Author Topic: How wire this Power Supply?  (Read 2411 times)
savj14
  • Last login:April 06, 2020, 07:52:46 pm
« on: March 28, 2020, 05:48:41 pm »
I have a Jamma PCB that I'm looking to test and possibly sell but I wasn't sure how to wire up and test the Power Supply in the attached pics. I have no idea if it even works but I figured I'd test it and if all else fails I'll buy a new one. I have a power cord stripped with green, white, and black wires but I wanted to ask here before I do anything.
bperkins01
Re: How wire this Power Supply?
« Reply #1 on: March 28, 2020, 05:53:07 pm »
Black and white to AC110 (doesn't matter which since it is not labeled on the PS)
Green to FG
Thats it
« Last Edit: March 28, 2020, 06:07:03 pm by bperkins01 »
savj14
« Reply #2 on: March 28, 2020, 06:37:03 pm »
Awesome thanks for the quick reply back. Would the Ground from the Jamma connector go to FG as well?
What is the 0V connection use for?
savj14
« Reply #3 on: March 28, 2020, 07:21:32 pm »
What should I use for testing the Voltage? I've tried the different VDC options and none of them will show close to 5 volts.
  • Last login:Yesterday at 11:30:00 pm
« Reply #4 on: March 28, 2020, 08:24:39 pm »
0V is where you should hook up jamma ground.
You probably won't get a good reading without a load.
savj14
« Reply #5 on: March 28, 2020, 09:52:34 pm »
The Power Supply has an adjustment nob on it. If I have a PCB connected with the voltage too high so I can test and get a reading is there any chance I can ruin the PCB?
« Reply #6 on: March 28, 2020, 11:00:25 pm »
Turn it all the way widdershins before you plug a pcb into it.  Adjust as necessary.
bobbyb13
  • Last login:Yesterday at 06:56:55 pm
« Reply #7 on: March 29, 2020, 01:34:04 am »
Thank you pbj for expanding my universe today-
I had never heard the term widdershins before
savj14
« Reply #8 on: March 29, 2020, 03:24:18 am »
Haha I had to Google that one as I thought it was a typo or something. You really do learn something new everyday I guess.
Thanks for the info and I'll give that a go tomorrow. I'll give it the old "Lefty Loosey"
« Last Edit: March 29, 2020, 03:28:09 am by savj14 »
genrod
  • Last login:June 29, 2025, 08:03:09 pm
« Reply #9 on: March 31, 2020, 06:14:46 pm »
I noticed the adjustment knob is missing.  How will you be turning the knob?
