Author Topic: Hantarex polo b+ high (SOLVED)  (Read 1248 times)
Justez
  • Last login:January 10, 2024, 05:49:44 am
« on: May 01, 2020, 07:49:10 am »
I have a hantarex polo 25.
Problem - No picture or neck glow. (No ticking sound)
I'm running through RF's flowchart to troubleshoot this thing and the B+ is still reading high even though I followed it all the way to the end.
Use a 40w bulb as a charge to verify that the power supply is correct.
I obtained:
B+ 145v
TP9 17v
TP8 26v
TP10 12v
I tried the flyback on another chassis and it's ok
I mount the flyback again and got:
B+ 155v
TP9 17v
TP8 26v
TP10 12v
IC104 pin 1 : 11,85v
Bu508(T114) tested and ok, collector voltage same as B+ 155v
I test T113, seems ok.
TP23 oscillospcope
TP27 oscillospcope
I was wondering if anyone has ever seen anything like this before and might have some tips.
SOLVED:  TH2 was dead
« Last Edit: May 01, 2020, 01:15:25 pm by Justez »
