Author Topic: Stranded or solid wire.....  (Read 3099 times)
EEmu
« on: June 11, 2002, 12:47:15 pm »
.....for wiring buttons and joysticks?  Can solid wire be crimped onto quick disconnects?
Thanks for any help.
jelloslug
  • Last login:May 25, 2005, 03:55:59 pm
  • Splut!
    • Jelloslugs Arcade
Re: Stranded or solid wire.....
« Reply #1 on: June 11, 2002, 03:00:51 pm »
Go with stranded wire for crimped connections, solid will break very easily and does not hold a crimped connection very well, on the other hand if its going from a terminal block solid will work fine.  Solid is also a bit easier to solder on to D-sub connectors.
EEmu
« Reply #2 on: June 11, 2002, 04:09:46 pm »
Thanks jelloslug.
J_K_M_A_N
  • Last login:Yesterday at 08:38:55 am
« Reply #3 on: June 13, 2002, 11:11:06 am »
Personally, I used telephone wire. Not a cord but the internal wire. (Solid copper) I found it VERY easy to use especially with the terminal connectors. But I also used crimp connections on the other end. I haven't hand any problem with them breaking or slipping out. Good luck.
J_K_M_A_N
jkman999.tripod.com
