys? Thanks in advance.
  • Last login:Today at 08:12:41 am
You should be able to get into it from the back.
Just put a new plug on it, 110V is close enough.
kingted
Hi, thanks for the reply. The cabinet is covered with these one way rivet type fasteners which I believe is because it's a slot machine type game (maybe I'm wrong). The only way I could see getting in through the back is by cutting it open although there is a small hole where I can see inside and even see the lock up front but I can't really reach it.
jennifer
I doesnt do you any good if you can't get into it, mice may have been in there and at best would only be a fire hazzard...Original, is a fun thought but not really practical sometimes if it could potentially burn your house down...I would personally drill the lock and not lose a minutes sleep.
Ken Layton
  • Guru
  • Technician
That's a "pachislo" Japanese slot machine.
Suggest you join this forum:
https://www.pachitalk.com/forums/index.php?
They can tell you all about your machine and how to get in it without a key.
kingted
