Author Topic: low-voltage solution  (Read 1815 times)
Huskerfan
  • Last login:October 05, 2021, 11:40:38 pm
« on: February 14, 2020, 03:21:49 pm »
Hi,
Years ago I was using a powermite to power coin door bulbs, track ball lights, and speakers.
I'm basically re-doing my whole setup.
What are people using these days?  Sorry, I tried to search "low voltage" and it was difficult to find anything.
nitrogen_widget
  • Last login:May 23, 2025, 02:30:58 pm
Re: low-voltage solution
« Reply #1 on: February 14, 2020, 06:16:06 pm »
I use something like this:
http://www.ohmslawcalculator.com/led-resistor-calculator
with LEDS, resistors, and old phone chargers from thrift stores.
Huskerfan
« Reply #2 on: February 14, 2020, 06:50:45 pm »
Whoah!  That seems over my pay grade!
Anything store bought?  Plug and Play?
But thanks!  That's pretty cool!
nitrogen_widget
« Reply #3 on: February 16, 2020, 10:47:31 am »
  • Last login:Yesterday at 11:00:27 pm
« Reply #4 on: February 16, 2020, 07:17:56 pm »
I'd just go ahead and knock it down to 5v if you are going to refit everything.... then you can power the whole thing with a powered usb hub/charger.
Huskerfan
« Reply #5 on: March 04, 2020, 10:07:33 am »
I found a youtube video where you can McGyver a pc power source.  Just hook up the green and black wire for constant power and yellow is 12 volt.  Pretty cool actually
lilshawn
  • Last login:Yesterday at 05:48:23 pm
« Reply #6 on: March 06, 2020, 12:27:22 am »
any game you have in your cabinet needs power.... just steal power from that power supply. 5 volts, 12 volts... whatever.
i normally use one of those cheapy arcade power supplies https://www.amazon.ca/16A-Arcade-Switching-Power-Supply/dp/B00F1YQDBA
i tag off a ground (usually coin switch) and then run the positive wire into the cabinet and crimp a spade connector onto it... then i can put it on whatever voltage i need.... if i run out of 12v wedge bulbs and all I have are 6v 555's (which I have stupid amounts of)... i can just move it onto the 5V connector.
