Author Topic: Megatouch Aurora Additional Security Key  (Read 4482 times)
jasonripp
  • Last login:April 19, 2022, 03:44:44 pm
« on: May 03, 2020, 07:13:20 pm »
I think this is the first post for me, but I've been lurking for awhile and have much appreciated the knowledge I've gained here. So thanks!
I bought a mixed lot of Megatouch units awhile back, mostly XLs, but there was also a dead Ion Elite and another dead Ion Aurora. The Elite is now up and running and I finally got around to tearing into the Aurora. It has numerous issues - dead hard drive, dead power supply, dead motherboard, but I've been working through it. Since my plan is to install it in a repurposed XL upright cabinet, I began taking out all of the components today.
After removing the power switch assembly, I noticed a small board under where the MyMerit key reader is located. Upon removal, I flipped it over and was surprised to see a second Dallas iButton security key. It lacks the "spoon" plastic of the normal key, but it's definitely a second, well-hidden key.
I haven't seen any mention of a second key in all my research on this unit, so I am wondering of anyone has any insight.
gavinlew
  • Last login:August 16, 2024, 11:27:22 am
Re: Megatouch Aurora Additional Security Key
« Reply #1 on: May 03, 2020, 07:17:10 pm »
Hi Jason
I got a board similar in my box of spares will check to see if I can find anything that may help you - I think it’s connected to an IOboard as it was for my 6000XL
(Will check in the morning now as in the UK)
orizzle
  • Last login:September 21, 2020, 07:20:41 pm
« Reply #2 on: May 03, 2020, 07:18:36 pm »
It should be a DS1991 key. It's not for security but instead a cabinet identifier. It was used for online games to tell the servers if you had an Aurora 17, 19, or 19 wide. It also stores information about the light show. That's why you get lights immediately even before the game boots.
The 17" Evos have them also.  I think the Rx also does, under the I/O I believe.
« Last Edit: May 03, 2020, 07:22:01 pm by orizzle »
jasonripp
« Reply #3 on: May 03, 2020, 07:34:46 pm »
Thanks for the info!
Do you know if it is required for the system to run? I suppose it's no big deal to leave it in the mix, but I'm trying to remove anything not needed for my build.
orizzle
« Reply #4 on: May 03, 2020, 07:51:02 pm »
If you want the light show to function properly, leave it in
