Author Topic: Nintendo cabinet build - Wreck-It Ralph  (Read 164875 times)
UnclearHermit
  • Last login:April 05, 2024, 02:08:17 pm
  • Finally started building 2019,est. completion 2036
« on: June 09, 2019, 04:41:09 pm »
Okay, here we go.  I've been planning to build a Nintendo cabinet for a while now, having been considering building an arcade cabinet on and off for far more years than I care to remember.  I'm going for a Nintendo cabinet simply because I like the look of them and not out of any particular nostalgia for Nintendo cabinets.  I don't even think I ever saw an original one growing up in the UK.
I'm doing this partly because of the hoped end result of some kind of working arcade cabinet, but just as much because I like the challenge of doing this.  I've not built anything like it before and so there are lots of new skills to be picked up along the way.
Theme-wise I'm not sure what this is yet.  So I don't know if it'll be a DK or a Popeye or something custom, so even the colour choice is yet to be made.  I've got to think through all of the questions around horizonal/vertical games, 4-way/8-way joysticks, repro joysticks or something else so I can switch 4 to 8-way etc.  But I've already spent an absolute eternity reading and re-reading all the wonderful posts on here, and capturing notes and photos as I go of all of the little parts of the cabinet to help me as I go.  My thanks to all of those people who have invested their time to provide such great posts for others like me to follow.  I'll try to post as I go to try and give something back for others in the future, including all of the mistakes I'm likely to make along the way.
I'm using the Gaetan plans and already have a 1-1 print and have started some panel cuts, but I'm finding inconsistencies between the 1:1 print, the measurements on the plans/dxf files etc.  For instance, my printed 1:1 control panel is a couple of mm different in size to what the plans say it should be, and similarly the dimensions shown on the pdf seem to be a couple of mm different to what I find if I take measurements off the dxf files.  So I'm having to be careful to make sure that I don't end up with panels in different widths across the cabinet.
And so to my first question.  The interior horizontal panel which forms the bottom panel for the marquee, and which support the vertical panel holding the marquee light, is shown on Gaetan's plans as 10mm deep.  But I see photos (I think from Chance when he and Gaetan were taking measurements for those plans) that show it as 8mm deep.  I'm build this thing out of 15mm MDF, and will live with the pros and cons of that decision, but either way I'm probably going to struggle to find some that's either 8mm or 10mm.  The depth of the panel is presumably going to impact either the space for the bezel or the space for the marque, so I'll probably end up buying some 1/2" MDF and then routing off a few mm at the front.  But is it supposed to be 8mm or is it supposed to be 10mm?
Photos of some initial "work" to follow, once I figure out how to upload to the photos thread and link here...
thanks
Mike
« Last Edit: April 27, 2020, 06:15:22 pm by UnclearHermit »
UnclearHermit
Re: Nintendo cabinet build with undetermined theme
« Reply #1 on: June 09, 2019, 06:49:03 pm »
Let's try a couple of pictures.  This has always seemed convoluted but I'm sure there's a good reason.  Hopefully these will show up..
I ordered a 1:1 print of the Gaetan plans a little while ago from planprint-it.co.uk, which cost about £18 once delivery was factored in.  They have a minimum order of £10 before VAT, so I added in the other non-1:1 diagrams just to bring the cost up to the minimum.
I then went around the large print with a craft knife and a metal ruler and carefully cut it out.  This wasn't actually too bad to do.  It's just a question of taking the time rather than rushing the cuts.
I don't have the confidence/experience with the wood to go straight onto the final MDF for these, but I didn't want to use a full-size template either just to keep costs down (some hope).  So I used an old piece of smaller 1/4" MDF and transferred onto it the corners and angles from the full size cabinet side.  I figured that I didn't really need a template for the straight lines!
This was all a while ago now.  I've found that I have not a lot of free time to progress this, and when I do progress it I seem to be very slow :)  So I've got a bunch of pictures that I can post when time permits to bring things up to where I am now.  At least it'll feel like progress in the thread, even if I'm not making much in reality!
UnclearHermit
« Reply #2 on: June 10, 2019, 10:43:33 am »
You can see here the small piece of 6mm MDF that I used the template the corners/curves.
I traced the outlines from the 1:1 sheet onto the various sides/corners of this piece of wood and then cut using a jigsaw, followed by some routing off the straighter edges and sanding for the curves.  For the internal curves I wrapped a bit of sandpaper around a spray can lid I had lying around, to make it easier the sand the curves without destroying them in the process.  Apart from the bit on the right that I caught by going a little too far with the router this generally went okay.  A bit of filler mostly fixed up the routing mistake.
For the final cut onto the first side of 15mm MDF I traced around the 1:1 paper template and rough cut with the jigsaw.  It's been a long time since I used a jigsaw and my memory was me being pretty terrible with them, so I was pretty pleased to find this bit going well.  Once I had the rough cut I simply overlaid the MDF template onto the various curves/corners once at a time and used the router to clone the template.  Whilst doing that I somehow managed to get the router to gouge a hole into my wood around the control panel area, and thought I must have accidentally tilted the router or something.  You can see the rough repair in the image below.
This kind of damage is irritating, not just because of the damage but because it then delays things while I have to wait/sand/fill/wait/sand etc.  Anyway, once I'd repaired this latest setback I was able to get the completed side clamped onto the second MDF sheet ready to be traced, rough cut and then cloned.
More to follow when the image thread doesn't think I'm violating some kind of security...
« Last Edit: June 10, 2019, 10:46:53 am by UnclearHermit »
UnclearHermit
« Reply #3 on: June 11, 2019, 05:07:17 pm »
No idea what the security violation was, but I've resized the next images and then they seem to upload fine.
Patched up side section.
I'm using a lightweight filler for this and I might need to change that if I have more problems.  It's a bit TOO lightweight, so it's easily dented.
With the damage repaired and the second size roughly cut out I set about clamping and cloning the first side.
Things went fine for a while and then the router bit into the wood again.  This time I knew I'd been holding it straight so I stopped to figure out what was going on.  It turned out that the bearing on the router bit was able to move upwards, and so it was moving up above the piece I was cloning and so the bit could bite into my wood.  This meant that it actually damaged both bit of wood in the process.  This is obviously my inexperience with not having the router bit inserted high enough to prevent this.  This is only my second project with a router; we live and learn...  Fill/wait/sand etc.  At this rate this thing will be more filler than MDF, although I suppose it'll be lighter.
Laythe
  • Last login:February 04, 2026, 08:00:11 pm
« Reply #4 on: June 11, 2019, 10:17:13 pm »
Looking good!
The setbacks are frustrating, but as long as you can fix it as many times as you mess it up, it'll all be fine in the end.
jdbailey1206
« Reply #5 on: June 12, 2019, 08:06:40 am »
I did the same thing with my FFJR cab.  I had the luxury of doing it with my slot cutter and made the slot too large for about two feet.  Like Laythe said this is the time for mistakes.  Patch it and move on.
UnclearHermit
« Reply #6 on: June 12, 2019, 01:24:51 pm »
Thanks.
Moving on, I needed to transfer the blocking markings from the 1:1 onto the wood.  Clamping it on top seemed like a good start.
Someone in another build had the great idea of making a couple of blocks to make it easy to accurately position the blocking based upon the MDF depth, with either single or double spacing.
But I couldn't think of a great way of transferring the marks from the 1:1, other than using tracing or copy paper, neither of which I had to hand. So for the large areas I just cut them out, and the cut-outs will come in handy later.
For the blocking I just cut small notches are the end of each blocking mark, and could then draw through the hole onto the wood.
UnclearHermit
« Reply #7 on: June 16, 2019, 06:02:19 pm »
Can anyone help with what the five marked holes are from Gaetan's plans?  My assumptions was that they were all related to mounting the monitor, but looking through various threads I can only see the top left two holes being used to secure a bar at the top of a monitor mount.  What are the other three for?  And do these all bolt right through from the outside of the cabinet for strength?
I'm a long way from deciding about monitor options, but I'd like to at least understand the mounting holes before I get too far down the road (especially since if I paint then I won't know where I made these marks!).
thanks
UnclearHermit
« Reply #8 on: June 22, 2019, 08:15:45 am »
A word of warning for anyone else following the Gaetan plans for this.  Don't get me wrong.  The plans are fantastic and without efforts like this it would be impossible for people like me to even start a project like this.  But I'm finding inconsistencies between the 1:1 plan and the dimensions shown on some of the other sheets, which might be issues with the 1:1 plan or might have been introduced during the printing.  A good example is the base.  I've cut this to 730mm because that's what the dimensions show it should be.  But if I measure the 1:1 plan, which is what my entire side panel measurements are transferred from, then this distance is about 736mm.  So I'll end up with a 3mm gap between the front and back panels and the base.  I think most of this will get masked by blocking and the blocking is still deep enough to not cause any structural issues, but if you're going to build from the plans then it's worth
a) checking a few of the larger measurements when you have the 1:1 print and comparing with the dimensions shown on the other sheets.
b) if you find discrepancies then take your cut measurements manually from this 1:1 where possible rather than taking/calculating from the given dimensions.
  • Last login:Yesterday at 02:56:06 pm
« Reply #9 on: June 22, 2019, 01:00:27 pm »
I'm pretty sure those holes in the sides of the cabinet are all for monitor support.  I can't remember exactly but I had to fill in a lot of them when I restored my DK+ because I preferred to support the monitor from inside (I just thought the bolts were ugly and unnecessary).
UnclearHermit
« Reply #10 on: June 22, 2019, 06:07:45 pm »
Thanks.  I must admit I thought the same about the bolts from the outside, especially when you see that they're normally bolted through the side art.  I also can't quite understand the need for bolting at all.  Looking at the cabinet design the entire weight of the cabinet, which includes the monitor, is transferred through the sides of the cabinet onto the base piece.  The base is only attached to the sides with blocking.  So if the whole weight of the cabinet can be supported with blocking then I can't see why the monitor, as a fraction of the cabinet weight, can't be supported the same way.  I might be missing something, of course!
nintendoid
  • Last login:February 12, 2026, 09:20:06 am
    • Nintendoid
« Reply #11 on: June 27, 2019, 09:50:51 am »
Great build look forward to seeing the completed cabinet and if its going to be a standard or custom finish.
  • Last login:February 13, 2026, 07:56:49 pm
« Reply #12 on: June 27, 2019, 10:13:27 am »
Blasphemy.
UnclearHermit
« Reply #13 on: July 01, 2019, 03:51:33 pm »
Thanks, and looking forward to seeing that myself  ;D
The slow progress continues, along with the mistakes 8) I cut a 1/2" recess in the rear of the two sides to accommodate the door.  It's times like this that I find myself going back over notes I've made to try and figure out things like how deep the door is, and therefore how deep that recess needs to be.  Similarly, how wide is the door and so how much does it overlap at the sides?  I think I ended up at 1/4" X 1/2" for this recess in the end.  Some of the door width measurements I saw would have left the side panels cut really thin.
The recess doesn't run all the way from top to bottom.  It stops above and below where the top and bottom rear panels attach.  Or, at least, it's not SUPPOSED to run all the way.  I'd originally cut it correctly but with a 1/4" X 1/4" slot.  When I figured that it actually needed to be 1/2" deep and cut it deeper I completely missed my "stop" markings at one end.
So out with the filler again to try and rebuild the missing section.
And after a fill/sand or two:
You'll also notice a load of masking tape already on these panels.  I might live to regret this, but I'm planning to paint the inside of the cabinet before assembly.  That seems a lot easier than trying to paint it later.  The downside is that I need to be able to attach the blocking to wood (not paint) and so I've had to carefully mask out where the blocking goes and hope that I can still see everything I need to when the tape gets removed.  I've also got to hope that I don't end up with loads of visible gaps in the paint where the tape is right on the edge of where the blocking will go.
I'm entirely expecting this all to fail horribly, but if it works then it will save me quite a bit of time painting around blocking later on.
I'm using an MDF primer, partly just to see if they're actually any good.  The last time I painted MDF I used normal white emulsion and was quite happy with that, plus I sealed the edges with a wood glue/water mix.  This time I'm just using the MDF primer.
The key thing I've noticed so far is that the fibres raised a lot less than they did with the emulsion, which isn't entirely surprising but was good news.  I only needed a light sand before moving onto a second coat.  I'm using a microfibre cloth to wipe down after sanding.  I've never tried that before, but it seemed a reasonable way to shift the dust without it just flying into the air.
I'll never understand Nintendo's logic in only painting parts of the inside of the cabinet.  I mean, I understand why the black bits are black, but the seemingly random points at which the black stops make no apparent sense.  They also seem to be different on different cabinets.  So I've gone for something similar to some that I've seen and will probably spray the areas I've currently got masked with a matt black (that's "flat" black for US readers) because the area is small.  I've never sprayed anything before so this will be an interesting experiment.  I highly doubt I'll be spraying the outside.
The other annoying thing about parts of the inside being unpainted is that I'll be left with exposed MDF faces and edges, whereas I'd far rather have things sealed to reduce potential water damage etc.
One paint question - where does the gloss black starts and stop?  In photos I've seen it seems to run along the front few inches of the cabinet, so I think that's all that's visible from the outside (but some gloss will be "inside", where you'd think there would be a risk of reflection).  I don't know what happens at the top of the cabinet where the "inside" of the sides are visible for about 15mm.  Does the gloss also cover this area, or does it transition from gloss to matt somewhere as it goes up past the front of the marquee?
« Last Edit: July 01, 2019, 05:45:23 pm by UnclearHermit »
ChanceKJ
« Reply #14 on: July 07, 2019, 04:24:37 pm »
« Last Edit: March 19, 2021, 02:15:27 am by ChanceKJ »
UnclearHermit
« Reply #15 on: July 07, 2019, 04:47:13 pm »
Thanks.  I've read so many threads, including all of yours many times, and somehow never picked up on the fact that there was laminate on the INSIDE as well as the outside.  A couple of questions, if you don't mind.
In your photo here https://www.flickr.com/photos/chancekj/18583008985/in/album-72157649587158666/ (sorry, not sure how to get a direct image link from Flickr) is that the semi-gloss laminate that you can see extend back to an inch or so behind the bezel support?  I'm assuming that means it runs vertically and appears at the top of the cabinet at the point in the image that you linked.  Makes a lot more sense why there's a solid vertical line if it's a sheet of laminate!
Also, it might be the light but that picture you linked of the side panel "inside" appears to show the semi-gloss laminate, then a tiny groove a recessed bare wood, then nearly an inch of wood that appears to have grain running horizontally and then the rest of the exposed wood running with a horizontal grain.  Is there a reason for the two wood grains that or is it just a past repair or something?  I can't think of anything I've read that would explain it.  Thanks again, and also thanks for the massive amounts of posts you've made on these cabinets over the years  :applaud:
ChanceKJ
« Reply #16 on: July 07, 2019, 04:49:43 pm »
« Last Edit: March 19, 2021, 02:15:03 am by ChanceKJ »
ChanceKJ
« Reply #17 on: July 07, 2019, 05:03:01 pm »
« Last Edit: March 19, 2021, 03:07:35 am by ChanceKJ »
ChanceKJ
« Reply #18 on: July 07, 2019, 05:05:14 pm »
« Last Edit: March 19, 2021, 03:06:51 am by ChanceKJ »
ChanceKJ
« Reply #19 on: July 07, 2019, 05:16:36 pm »
« Last Edit: March 19, 2021, 02:12:29 am by ChanceKJ »
UnclearHermit
« Reply #20 on: July 07, 2019, 06:02:00 pm »
I was just wondering about how the depth of the laminate was accommodated on the inside! Routing of that section makes sense but would certainly have been tedious and time consuming.  It's surprising that was ever cheaper/faster than just laminating the whole panel, so not surprising that the US approach changed.  I know I'm only doing a repro here, and using MDF it's hardly authentic, but it's nice to understand the original cabinet detailing to try and get something that at least feels right.
Those photos are interesting (aside from being upside down and messing with my head), especially because they also show another detail that's rarely captured in photos.  That small piece of wood that goes between the speaker panel and the front door panel is show on the Gaetan(/your  :)) plans as sitting 5mm higher than the bottom of the speaker panel.  But in your photo of the Japanese cabinet it appears to be flush, and with an unfinished end to the ply meeting coloured wood, compared with the US one which also seems flush but with black wood.  So a colour detailing difference, but also neither of those cabinets matching the one you'd used for the Gaetan measurements, which I think is shown here:
I've spent so much time trying to understand areas like this, but every time I think I've got a handle on something I find that there are multiple variants anyway!
UnclearHermit
« Reply #21 on: July 07, 2019, 06:05:57 pm »
While we’re on the topic of finish: The wood cross beam that locks in both the control panel top edge and the lower bezel bracket is actually always covered wood. Its a thin laminate in the Wood cabs, and a thicker black laminate in the US particle cabs.
Adding that to the list of things I didn't know.  Again, I don't remember ever reading that.  I assumed it was just painted.
Thanks for the bolt info as well.  That makes so much more sense now.  I couldn't understand why there were so many holes when the bracket didn't seem to require it in any photos I'd seen.
ChanceKJ
« Reply #22 on: July 07, 2019, 06:23:19 pm »
« Last Edit: March 19, 2021, 02:12:15 am by ChanceKJ »
UnclearHermit
« Reply #23 on: July 07, 2019, 06:40:35 pm »
Thanks, I’ve been through all of those albums many times already to get me to this point  :D
UnclearHermit
« Reply #24 on: July 12, 2019, 06:12:57 pm »
Spraying commences...
As I said, this is new to me.  The first things I found out are that the spray area is really small.  The second is that you can't point a can at any kind of decent angle towards a horizontal surface without it starting to splatter dots.  Luckily this wasn't a problem I couldn't deal with at this stage and a light sand got things back on track.  Having the panel vertical would probably make the spraying work better, especially because I see a lot of spray going outwards across the board and not doing much, but presumably puts me at more risk of runs.
After a few coats things are looking a lot better (yes, that's the other side panel, but they're both coming along okay).
Still a bit patchy with the primer underneath, and I also notice a bit of striping.  I do have to tell myself that this is the inside of a cabinet, but I'm also learning for if I decide to do the outside sprayed.  I'm also finding out that spraying is rather expensive.  I could have rolled on some matt black for a fraction of the cost, or even perhaps rolled on for a base coat and then finished in spray.  I've got some satin black for the front inches of the cabinet so I only really need to get the rear sections looking a bit better in the matt.
The edges soaked up a fair bit of paint, which isn't surprising for MDF but I'd hoped the MDF primer would do a better job there.  For any other edges I'll probably start with a glue coat.  I could put on more coats of the primer on the edges, but that just creates more work keeping the faces clean of any excess paint.
I'm still quite nervous about removing that tape and seeing if the blocking will be easy to locate still, and if I've left gaping gaps of wood between the blocking and the black areas.
UnclearHermit
« Reply #25 on: July 23, 2019, 05:48:39 am »
After finishing up with the matt black I moved onto a satin black (from Toolstation, UK-folk) for the front of the sides, leaving the top-rear matt.  This was going on really well until I was getting near the end of the second side when I realised a mistake.  Well, two.  Firstly, in a moment of insanity I seem to have place my "vertical line" in different places on the two sides, so my paint extends further back in the bottom area.  What I seem to have done here is to stick the masking tape on the wrong side of the line  :banghead: I've corrected that for the satin coat, but it means I'll have a random couple of cm of matt paint in the lower section on one side.  Whether I can sand that back to wood remains to be seen.
The other mistake is around the marquee support.  I'd originally taped off where the thin wood attaches to the side of the cabinet to support the marquee sides.  I'd then decided that I wasn't happy that the placement was accurate enough, because I can't quite be sure where things will end up when I assemble the various pieces.  So I removed that piece of tape, figuring that having the support attached to painted wood isn't the end of the world for something that's just there to stop the marquee sides sagging (and to block light leakage , I assume).  Unfortunately it seems that I only removed this piece of wood from ONE side  :banghead: :banghead: :banghead:
On the plus side I've removed the tape from this area and it comes off beautifully, so I'm more confident when it comes to removing the tape from other areas later.  The downside is that I now have an area that I've got to bring up to level and then get black without creating masses of paint build-up around it.  Just hoping I can do the sanding and painting justice, and it's such an annoying waste of time.  This is the point where people will tell me I should have painted the sides later on  ;)
Closer image, where you can see it after a bit of primer etc.
Wyo
« Reply #26 on: July 24, 2019, 03:29:05 am »
I love this build.  Your meticulous attention to detail is awesome.  Can’t wait to see how it turns out!
UnclearHermit
« Reply #27 on: August 15, 2019, 01:26:36 pm »
Thanks, really appreciated, especially when I feel like I'm going backwards :)
I've been on holiday, so no real updates other than the sanding and filling of the "mistake".  This feels like a bit of an endless slog because I always seem to end up with a slight dent that's still not filled or a ridge of filler that stubbornly refuses to go anywhere.  After a lot of cycles I'm still not happy with things, and to make matters "worse" I ended up with a different texture on this bit of the panel because of the repeated sanding.  The rest of the panel has a slightly mottled feel that I was quite happy with and which I hadn't really thought much about.  The picture isn't great, but hopefully gives an idea.
After sanding the problem are I ended up with a much smoother finish, especially after I discovered the delights of wet & dry sanding at 600 grit.  Where this has left me is a situation where I couldn't really have the repaired area with a different texture, so I'm having to sand down the whole thing and then touch up the spray afterwards.  On the plus side this isn't a bad finish at all, but it's extra work.  Still not happy with those uneven areas that you can see on the right, but since most will be behind the marquee then I'm getting tempted to live with it.  My fear is the slight unknown of what will stand out when the cabinet is in more natural light than its current garage home.
Again, happy to be learning this stuff whilst working on stuff that'll mostly be on the inside and that's certainly a lot smaller area than when I come to do the outside.
« Last Edit: August 20, 2019, 05:52:46 pm by UnclearHermit »
gingecko
  • I'm working on it!
« Reply #28 on: August 15, 2019, 04:52:29 pm »
I'm going down a similar road, but doing a partial assembly then take everything apart to paint individually. I made a big screw up and had already painted the base, after fixing that mess....it's "assembly and then paint!". I'll be taping everything off when I get down to paint time and probably labelling things, so I know which piece goes where. I remember that being the other problem with my first cab...I took everything apart for painting and then couldn't remember where some of the framing boards were attaching. :P
Looking good though, and I'm curious to see how it goes!
paulliadis
  • Last login:August 16, 2019, 03:45:59 pm
  • I'm just this guy, you know?
    • blog
« Reply #29 on: August 16, 2019, 03:46:00 pm »
Posts like these make me want to try to build my own Nintendo cabinet.
1-UP
  • Last login:May 26, 2020, 06:53:22 am
« Reply #30 on: August 16, 2019, 04:56:12 pm »
I know that its far too late for this build but this is the way I drew out my side panels (or I should say a router jig for side panels)...
a) Designed the whole cabinet in SketchUp from plans.
b) Reduced side panel by 3mm (to suit router).
c) Added all dimentions to side panel plan inc. radiuses.
d) Printed layout of side panel on A4 paper showing all dimensions.
e) Used those dimensions to draw it out in pencil on wood template.
f) Cut out with a good jigsaw and a steady hand!
To draw out the plan I just used a steel ruler and some big calipers to get the radiuses. As I was drawing it all up in SketchUp it made more sense to do it this way. I've only ever seen people get plans printed big, then trace them. I hope this is helpful for other builders to know there's a different way to do it. Also, I don't like the idea of tracing from a print as a lot of printers, even used by professionals, are not calibrated correctly so you'll end up with a different size particularly in the roll feed direction.
I'm also in the UK doing this same build. I have recently had delivered from US, all the marquee and bezel retainers. I can take images and show dimensions of those parts if you were thinking of making your own? (getting them from US is super expensive but they're pretty important to the build).
« Last Edit: August 16, 2019, 05:18:33 pm by 1-UP »
UnclearHermit
« Reply #31 on: August 20, 2019, 04:53:14 pm »
You're not wrong about the 1:1 sizing.  I've already found that there are differences (only mm, but they can matter) between measurements that I take from the cad drawings versus what the 1:1 print shows me, and again between what the annotated drawing says that the measurements are.  The control panel 1:1 print ends up being wider than the actual control panel is supposed to be, so at some point I need to decide if I transpose the slightly larger measurements onto that piece of wood or whether that will cause me problems if I buy pre-made Perspex for the overlay.  I'm a way off that!
I can certainly see the benefit of having that 3D model.  I'm still wondering about the exact sizing of some pieces, to the extent that some bits I'll be cutting a bit long just so that I can then trim them down once I've more confidence in exactly how big they should be.
I'm guessing shipping and import from the US wasn't cheap?  I'm still figuring out how best to obtain the various retainers.
thanks
UnclearHermit
« Reply #32 on: August 20, 2019, 06:08:36 pm »
Just a quick update to talk about masking tape 8)
I've removing the masking tape that's been hiding my paint-less areas for many weeks now.  The key part of this is the bits that cover where all the blocking will go (and hopefully fit).  I'd used a selection of "normal" masking tape that I had lying around plus some more decent masking tape (Frog Tape) that I'd bought in the hope that it would keep the lines that really NEEDED to be straight nice and need.  Taking away the tape was pretty nerve-wracking because I had images of all of the paint underneath pulling up, or the paint surrounding the tape doing the same, but so far so good.  What's interesting though is the difference between the cheap and the "quality" tape.
This is where the cheap tape was.  Note the bleeding of the white primer at the edges, but also the large amounts of sticky stuff left on the surface of the wood.
Now contrast this with the decent stuff.  Sharp edges, and no stickiness AT ALL on the wood.
I'm pretty pleased at this sharp line between the matt black and the satin at the front of the cabinet.  Okay, this line won't be visible at all from the outside, but it's still nice :)
I'm sure the masking tape experts around here are thinking, "Well, duh, the decent stuff is better" but hopefully this will make another newbie like me take notice that there really is a difference and not just a shiny box and brand name!
gingecko
« Reply #33 on: August 21, 2019, 03:21:19 pm »
Notice taken! ;)
[Edit] I'll likely be using Scotch Blue tape, as that's what I've used in the past. Not sure if it would yield as clean of a line, but so far I don't have any plans for something quite as exact.
« Last Edit: August 21, 2019, 03:25:47 pm by gingecko »
UnclearHermit
« Reply #34 on: August 22, 2019, 03:49:58 pm »
I'm sure that'll be as good.  It's more about not using the cheapest masking tape you can get your hands on, which is my usual approach  ;)
UnclearHermit
« Reply #35 on: August 22, 2019, 04:09:30 pm »
And so to the other mistake, where I positioned the masking tape on the wrong side of my marked vertical line in the bottom half of the cabinet.  When I sprayed the satin part at the front I laid another piece of masking tape in the correct place, so that coat is fine, but I knew I was left with the matt black and primer underneath to try and sort out.  Again, this is the inside of the cabinet that nobody will see, but I really didn't want one side with the line in a different place to the other..
Having removed all of the tape and paper in the area I unmasked the offending line and lay a new strip of tape to protect the satin coat and to give me a line to clean up to.
I then scored down the edge of the tape with a knife to give me a clean cut to work up to.  Then I started off removing paint with a scraper.
I held a metal rule on top of the tape when I wanted a better edge to work against, or when I thought the tape was in particular danger.
Once I'd removed most of the black and was down to the primer I moved onto sandpaper, using paper wrapped in a wooden block for the most part and using the edge of the sandpaper along the ruler line.  I'm never going to get this perfect without creating other problems by taking the surface off the MDF too much, and I'm also conscious of time here.  But here's how the lower section looked after a bit of sanding.
Once I knew it was possible from the lower section I finished off the rest of it.
And removed the tape again...
Okay, not perfect, but I think this will do.  On to the other side next, which is mostly painted but on which I've started sanding down the visible parts of the satin so that they're smooth and not mottled.  Then I can start to think about attaching the blocking.
gingecko
« Reply #36 on: August 23, 2019, 11:52:19 am »
That paint finish looks really slick out in the light. You mentioned wet/dry sand at 600 grit? I've read so much conflicting information about painting MDF, that it's maddening. I'm planning to roll on oil primer and paint. I've heard you just need to 'scuff' the MDF faces beforehand. I'm curious what process you're using?
UnclearHermit
« Reply #37 on: August 23, 2019, 06:10:36 pm »
I think I might have run a sanding block over the MDF before painting, but if I did then it was for a couple of minutes over the surface.  I then rolled on an MDF primer, as much out of curiosity to see if "MDF primer" actually did anything special.  You can see that application (probably second coat), complete with the roller lines in the image here.
As I mentioned above, the primer seemed to make the MDF fibres raise a bit less than just an emulsion coat and so probably reduced sanding between coats a little.  Sanding between coats was just a few minutes with a sanding block to take those raised fibres down again, then brush down, then wipe down with a micro-fibre cloth (which wasn't happy at this stage because the surface is still quite "rough" even though it doesn't feel it to the hand) then a second coat of primer.  After the brief sand and cloth wipe (much easier on second coat) I moved on to the matt spray.  A few coats of that got me the coverage I needed, then I sprayed the satin on top of the areas that needed it.  The micro-fibre cloth gets better with each coat, and is now invaluable for just wiping off the layer of dust that always descends.
The wet & dry only really came in because I was working on that repair at the top of the cabinet where I'd put masking tape where it wasn't needed, and the smooth coat only came about because of the need to repeatedly fill & sand that repair job.  But now that I've had to extend that look to the rest of the visible satin areas I just relied on wet & dry with the 600 grit to remove the more mottled texture that I previously had.  With the second side of the cab I'm reducing time by only doing this on the areas that will actually be visible, leaving the mottled texture on bits that are truly inside or which will be covered by the cabinet front etc.  But it doesn't actually take much time with the 600 to take most of the mottling away and get down to a smoother coat, although my "repair" area is still a bit smoother I'd say.  All I'm doing is spraying the area lightly with water and then sanding over with the 600 grit wrapped around a block, then wiping off the paint that comes away.
I've not decided what I'm doing with the outside yet but there's a good chance I won't be able to get the right colour (/afford!) to spray-can the outside.  The only other piece of MDF I've painted in the past was done (with a foam roller) in white emulsion, and I ended up with the same mottled texture, which was fine for what I was doing there.  But I'm very tempted to test out that same approach and then use the wet & dry to see if I can get a flatter finish.  That's one to try on a smaller piece of test material before I commit to an entire cabinet exterior!  I've actually found the spray cans pretty good to work with despite my complete lack of experience, aside from losing time to some occasional splatter damage, but it's a lot more expensive than a tin of emulsion.  Another option would be a sub-coat in emulsion and then topped out with spray, but the colour match would have to be pretty near identical for that to work with any real savings.
Laythe
« Reply #38 on: August 24, 2019, 03:15:35 am »
Looking good!
I've been doing a lot of wet sanding of foam-rolled latex paint and I'm getting good results.  It's worth a try on a scrap piece.
My process has been something like
  roll, wetsand, repeat until you've got no glossy pits remaining of residual orange peel
  then novus #2 polish on a rag if some gloss is desired.
gingecko
« Reply #39 on: August 24, 2019, 02:27:14 pm »
Do you guys start with a different grit and work up to 600 or just stick with 600?
