Author Topic: FS: 3" Happ Golden Tee Trackballs  (Read 13870 times)
mp2526
  • Last login:August 11, 2023, 02:30:47 pm
    • Miavio
Re:FS: 3" Betson Imperial Trackballs
« Reply #40 on: June 16, 2004, 02:39:00 pm »
Does anyone know if the HAPP surface mounting plate (the one with no bolts/screws showing) will work with the Betson Imperial Trackbal.
I had to sand down the powder coating on the posts to get them to squeeze into the holes on my betson, but it did however work.
jbeersm
  • Last login:May 13, 2005, 02:53:45 pm
  • Never grow up...
« Reply #41 on: June 16, 2004, 02:41:05 pm »
Okay, Thanks for the info.
sfetaz
  • Last login:March 11, 2008, 12:58:28 pm
  • DDR4LIFE
    • Home of DDR Machine Rentals and The Madison Square Garden DDR Championships!
« Reply #42 on: June 23, 2004, 03:33:17 am »
Please PM me I am highly interested.  Thanks!
SirPeale
  • Green Mountain Man
« Reply #43 on: June 23, 2004, 08:42:23 pm »
PM sent.
jcoleman
  • Last login:March 15, 2025, 04:12:49 pm
  • RTFM
« Reply #44 on: June 23, 2004, 09:35:16 pm »
Peale, do the optic boards in your trackballs work with the minipac?  If so, I could use any extras that you have.
Coleman
SirPeale
« Reply #45 on: June 23, 2004, 09:36:26 pm »
They're a standard trackball; I have not tested it (I don't have a MiniPAC) but there is no reason why it should not.
Witchboard
« Reply #46 on: June 23, 2004, 10:31:27 pm »
The only thing the Mini-PAC site says is,
The full wiring harness for 28 switches and optical controls is available in two versions, for either Happ or Ultimarc trackball. Note that the Ultimarc trackball must be the special version listed for the Mini-PAC. The board will not work with the Suzo/Wico trackball.
Hope this helps.
SirPeale
« Reply #47 on: June 24, 2004, 08:13:54 am »
Hope this helps.
Whoa!  Thanks for posting this, Witchboard!
jcoleman
  • RTFM
« Reply #48 on: June 24, 2004, 09:49:26 am »
The problem is that I have an Imperial/Betson TB already and I can't get it to work...my OSCAR spinner work fine on the tb inputs, though, and the tb worked fine before I hacked one of the boards to take out the PS/2 mouse functionality...
Coleman
sc1103
  • Last login:December 11, 2020, 08:37:35 pm
« Reply #49 on: July 09, 2004, 07:49:25 pm »
Peale can you check your PM? Thanks
SirPeale
Re:SOLD! 3" Betson Imperial Trackballs
« Reply #50 on: October 21, 2004, 07:31:01 pm »
Hm...looks like I'm coming into some more trackballs shortly.
AmericanDemon
  • Last login:September 22, 2019, 11:08:03 pm
  • Still an AmericanDemon
Re:FS: 3" Happ Golden Tee Trackballs
« Reply #51 on: October 21, 2004, 08:44:18 pm »
Keep us up to date.  I'd be interested in one.
Peter Baluk
  • Last login:September 30, 2006, 10:36:37 am
  • heavy load! in Brantford ,Ontario
« Reply #52 on: October 22, 2004, 09:41:12 pm »
so are these Happ or Betsons?
IF IT HAS ,TIRES
SirPeale
« Reply #53 on: October 22, 2004, 09:42:55 pm »
These new ones are Happ.
wdw_ryan
  • Last login:December 15, 2004, 12:19:38 am
« Reply #54 on: October 23, 2004, 01:33:59 am »
Are the Happ ones Golden Tee or do the have the light bulb harness?
Thanks,
Ryan
SirPeale
« Reply #55 on: October 23, 2004, 08:27:05 am »
I got them in a bulk lot.  Won't know much more about them until I have them in hand.  I can tell you that they were advertised as Happ Golden Tee trackballs.
AmericanDemon
« Reply #56 on: October 23, 2004, 09:05:01 pm »
When do you think you will have them in hand?
Mamezilla
  • Last login:February 07, 2026, 01:16:30 pm
« Reply #57 on: October 23, 2004, 10:09:13 pm »
Peale,
If those trackballs are the same that the first bunch you had, I'm interested into getting one of those.  I've sent you a PM about this.
Don't throw rocks to a man with a machine gun
-- Rowdy Roddy Piper --
SirPeale
« Reply #58 on: October 24, 2004, 08:34:05 am »
I should have them in hand within a week.  They're coming from .ca
I will post when I have them in hand, and once they're cleaned, lubed and tested I'll post that they will be for sale.
(shameless plug here for the quick disconnects I've got as well, see my sig!)
« Last Edit: October 24, 2004, 08:37:14 am by Peale »
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
« Reply #59 on: October 24, 2004, 02:41:58 pm »
Think one of these 3" trackballs would look stupid in a midway cocktail control panel?  They're pretty big.
I wouldn't be playing golden tee with it, but I could see myself playing centipede.  How big is the mounting hardware?  I've only got 5"x9.5"x3" to work with (HxWxD)
thanks,
-jeff!
this was my solution  ;D
the trackball CP is 14" wide
http://www.arcadecontrols.org/yabbse/index.php?board=10;action=display;threadid=25687
the GT 3" TB is great !
« Last Edit: October 24, 2004, 02:42:43 pm by rchadd »
Pacific Ripper
  • Last login:May 14, 2008, 12:14:30 pm
  • Tearing it up like a rag doll.
« Reply #60 on: October 24, 2004, 11:09:44 pm »
I'm also interested in getting one of those trackballs from you when they're available. If possible, could you please PM me when they are available?
EvilNuff
« Reply #61 on: October 26, 2004, 08:07:41 pm »
I'd be interested if you get more in as well.
AmericanDemon
« Reply #62 on: November 15, 2004, 06:08:41 pm »
Anything New on Peale?  Oh the suspense.
SirPeale
« Reply #63 on: November 15, 2004, 06:21:19 pm »
I have the trackballs, but have not had the opportunity to do what I need to do to them.  Like the black buttons, I hope to have them done by week's end.
AmericanDemon
« Reply #64 on: November 15, 2004, 07:30:05 pm »
Rock on.  ;)
armax
  • Last login:July 12, 2017, 07:20:15 pm
  • Game Not Over
Re: FS: 3" Happ Golden Tee Trackballs
« Reply #65 on: November 23, 2004, 04:48:32 am »
I'll take one.
