Author Topic: Trouble replacing RGB light on a joystick connected to an LEDWiz  (Read 2203 times)
mhermann
  • Last login:October 04, 2019, 07:10:08 pm
  • We ain't found.........
Hello all. Haven't been here in a long while. Hope everyone is well.
Anyway, one of the RGB lights went out in one of my joysticks. I had someone wire this for me years ago so I am not sure how to fix it. I was able to remove the old RBG light from the joystick and the LEDWiz.
I bought a replacement from Paradise Arcade:
RGB 5mm LED
Model PAS-Joy5MMLED-RGB
Custom made 5mm RGB LEDs with leads our hollow shafts, great LEDS to light your balls!
https://paradisearcadeshop.com/home/products/paradise-arcade-exclusive-products/556_rgb-5mm-led?search_query=rgb&results=94
I connect the R-G-B to the LEDWiz ports 1,2 and 3. Then I connect the black wire which I believe is power to where the old piece of the wire from the last RGb was as it is then "combined" with the wires from the 7 push buttons and goes into the 5v port.
The Green and the Blue work fine. But the Red starts strong and then seems to die.
I am sure it is user error, I am just not sure what.
Mr. Peabody
  • Last login:March 05, 2025, 05:44:10 pm
Re: Trouble replacing RGB light on a joystick connected to an LEDWiz
« Reply #1 on: October 02, 2019, 02:58:23 pm »
Check schematics and voltages.
mhermann
« Reply #2 on: October 02, 2019, 05:12:03 pm »
Ok. Not really sure what I am checking for. Looks like I need to do some learn'n :)
I figured the R G B go into ports on the LEDwiz and then I just put the 5v into the 5v port of the LEDwiz.
I think this is what I just don't really understand:
"Please note these do not have resistors installed so they will need a current control circuit (or resistor) to run properly."
Do I just purchase a resistor and put it inline between the RGB light and the 5v input?
I have never gotten down to the level of schematics and voltages. Looks like I need to start.
Thanks for the reply.
mhermann
« Reply #3 on: October 04, 2019, 07:10:08 pm »
Figured it out. It was simple for most people but I am a little electrically challenged. Just had to figure out the proper resistor and unfortunately resorted to electrically tape. Next time I may buy a soldering iron so I don't feel like hack.
