Author Topic: New Bartop Project - 19" LCD 4:3 - Spincade Classic  (Read 8522 times)
rtkiii
  • Last login:May 07, 2024, 04:42:35 pm
  • Ready to Build! Not building? Making Movies!
    • RTKIII Productions YouTube Channel
« on: February 04, 2020, 10:15:26 am »
Hey everyone,
I opened a thread asking some questions in another area and I have decided to proceed with this project.  I wanted a dedicated spinner cabinet but by the time I bought the controls and saw I was going to drop another $200 for the cabinet I changed my thinking as I could only find about 40 or so games that I'd play with a spinner.  It was tough for my mind to justify a $300+ for 40 games.  :)
I decided to go with a 4-way joystick and 3 button setup on the left hand side and then a spinner setup on the right hand side.  I have 4/8 way controllers in my main cab but I typically always use the 8 way so I thought this would be a good way to represent the 4-way games correctly.  I also wanted to stay 4:3(I know the risk) but I just am not a fan of 22"wide screen LCDs cropped so much so I found a guy on ETSY who had the setup I wanted but missing the plastics, which I i'll buy and cut accordingly.  Also cut for T-Molding but not included, $115 shipped and this is arriving today.
Using Rasberry Pii but not sure I am a fan of it as I normally just use an i5, but due to size restrictions I feel it is the only option...i'll need to test more once everything is installed.
I bought a spintrak and configured fine with Mame/RetroPi, seems fluid but it is not in the cab yet.  :)
That is all I have for now. :)
« Last Edit: February 26, 2020, 05:36:45 pm by rtkiii »
rtkiii
Re: New Bartop Project - 19" LCD 4:3 - Name not Determined
« Reply #1 on: February 04, 2020, 10:16:58 am »
Site I bought from...looks like it is down to $95, which I think is $10 cheaper and he did custom cuts.
https://www.etsy.com/listing/691438317/bartop-arcade-cabinet-kit-black-easy?ref=yr_purchases
meyer980
  • Last login:January 26, 2026, 08:20:18 pm
  • Building fun things for fun
    • sergiostuff.com/2020/04/15/felix-son-arcade-game/
    • Sergio Stuff
« Reply #2 on: February 04, 2020, 01:38:33 pm »
Good luck as you get started!
$300 to play 40 games is bad you say? Hmmm, I probably shouldn't have spent nearly $800 to build my cabinet that I only use to play 20-30 vertical classics then huh? :laugh2: :laugh2:
rtkiii
« Reply #3 on: February 04, 2020, 01:50:47 pm »
To me  :) - to each their own, right!  I built my first one for about $500(but got a legit cab for $50 which helped alot) and I have around 500 games, all tested and play well.  Yeah I'm not sure I could have done on for $800 and only two dozen games....and you clearly have morre talent...nice Fix it Felix build!  I just added this to my mame cabinet a couple weeks back for my daughter to play.  But a stand alone cab...Sweet goodness!
« Last Edit: February 04, 2020, 01:52:39 pm by rtkiii »
« Reply #4 on: February 04, 2020, 02:41:16 pm »
Sounds about right.
rtkiii
« Reply #5 on: February 10, 2020, 12:54:15 pm »
Making progress and built the cabinet and tested out retropie and things are moving along nicely but I am finding it tough to find some USB speakers for the cabinet as the speaker area is on 2 1/4" height and about 7" long.  Even the smallest, decent speakers are 3in in height at the smallest.  Curious if any have suggestions for some USB speakers I can use in the small area?
thanks
« Reply #6 on: February 10, 2020, 02:51:12 pm »
thanks
Amazon Basics speakers are 2" I think?  The case screws apart too so they are really easy to pull out and rewire.  I just cracked open a pair yesterday and can measure them when I get home.  They are definitely smaller than 3" when facing down.
I did something similar in my last project HERE.  The ones I cracked open last night are even smaller - Amazon must have updated their design.  They also completely unscrewed from the case (unlike the pics I linked to).  So you unscrew the case, pop off the front panel and then you can actually unscrew the speaker and use it however you want.
« Last Edit: February 10, 2020, 02:55:55 pm by javeryh »
rtkiii
« Reply #7 on: February 10, 2020, 04:04:24 pm »
Oh cool!  I did not think of taking the plastics off...even though I did that in my last two builds...LOL.  I guess I thought it would be easy to find super small speakers.  :)  I'll check out the basics but if you want to measure that would be helpful.
I need them to be thinner than 2 1/4" face down.  :)
These?  - https://www.amazon.com/AmazonBasics-Computer-Speakers-Desktop-USB-Powered/dp/B07D7TV5J3/ref=sr_1_3?keywords=amazon+basics+speakers&qid=1581368699&sr=8-3
rtkiii
« Reply #8 on: February 11, 2020, 02:55:37 pm »
Ordered amazon basic speakers to see if those will work out.
Ordered t-moding - white
Ordered some mounting feeet
Ordered some LED buttons(6 white, 2 red and 1 green) but need to find a LED controller.  I am not going to go with LEDPAC(or whatever it is called) this time around as I do not plan on doing anything too fancy, just light up.  I had just regular happ buttons but I am not feeling the yellow and blue buttons I have.  Been looking for a certain style button and stumbled across the ones I chose to go with when I was getting t-moding and feet.
rtkiii
« Reply #10 on: February 13, 2020, 10:25:59 am »
I had a constant hum/buzz in the speakers so I have returned those and bought something else.  They did not sound "horrible" when the games were playing but the buzz was always in the back of my mind.  What did I expect for $13  :) - LOL
We will see if that pan out.
« Reply #11 on: February 13, 2020, 10:47:46 am »
Oh man... my hearing is crap probably because of decades of headphone use so I probably don't hear anything.  Or maybe you got a bad set?
 :dunno
rtkiii
« Reply #12 on: February 14, 2020, 01:18:13 pm »
I put the t-modling on the the cabinet.  I was surprised the TModiing cut went along the bottom of the sides.  I was planning on feet so it will not slide around but I worry the tmold cut will be too big for the screw that goes into the foot.  I have not done a bartop before but if I do tmodling along the bottom does that keep the cabinet from sliding on smooth surfaces?
firedance
  • Last login:Today at 01:36:18 pm
« Reply #13 on: February 14, 2020, 01:28:52 pm »
on my bartops i mounted the feet on the bottom not on the edges -
http://forum.arcadecontrols.com/index.php/topic,158182.0.html
post #10 shows the feet
they are supposed to go on a toilet seat  ;)
rtkiii
« Reply #14 on: February 14, 2020, 01:44:00 pm »
Oh YEAH!!!!  That makes sense....yeah I'll do the bottom...LOL.  I feel like an idiot...ha!
firedance
« Reply #15 on: February 14, 2020, 02:03:16 pm »
remember, there are no stupid questions  ;)
plus it gives you just enough room to get your fingers underneath to pickup the bartop when you want to move it :)
rtkiii
« Reply #16 on: February 20, 2020, 03:19:54 pm »
This is coming along nicely.  I have the buttons and controls in, I have the t-molding installed, monitor and sound bar installed.  Seems to control well.  working on LED buttons.  I bought 12v versions on accident and trying to get PS for them, ordered and on its way.  I will post a picture soon
But I am looking for some ideas on the control panel graphics.  Normally I do just a paper printout of some sort with graphics and 1/8" plastic sheet to protect it.  Well my LED buttons are barely 3/4" long to get through the 3/4" CP and so I do not have the room for the plastic.  So I am hoping to find a good quality, thin plastic printable graphic CP design(that I design but someone else prints) to use.  I do not really want a sticker but will use if that is the only other option.
any suggestions?
Thanks,rich
rtkiii
Re: New Bartop Project - 19" LCD 4:3 - Spincade Classic
« Reply #17 on: February 26, 2020, 05:37:57 pm »
Working on graphics and marquee.  Decided on name "Spincade Classic"  :)
CP pretty basic so I dont have to measure out holes...but that might change
rtkiii
« Reply #18 on: February 26, 2020, 05:39:42 pm »
Marquee Draft
« Last Edit: February 26, 2020, 09:24:53 pm by rtkiii »
rtkiii
« Reply #19 on: February 26, 2020, 05:44:53 pm »
Cab progress.  Everything is wired up except the power, which i will get done this weekend.  Need to get some bigger feet because LED lights on bottom of cab did not emit light.  LOL
Need to figure out a theme for RasPi as well...using this comic one since it is 4x3 as a start.
« Last Edit: February 26, 2020, 05:48:58 pm by rtkiii »
yamatetsu
  • Last login:Today at 01:11:07 pm
  • Just because.
« Reply #20 on: February 29, 2020, 11:15:39 am »
« Reply #21 on: February 29, 2020, 01:31:27 pm »
That bezel art lined up nice, didn't it?
Looks good.
rtkiii
« Reply #22 on: March 02, 2020, 08:31:15 am »
Someone photo-shopped that in  :) - might be a little too much blue for me but thanks
rtkiii
« Reply #23 on: May 04, 2020, 03:07:57 pm »
CP graphic installed.
rtkiii
« Reply #24 on: May 11, 2020, 10:23:13 am »
Did more tweaking to marquee and think I am going to go with this one.
Kingcade
  • Last login:January 17, 2025, 10:50:45 pm
  • Building a steampunk arcade cabinet
« Reply #25 on: May 11, 2020, 10:32:56 am »
Nice Marquee design! I definitely think this version is the best.
KINGCADE - my Steampunk Wild West penny arcade-style cabinet
http://forum.arcadecontrols.com/index.php/topic,161105.msg1697383.html#msg1697383
rtkiii
« Reply #26 on: May 11, 2020, 01:44:08 pm »
Thanks...yeah I usually throw some ideas out and then walk away for awhile and then come back and tweak  :)
