Author Topic: Hantarex Polo horizontal collapse (SOLVED)  (Read 4610 times)
perjmolsen
  • Last login:December 08, 2022, 04:09:06 am
  • I want to learn, and try.. I NEWER give up :)
    • My gameroom
« on: October 25, 2019, 04:18:25 pm »
Hi
Help :)
I have a Hantarex Polo with horizontal collapse. - What do I overlook?  :banghead:
I have checked the volts - they all seem OK
TP6    145V
TP10 11.9V
TP8 27.9 V
TP9 16.3V
TP31  27V
Tested
R177
R167
Changed the following parts but still horizontal collapse
IC103
C144
C142
C137
IC104
Need the experts!  :notworthy:
« Last Edit: October 27, 2019, 03:57:40 pm by perjmolsen »
princess prin prin
  • Last login:Yesterday at 12:29:44 pm
  • intrinsically safe
Re: Hantarex Polo horizontal collapse
« Reply #1 on: October 26, 2019, 04:33:25 am »
Dodgy yoke connection? Are those croc terminals actually making contact?
D127? C401? VR402 (V.AMP)? Reseat control board.
perjmolsen
    • My gameroom
« Reply #2 on: October 27, 2019, 03:57:13 pm »
Hi  :cheers:
Well... I have done it again!   ::)
I had tested D127 in the past... It tested OK..
But I had again forgot to solder the leg in, that i had lifted to test the diode...
Somehow.. when I solder the parts in things work alot better  ;D
So the solution to the collapse where just to put som solder on the leg  :laugh:
Mr. Peabody
  • Last login:November 11, 2025, 07:08:52 pm
Re: Hantarex Polo horizontal collapse (SOLVED)
« Reply #3 on: October 31, 2019, 01:40:08 pm »
Well.....
