Author Topic: Mike A's end to procrastination  (Read 100979 times)
bperkins01
Re: Mike A's end to procrastination
« Reply #360 on: February 22, 2020, 08:45:04 am »
I bought plans for a Grandfather clock - which had spindles - so that I had a reason to buy a laythe.. Just because I wanted one..
That clock is about to turn 21..
I need to go make some pens..
« Reply #361 on: February 22, 2020, 10:35:01 am »
Haha we've all been there at some point...
jennifer
« Reply #362 on: February 22, 2020, 07:12:39 pm »
CNC, seems to have it's following, And cant build a spot on, without concessions, Ultimately with varieties of results...However, The workmanship on a pre war juke, is what sold me on conventional tooling, It could be duplicated I supose, But that doesn't change the skill level of, a zero tolerance acceptance...It is truly a thing of beauty in the right hands.
  • Last login:Today at 06:46:54 am
« Reply #363 on: February 24, 2020, 08:36:54 am »
I was pretty busy this weekend but I did get a few things done.
Here are a couple of random CNC pics because no matter what I say, You guys want a CNC machine for cutting arcade cabs.
Even cutting at over 100 ipm this takes way longer than using my table saw and router. I would never use the CNC for this kind of job again unless I had a
rack and pinion machine that could cut at least 3 times faster than mine.
I left the dust shoe off so you could see everything better. With the dust shoe in place there is 99 percent less sawdust laying around.
« Reply #364 on: February 24, 2020, 08:44:52 am »
I pinned a bunch of Molex connectors.
Here are some of them.
One advantage to being single. Wiring a CP on my kitchen counter. Leaving it there overnight to work on again in the morning.
I built a shelf in my arcade room this weekend.
My Subwoofer and PA speaker take up the space of one arcade cab. They also melt your face if you are standing in front of them.
The solution was to move them out of the way. I still need to wrap the studs in cedar.
Today I am going to finally remove the old plumbing for my Aquarium. That is the white PVC you see in the pic.
Gilrock
« Reply #365 on: February 24, 2020, 09:06:25 am »
I can barely lift the 4'x8' sheets of birch plywood into the cart at Home Depot much less push it through my table saw.  It's hard enough to swing it up onto the router table.  I still prefer using the router table for large pieces like you show in that photo.  If I had a friend to help hold the material I could do it on the table saw.
Gilrock
« Reply #366 on: February 24, 2020, 09:07:58 am »
Do you have a huge table saw?  I guess if you got one that holds an entire 4'x8' sheet it would be awesome.  I've got one of those portable table saws that is only like 25" x 20" roughly.  I have to use one of those roller stands to try to catch the boards.
« Reply #367 on: February 24, 2020, 09:10:03 am »
I use roller stands, and my chop saw bench is the same height as my table saw bench. I can roll it in place to use as an out feed table.
jdbailey1206
« Reply #368 on: February 24, 2020, 09:11:41 am »
Awesome set up Mike.  But please consider a duct for the 120mm(?) fan that comes out of the top of your box.  It may extend the life of the electronics.  See below bro.
« Reply #369 on: February 24, 2020, 09:12:34 am »
I cut full sheets of ply on my barn floor.
I have a 4x8 sheet of insulation 1 inch thick that i lay down on the floor.
The plywood goes on top of that.
I set my circular saw to cut just through the plywood.
Easy and fast.
« Reply #370 on: February 24, 2020, 09:14:25 am »
I operate my machine with the dust boot in place all of the time. There is normally no dust. I leave it off when I take glamor shots.
And that fan is like 40mm. :P
jdbailey1206
« Reply #371 on: February 24, 2020, 09:20:46 am »
bperkins01
« Reply #372 on: February 24, 2020, 10:02:08 am »
Nice
Update
Arroyo
  • Last login:March 08, 2026, 05:26:58 pm
  • Budgets are boring
« Reply #373 on: February 24, 2020, 11:49:30 am »
Still jealous of that CNC.  And I gots to see it in person, it’s glorious.
Good call on those speakers, that was killing your floor space.  You’ve done some serious rearranging of those machines,  nice work!
« Reply #374 on: February 24, 2020, 11:52:32 am »
By Wednesday I plan on having the arcade put back together. I will post some pics.
« Reply #375 on: February 24, 2020, 02:43:19 pm »
Oh sweet, your CNC is up and running again. Nice.  I remember you saying you were having issues with it a little while back, but didn't know if you got it worked out.   :cheers:
« Reply #376 on: February 24, 2020, 02:54:50 pm »
Yeah. After 15 years it is starting to give me problems here and there.
The motor driver software isn't supported anymore.
I need to switch it over to Mach3 at some point.
bperkins01
« Reply #377 on: February 24, 2020, 05:04:39 pm »
Nice wiring job  ;)
« Reply #378 on: March 03, 2020, 08:17:31 am »
Play testing with kids and adults went pretty well at my party. The first kids to arrive lunged at the cab and threw quarters in. They didn't have to receive any instructions and they were playing right away. They were all elementary school aged.
Player 3 button 2 stopped working halfway through the night. I will have to check out my wiring when I get a little free time.
Other than that everything worked great. My long time buddy was the last to leave the party and we played Trog for an hour or so.
Arroyo
« Reply #379 on: March 03, 2020, 10:01:42 am »
I hate tracking down a wiring issue.
« Reply #380 on: March 03, 2020, 10:18:05 am »
The dream!  This is exactly how it should be - everything self-explanatory, even for kids.
« Reply #381 on: March 03, 2020, 11:32:48 am »
Yeah. The first hour of my party I am stretching dough and cooking pizzas. It helps a lot that my games don't require a training course to get started.
Hoopz
  • Intellivision Rocks!
« Reply #382 on: March 03, 2020, 12:49:26 pm »
Using the longer and cooler fermentation process on your dough really made it delicious I bet.  Good job on that and on the build.   :applaud:
« Reply #383 on: March 03, 2020, 12:55:47 pm »
Thanks.
The cold rise definitely makes a difference.
jdbailey1206
« Reply #384 on: March 04, 2020, 07:57:56 am »
BYOAC ≠ Build Your Own Arcade Controls.  BYOAC = Build Your Own Appetizing Calzones.
bimm25e
  • Last login:July 30, 2024, 08:44:11 am
« Reply #385 on: March 06, 2020, 12:11:52 pm »
You can get cheap versions of these on ebay. I use them on my racing cabs where real estate is limited but i need coin/escape buttons.
bimm25e
« Reply #386 on: March 06, 2020, 12:12:52 pm »
4 player games don't usually have more than 4 buttons. But i would strongly recommend giving p1 and p2 6 buttons.
There are some VERY GOOD 1p/2p 6 button games and it is nice to have that option.
« Last Edit: March 06, 2020, 12:16:13 pm by bimm25e »
« Reply #387 on: March 06, 2020, 12:48:04 pm »
Okay. Who is trolling me?
This can't be real.
« Reply #388 on: March 07, 2020, 05:33:54 pm »
Okay. The p3 b2 problem is not a wiring issue. That button works fine in Wild West Cowboys of Moo Mesa. So I guess it is time to pull my Simpsons PCB and figure out the problem.
« Reply #389 on: March 07, 2020, 06:01:16 pm »
Hopefully you can find a schematic. Might just be a diode. My Millipede board had the test switch stuck on, and it just happened to be the diode in circuit. Swapped it out and all was golden.
