Author Topic: WG K7400 Linerarity, slight issue.  (Read 1154 times)
Tim McManus
  • Last login:May 28, 2019, 01:53:06 pm
« on: May 28, 2019, 01:50:45 pm »
Just got my WGK7400 chassis running  and its been working fine "BUT" there is a slight linerarity issue.  The monitor is for a "vertical" oriented Multugame, so when viewing from the front, Monitor oriented "vertically") the far right hand side seems slightly larger proportion than far left side. (about 1/4 of an inch)
I have done the ususal cap kit and replaced the vertical deflection IC.
Any way to adjust this so the symmetry is equal on both sides?
