Author Topic: Megatouch Video - re-usable guts?  (Read 4022 times)
partycat
  • Last login:March 07, 2020, 12:37:40 pm
« on: February 14, 2020, 02:48:59 pm »
From reading the little bit of information I can find on the ancient "Megatouch Video" cabinets, they're largely a stay-away relic in a state of decay. I can get a hold of one for nothing to fart around with , and I realize it takes eeprom chips for the programming so it is more or less what it is and cannot be upgraded.
The semi-FAQ from the games list thread says most of the parts aren't of any value to anything. Is the cabinet (dimensions wise) and display usable if there are enough parts available from an XL? At this point I will probably test and re-cap the power supply if needed, and then just let it be until the CRT fails, but, if I can make it a project I just might.
mahkeymike
  • Last login:January 15, 2026, 03:00:29 pm
Re: Megatouch Video - re-usable guts?
« Reply #1 on: February 14, 2020, 08:24:06 pm »
I re read this thread 3 times, I still have no clue what OP is asking.  :banghead:
partycat
« Reply #2 on: February 15, 2020, 08:11:30 am »
Sorry - is the power supply or touch screen reusable if I get parts from an XL to try and convert or upgrade this cabinet? Looks to be an old 5 or 6.
I realize that may not be cheaper than just finding one of those.
partycat
« Reply #3 on: February 15, 2020, 01:33:03 pm »
I did some more reading and picked up the cabinet anyways since it was just my time to grab it. It's a Super 4, and appears to be in fine working order except for the touchscreen glass itself which is damaged, and R1 on the remote board for the monitor smoked out some time in the past. Display is working fine though I suppose adjusting the brightness it out of the question. I guess I'd need to understand a bit better why that happened but replacing a resistor is easy enough.
My understanding of everything XL and up is that they drive VGA monitors, and this cabinet is CGA. While not impossible to convert, it would not be plug and play, and may not be worth playing around with.
It may be better at this point since it is in otherwise general good condition to repair the touchscreen and have it for what it is.
I'm still interested in any experiences or thoughts on retrofitting this cabinet as I do want the XL games, and it doesn't hurt to entertain the idea.
Apologies for the first post I was in the middle of a few things at work and I didn't devote enough brain cells to writing.
lilshawn
  • Moderator
  • Last login:January 26, 2026, 07:56:08 pm
« Reply #4 on: February 15, 2020, 04:59:07 pm »
i would assume you are talking about the megatouch in the great big upright arcade cabinet or slightly smaller cabinet like a pedestal (called cabaret) with like 4 games in 1?
not much to do with them...as "upgrading" them meant taking all the guts out and replacing it with new stuff (as you mention)
partycat
« Reply #5 on: February 15, 2020, 06:54:11 pm »
It's the coutertop 13" , a super IV. No buttons and the various games.
partycat
« Reply #6 on: February 20, 2020, 07:44:14 pm »
I replaced the touchscreen with an eBay part, really wasn't hard at all, cleaned up the cabinet and replaced the locks so they ... exist.
Super 4 tournament edition, works fine. I don't think the security chip is battery on this so I may as well enjoy it for now.
Thanks for getting back to me, since I really want a more modern one I'm sure I'll be back once I find one for not megabucks
