Author Topic: help using mameWah With joystick  (Read 2878 times)
TeutonicDarkness
  • Last login:July 16, 2019, 10:54:16 pm
« on: May 29, 2019, 10:51:15 pm »
Hello,
 I have used the  old version of MameWah for years because I have a program that makes it easy to configure and it just
did everything I needed flaWlessly. NoW I'm using a joystick and it Wont Work.
Using the latest MameWah I can scroll the game list but can't seem to get get buttons set up to start game.
Buttons Work in everything but MameWah. Cant get Joy1button8 to take am I setting something up Wrong.
and please overlook any mispellling or odd caps here this keyboard is going hayWire ( not my mame pc but my internet one.
TeutonicDarkness
Re: help using mameWah With joystick
« Reply #1 on: May 31, 2019, 10:10:35 pm »
Reading the documentation listed in ctrl.txt
'Joystick Inputs (?=device no.):
JOY?_LEFT
JOY?_RIGHT
JOY?_UP
JOY?_DOWN
JOY?_IN
JOY?_OUT
JOY?_ROTATELEFT
JOY?_ROTATERIGHT
JOY?_ROTATEUP
JOY?_ROTATEDOWN
JOY?_ROTATEIN
JOY?_ROTATEOUT
JOY?_SLIDER0INC
JOY?_SLIDER0DEC
JOY?_SLIDER1INC
JOY?_SLIDER1DEC
JOY?_POV0-3_LEFT
JOY?_POV0-3_RIGHT
JOY?_POV0-3_UP
JOY?_POV0-3_DOWN
JOY?_BUTTON0-31
However when I try adding this
LAUNCH_GAME         "DIK_1 ¦ JOY1_BUTTON8"
to mamewah.cfg I get no results.
What am I missing the joystick works just not buttons. Do I have to enable buttons
somewhere else?
Nuexzz
  • Last login:October 01, 2023, 01:26:58 am
« Reply #2 on: June 01, 2019, 05:16:10 am »
Maybe you are setting the wrong file.
be sure of the following route "Mamewah \ config \ mamewah.cfg"
example to launch the selected game with button 8 and key 1
Code: [Select]
### INPUT MAPPINGS ###
# main form
UP_1_GAME "DIK_UP ¦ JOY1_UP ¦ MOUSE_UP"
DOWN_1_GAME "DIK_DOWN ¦ JOY1_DOWN ¦ MOUSE_DOWN"
LAUNCH_GAME "DIK_1 ¦ JOY1_button8"
### SETTINGS ###
# 0 or 1 (off / on)
keyboard 1
mouse 1
joystick 1
« Last Edit: June 01, 2019, 06:41:33 am by Nuexzz »
TeutonicDarkness
« Reply #3 on: June 01, 2019, 03:28:08 pm »
Code: [Select]
# main form
### SETTINGS ###
# 0 or 1 (off / on)
keyboard 1
mouse 1
joystick 1
This is the file I am setting. I have been trying to setup button 8 and button 9 to replace key press
1 and 2. I have discovered that button 9 works instead of buttons 8 all other buttons including 8 do not.
My joystick and buttons work in everything except mamewah.
TeutonicDarkness
« Reply #4 on: June 06, 2019, 11:31:09 pm »
 Anyone out there have any other ideas? I am going mad over here trying to figure
this one out :angry:
I was really hoping I could continue to use Mamewah...
If I can't figure this out its back to the quest of finding a new go to frontend.
I have finally figured this out Mamewah sees the buttons wrong
 8 is 7, 9 is 8 .
At least I know now....
I can live with the limitation. ;)
« Last Edit: June 07, 2019, 01:12:38 am by TeutonicDarkness »
Nuexzz
« Reply #5 on: June 08, 2019, 03:12:44 am »
come on guys! it's not a problem of S.O. 10,8,7 ... it's just a configuration, (personally I with joytokey, I have everything configured to my liking in w10)
Nuexzz
« Reply #6 on: June 08, 2019, 03:15:42 am »
 8 is 7, 9 is 8 .
try to emulate the keystrokes of joy by keys with (joytokey)
TeutonicDarkness
« Reply #7 on: June 08, 2019, 11:00:50 am »
Would you then be willing to help with other issues if I PM you?
Nuexzz
« Reply #8 on: June 09, 2019, 12:36:43 am »
Sure, I have no problems.
