Author Topic: GroovyArcade boot hang on splash screen --> Solved  (Read 4080 times)
claudiola
  • Last login:October 21, 2020, 08:04:01 am
« on: March 31, 2020, 01:06:43 pm »
Hi to all,
I have reinstalled from scratch new version of GroovyArcade (GroovyArcade-Arch2019.03.10-x86_64.iso) in order to replace the old one.
1. Started emulator from USB set monitor & other sfuff : work fine
2. Installed with previuos setting on new SSD disk (tested many times seems to be good!!) , I was able to install without any problem (auto HDD config) than I configured the roms on a secondary disk like did on old version.
3. First reboot is good
4. Next boot hang on Groovy Arcade splash screen
5. After several reboot, once starts normally until the next boot problem :-(((
I have tried multiple times with same result.
Now I'm able to boot from USB & acess to the SDD disk ...
Please help me !! What I have to check ?  :notworthy: :notworthy:
Thanks, Claudio.
« Last Edit: April 21, 2020, 12:12:49 pm by claudiola »
claudiola
Re: GroovyArcade boot hang on splash screen
« Reply #1 on: April 01, 2020, 12:49:06 pm »
Hi, reading also some other topic, I add some information that can help to debug ( I hope).
syslinux.cfg :
default arch
timeout 2
prompt 2
#UI vesamenu.c32
menu title Groovy Arcade Linux
label arch
menu label GroovyArcade
linux ../vmlinuz-linux
append root=/dev/disk/by-label/GA rw rd.udev.log-priority=3 splash vga=0x311 video=VGA-1:640x480ec
initrd ../initramfs-linux.img
boot.log:
         Starting Samba NMB Daemon...
         Starting Permit User Sessions...
[  OK  ] Started OpenSSH Daemon.
[  OK  ] Started Permit User Sessions.
         Starting Wait for Plymouth Boot Screen to Quit...
         Starting Terminate Plymouth Boot Screen...
claudiola
« Reply #2 on: April 01, 2020, 12:52:03 pm »
Added boot hang image.
Substring
  • Last login:June 18, 2025, 02:52:14 pm
  • Forking GroovyArcade
    • forum.arcadecontrols.com/index.php/topic,160023.0.html
    • GroovyArcade active fork
« Reply #3 on: April 01, 2020, 02:03:42 pm »
Have you updated your system with pacman ?
claudiola
« Reply #4 on: April 01, 2020, 02:27:38 pm »
No, only basic install from ISO. No update.
Substring
« Reply #5 on: April 01, 2020, 03:03:38 pm »
If you have ssh access, please give the output of "journalctl -b"
claudiola
« Reply #6 on: April 01, 2020, 05:13:12 pm »
In this moment no acces, tomorrow I will try ( I have row data, no idea if can be useful).
Thanks, Claudio.
claudiola
« Reply #7 on: April 02, 2020, 09:30:58 am »
Thanks, Claudio.
Ciao,
I was able to get the files : 2 from boot ko taken with "journalctl -D ." on the journal dir + 1 from good boot
claudiola
« Reply #8 on: April 02, 2020, 12:56:49 pm »
Ciao, I made some home-made test !!
I have done another installation on other disk.
I discovered that every time I shutdown the system from GUI at next restart I get the boot problem !!
If I restart or shutdown from "text menù" no problem on boot !!
I tried to enter in maintencance mode but no way, any hit on keyboard fail (password for was root set before ..)
Any idea ?
Substring
« Reply #9 on: April 02, 2020, 03:59:29 pm »
It says your ntfs shared drive is "corrupted" and you should fix it but Linux doesn't have the required tool (and it doesn't even exist I'm afraid).
Take out your drive, plug it in windows, repair.
And try not to brutally shutdown in GA.
claudiola
« Reply #10 on: April 02, 2020, 05:24:14 pm »
I will try, on ROM disk I have also installed Win XP with Feel as backup solution.
Trust me I take care of my cabinet (I dreamed for years), I not brutally shutdown in GA, I use the shutdown option provided by Groovymane waiting the power off of the whole sustem.
Thanks.
claudiola
« Reply #11 on: April 21, 2020, 12:11:53 pm »
Hi, sorry to be late in response : problem solved moving all roms & cabs on same disk with GroovyMame front-end installation; now no more problem on boot with only one disk installed on my PC.
I did also the test on NTFS disk that was good, no problem found; I'm able to boot and use windows XP ...
Thanks for support, Claudio.
