Author Topic: NES not powering on even after recap. Now fixed  (Read 2931 times)
Locke141
  • Never grow up.
« on: July 22, 2019, 03:12:31 pm »
I got an NES front loader that was having an issue with the 72 pin connector. I fixed it and all seemed well after testing. A week later and it is no longer powering on. I just recapped everything in the RF/power box  using a cap kit. The continued testing is looking good but still no led or signal. Might it be the 17805? How does one test it?
« Last Edit: August 07, 2019, 10:13:23 pm by Locke141 »
Locke141
  • Never grow up.
Re: NES not powering on even after recap.
« Reply #1 on: August 07, 2019, 10:12:46 pm »
Fixed,
It was the linear power regulator. I replaced it with one form console5.com.
https://console5.com/store/7805-5-volt-regulator.html
  • Last login:Yesterday at 11:17:30 pm
Re: NES not powering on even after recap. Now fixed
« Reply #2 on: August 07, 2019, 10:56:02 pm »
It’s always the power supply
« Reply #3 on: August 07, 2019, 11:38:07 pm »
Nice fix.
How did you determine that? Did you pull and test it?
Locke141
  • Never grow up.
« Reply #4 on: August 08, 2019, 06:18:40 am »
Nice fix.
Kind of, I opened up the case, pulled out the board, got it all hooked up out side the case and pocked around with my multi meter. I should have pulled and tested, safer for the board that way. As PBJ said it’s usually the power supply and I had already recapped said supply.
Pick of the dead one below. I had some heat sink past on hand so cheep and simple repair.
« Last Edit: August 08, 2019, 09:44:22 am by Locke141 »
  • Last login:Today at 06:18:49 pm
« Reply #5 on: August 08, 2019, 04:07:43 pm »
Just out of curiosity how much shipping did they charge for that 60 cent part?
« Reply #6 on: August 08, 2019, 04:30:48 pm »
From console5, probably a lot.
Locke141
  • Never grow up.
« Reply #7 on: August 08, 2019, 05:14:56 pm »
Subtotal   $0.59 USD
Shipping and handling   $2.69 USD
Total   $3.28 USD
Payment   $3.28 USD
I could have got a pack of them on amazon for less per unit but I only needed one and $3.29 shipped It was close enough. Should have checked mouser and element 14.
« Last Edit: August 08, 2019, 05:17:57 pm by Locke141 »
