Author Topic: Non retro games on arcade monitor with emudrivers  (Read 2729 times)
xaryC
  • Last login:March 20, 2025, 03:39:04 pm
« on: April 30, 2020, 04:19:43 am »
Hello,
I'm trying to get mortal kombat komplete edition to run in my arcade cabinet. The game runs fine when I connect my 'normal' lcd monitor to my pc. But when its connected to my crt monitor I get a '4:3 modes are not supported' error. Is there a workaround for these kind of 'newer' games that don't support low resolutions?
When i uninstall the emudrivers and the basic vga drivers are installed the game runs, but very slow...
psakhis
  • Last login:September 24, 2024, 11:54:25 am
Re: Non retro games on arcade monitor with emudrivers
« Reply #1 on: April 30, 2020, 07:37:08 am »
You need to know if game supports 640x480i at most. I have a plenty of modern games in my cabinet with different resolutions.
I think you will examine this topic http://forum.arcadecontrols.com/index.php?topic=132504.80
« Last Edit: April 30, 2020, 10:38:58 am by psakhis »
buttersoft
  • Last login:Today at 02:42:44 am
  • Is running at 15kHz
« Reply #2 on: May 01, 2020, 08:45:05 am »
A ton of games will run happily in 800x600@50i as well. Just pick 800x600 and they don't even care. I'm playing Tekken 7 online that way on my horizontal cab.
Better done on a TV rather than an arcade monitor, perhaps. You'd want to make sure yours can handle that mode ok.
xaryC
« Reply #3 on: May 03, 2020, 01:28:00 pm »
I did came across that topic allready but it didn't have a solution to mu problem.
I can get the game to boot when I set my desktop resolution to a super resolution (2650x240) but my screen is squiched and I can't see much, but it does boot, and at the right speed...
xaryC
« Reply #4 on: May 03, 2020, 01:30:40 pm »
I will try to add that mode to the drivers list. But when I got the game to run on my lcd pc monitor I couldn't set te resolution lower than 1366x768 (or something like that)
I'm using windows 10 64 if that does matter... And disabled the amd external utility in the services.
« Last Edit: May 03, 2020, 01:32:14 pm by xaryC »
psakhis
« Reply #5 on: May 03, 2020, 02:34:13 pm »
You can edit the resolution in the config file.
%APPDATA%\MKKE\options.ini
xaryC
« Reply #6 on: May 03, 2020, 03:40:06 pm »
Yeah did that, doesn't work for me... Also changed the dxdiag.txt and set the dedicated memory to 1024 and made the file read only.
But still no luck on launching...  :(
