Author Topic: kade 2.0  (Read 1883 times)
scroeffie
kade 2.0
« on: November 26, 2019, 12:40:01 pm »
iam using kade 2.0 with a og xbox so far i like it but some games wont load wit ninja ,so i was thinking i want to move to a rasberry pi
does the kade work with the rasberry pi and is it plug and play ,no need to flash the firmware etc !?!?
  • Last login:Today at 02:09:19 am
Re: kade 2.0
« Reply #1 on: November 26, 2019, 01:45:01 pm »
If you programmed it with Output Mode set to "Auto detect" (the default setting), the KADE miniArcade 2.0 should auto detect whether connected to an Xbox or a RasPi and change the Output System to "Xbox" or "Generic USB/HID Joypad" accordingly.
If you programmed it with Output Mode set to "Force Xbox", you'll need to reprogram it using the Mapper program.
scroeffie
Re: kade 2.0
« Reply #2 on: November 26, 2019, 02:42:15 pm »
i did not program anything bought it from bruno as is
Re: kade 2.0
« Reply #3 on: November 26, 2019, 03:04:11 pm »
He probably used default settings, so it should work with a RasPi.
Worst case scenario, grab the download package containing the Mapper program and User Guide from the link in this post and follow the directions to reprogram your encoder.   ;D
scroeffie
Re: kade 2.0
« Reply #4 on: November 26, 2019, 03:05:45 pm »
thanks i wil try this in the future or use coinops with the xbox
