Author Topic: Can feel electricity from the screws near the controls?  (Read 2579 times)
Ekleo
  • Last login:March 01, 2020, 11:54:22 pm
« on: December 22, 2019, 08:19:31 pm »
I'm fairly new to collecting machines, so I'm not sure if this is a common problem or something you can fix, but I just bought a Namco Ms Pacman/Galaga machine and after playing for a bit, noticed you can feel a bit of electricity from the screws/pins around the controls. It's not much and doesn't hurt, but it's still a bit annoying cuz you can't rest your hand over them without feeling a little electricity.
Is there a way to fix this? Is there some sort of grounding issue? Maybe static from the monitor?
« Last Edit: December 22, 2019, 10:51:20 pm by Ekleo »
  • Last login:September 02, 2025, 11:42:36 pm
Re: Can feel electricity from the screws near the controls?
« Reply #1 on: December 23, 2019, 12:34:34 am »
Check your ground connections in the cabinet.  Check for continuity between them and the ground pin on the plug.  Make sure your plug has a ground pin.
jdbailey1206
« Reply #2 on: December 23, 2019, 08:44:51 am »
Yes.  Yes and yes.
Be careful with this.  Electricity is no joke.
Ekleo
« Reply #3 on: December 23, 2019, 09:06:15 am »
Thanks! I didn't know too much about ground plugs before your post but after looking more closely, the people who owned the machine before me apparently cut off the ground pin from the plug. I'll be replacing that plug immediately and hopefully that fixes it!
« Reply #4 on: December 23, 2019, 12:18:57 pm »
That will fix it.
Ekleo
« Reply #5 on: December 23, 2019, 04:51:44 pm »
That will fix it.
Just replaced it and it's all good now! Thanks again!
