Author Topic: Any good Arcade Monitor calibration procedure?  (Read 2229 times)
agalardi
  • Last login:March 21, 2020, 02:46:05 pm
  • Be water my friend....
« on: October 22, 2019, 01:34:01 pm »
I have a 21" arcade monitor and I am far away from a good calibration. I tried a lot but I am not good at it.
It would be great if someone have a step by step calibration guide/procedure/instructions.
I would be perfect if it comes with some calibration images with some kind of scale. Something like: "step 4: open img4 and adjust red until you can see between X and Y"... and so on.
Maybe It is not possible to get a guide like this...  :dunno
behrmr
  • Last login:April 23, 2021, 09:17:13 am
Re: Any good Arcade Monitor calibration procedure?
« Reply #1 on: October 22, 2019, 01:46:40 pm »
Color balancing is always going to be subjective. The key is to get your black and white levels the way you like then go from there.  On Youtube, buffet has a decent video on how to color balance a Sanyo.  The process is very similar to all monitors (except Sanyo has 3 brightness controls) so you might want to take a look at that.  Start watching after he is done setting the B+.  Here's a link to it  https://youtu.be/HASKqAOwLms?t=790  There are other videos out there try searching for "how to color balance arcade monitor"
agalardi
« Reply #2 on: October 23, 2019, 01:49:46 pm »
Thank you behrmr, I will try
