Author Topic: Cabinet Building Designs, Cut Sheets, and Blueprints  (Read 18495 times)
Alaska
  • Last login:January 02, 2025, 06:25:46 pm
  • Fight inflation not farmers
« on: September 30, 2019, 04:58:34 pm »
Use this thread to post your custom cabinet designs, cut sheets, blueprints, or other helpful pictures or links to other forum threads showing cabinet building designs and similar topics.
**EDIT 5/4/2020**
Links to cabinet plans will be compiled at the top of this thread, as shown below:
https://www.classicarcadecabinets.com/ Great site with tons of classic cabinet plans including Donkey Kong and Asteroids.
https://www.tested.com/art/makers/463926-designing-cocktail-arcade-cabinet-sketchup/ Cocktail cabinet walk through with cut sheets
« Last Edit: May 04, 2020, 01:45:54 pm by Alaska »
Alaska
Re: Cabinet Building Designs, Cut Sheets, and Blueprints
« Reply #1 on: September 30, 2019, 05:02:41 pm »
These cut sheets were shared with me in 2015 by a_netanl. Forum post can be found here:
http://forum.arcadecontrols.com/index.php/topic,149595.msg1563207.html#msg1563207
« Last Edit: September 30, 2019, 05:08:39 pm by Alaska »
  • Last login:August 31, 2025, 06:21:11 pm
« Reply #2 on: October 03, 2019, 12:26:42 pm »
Not really plans, but here are the measurements of my cab.
It's based on my own preferred ergonomics, not any actual arcade cabinets.
It has worked out well for me.  After years of using it, I wouldn't change any of the ergonomics or screen angle.
It is 32" wide to allow the 27" monitor to rotate.  Wide enough for some 32" LCD TVs to fit.
It think it would look better 24" wide, but I'm old.
Alaska
« Reply #3 on: October 03, 2019, 06:04:06 pm »
Great layout!
pjkjr
  • Last login:March 02, 2020, 07:39:39 am
« Reply #4 on: November 05, 2019, 07:12:08 am »
I have been searching and searching for a design I liked that i wanted to use for my first build coming up. I think I have found it! Thank you for posting this!
JohnnyJedi
  • Last login:May 28, 2020, 07:34:53 pm
  • I want to have 10k games on my arcade machine
« Reply #5 on: April 24, 2020, 10:19:56 pm »
This topic should be a sticky or some other one that includes cabinet schematics for the forum.. here are mine...
Only two 4' x 8'  panels needed to build a full arcade cabinet..
Just help others because its the right thing to do...
My first Full Cabinet Build http://forum.arcadecontrols.com/index.php/topic,162377.0.html
howie2673
  • Last login:November 28, 2021, 05:56:57 pm
« Reply #6 on: April 24, 2020, 10:25:05 pm »
Thank you all for the help on building a cabinet
Sent from my SM-N975U using Tapatalk
Alaska
« Last Edit: May 04, 2020, 01:45:02 pm by Alaska »
