Author Topic: Jpac Lockup during LED animations (Self Test)  (Read 866 times)
Bubs
  • Last login:June 07, 2020, 11:53:21 pm
« on: May 10, 2020, 01:00:22 am »
Hi everyone,
I'm new to this forum as a writer, but probably a reader for the last 6 years :-)
I'm using your J-pac for a couple of years and I'm very happy with it.
However, I noticed recently a behavior which is not optimal and wanted to know if there was a workaround:
When I boot my arcade cabinet, my kids are always pushing tons of buttons during the boot process. Resulting the JPAC to detecting some input as faulty (ON on boot).
What happen with the self-test, is that it will lockup every input to the keyboard while it is sending the right number of blinks to the LED... which result in a long freeze as my cabinet already booted for a while...
Does anyone knows if there a mode where the self-test LED do not block the inputs pass thru, or a mode when I can deactivate the self-test (jumper)?
I saw the last firmware seems to solve something similar but only for the Ultimate IO version of the board?
Thank you all !
