Author Topic: How to hook a speaker to a 10.1 LCD HMDI monitor? What speaker to buy? (Pi4B)  (Read 3177 times)
hillz4ever
  • Last login:May 30, 2020, 01:42:18 am
Guys im a lost trying to buy and hook a usb powered speaker to my 10.1 monitor. IDK which/what to buy, im trying to get a speaker that the monitor itself will power it. Any suggestions? The pin set on the right says speaker, then below it usb but there is a 3.5mm jack (earphone) and a micro usb port that will power 5v.  The monitor itself takes a 12V power supply
Would this work?  https://www.amazon.com/HONKYOB-Speaker-Computer-Multimedia-Notebook/dp/B075M7FHM1/ref=sr_1_8?dchild=1&keywords=usb+speaker&qid=1587335383&s=electronics&sr=1-8
Project: ICADE Mod, raspberry pi 4b (4GB), 64gb micro SD
Monitor...............................................................
LCD Controller Board:
HDMI Board Work for 40Pin EDP LCD Screen
Input Power Adapter: 5Vdc-12Vdc More than 2A.
Come In Standby Model When Not Input Signal
Standby Model <0.3W
Audio Input: 2HDMI
Audio Output: Earphone
OSD: Brightness Contrast VOL+ VOL- Language And So On
Language: English
Board Size: 82mm x 60mm x 5mm
10.1" VVX10T025J00 2560X1600 LCD Screen:
Display Mode IPS, Normally Black, Transmissive
Resolution 2560RGB)×1600
Outline Size 229.75 ×151.22×4.6(H×V×D)
Display Area 216.96× 135.6 (H×V)
Brightness 400 cd/m² (Typ.)
Contrast Ratio 1000:1 (Typ.) (TM)
Viewing Angle 80/80/80/80 (Typ.)(CR≥10) [Left / Right / Up / Down]
Signal Interface eDP (2 Lanes) , 40 pins , Connector
Backlight WLED
Input Voltage 3.3V (Typ.)
« Last Edit: April 19, 2020, 07:32:26 pm by hillz4ever »
